Question about ASUS ET2410-06 23.6 LCD Desktop i3 3.3GHz 4GB 1TB DVDRW
The computer shows a blue screen and crash report after being idle for some time
I left my house and about 2 hours later, I came back to find my computer had a blue screen with text saying there was a crash report, that windows had not shut down properly....What does this mean? It does this every time I leave it on and it's not in use for a long time? Please help! Thanks!
  • ASUS Master
  • 27,725 Answers
I would say you need thermal paste and clean the dust from inside your computer.
And while you are at it give it an overhaul download some Free antivirus and
BSOD Bluescreen of death can be caused by a number of things If the PSU power supply units fan is not working the PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
A bad or faulty motherboard data lead or its connection if its a flat 40 pin ide it will be the first to fail
make sure all leads have a dust free secure connections
A bad driver loose or faulty lead or not having enough ram or the RAM modules might be dirty. Might be getting hot Check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Then reseat the modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. You might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang and cause memory dumps
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask the seller if they guarantee the compatability of the ram before making any purchase
if you dont want to install more ram uninstall some unnecessary programs
make sure your ram modules have a dust free secure seating and the CPU central processing unit has thermal paste
If eventually you can get a screen Click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver. If you computer came with a motherboard disk the drivers could be on it or you might have to download one. or it might be a virus right click in bottom toolbar select task manager applications to see what is running and processes to see what is ticking over. http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information malware protection http://100-downloads.com/download.php?p=615 windows xp microsoft security essentials http://100-downloads.com/download.php?p=614 windows 7 microsoft security essentials
Hope this helps.
Posted on Dec 31, 2012
I turned on my modem, an all that is displayed on my monitor is the blue hp screen. In the botton left hand corner it says <F10=Setup> and <Esc = Boot Menu> and in the right bottom corner, it...
what modem, who's and where, ?
or is modem , monitor?
which blue HP screen there are many,
you left out what it says...
i can not watch you boot, and what is displayed, is key to the cause.
NO OS stated, is this XP?
when you boot, it always prompts in text ,hit ESC key to enter setup"
this is the BIOS hot key prompt that some times shows
a cute small HP icon this too is BIOS created.
then the PC boots and goes to OS, there many OS offered
Windows is XP is one? is it?
or Vista.,w7,/8/10 or PS/2 or linux. HP has many offered OS.
as do Refurb companies endless.
if windows?, the windows log in screen is next.
so my guess is the PC goes to BLUE screen that, before that.
stating (presenting)
startup file failed?
or , HP recover failed.?
or any of 50 other windows blue screens of *****.?
why not post a photo of the screen?
one screen is the XP BSOD , crash screen.
seen here.
one other blue screen is "windows is doing updates" so let it??
one modern HP W10 screen 1 of 50
this is most times below a bad video card driver used on PC.
not matching card to OS. and bam crash.
Aug 28, 2017 | HP Hewlett Packard Pavilion Slimline...
ACER Process 2/24 PreSystem
im having the same problem if anyone cann help that would be great !!!
Feb 07, 2010 | Acer Computers & Internet
Blue screen of death comes up then the netbook turns off
This article may help you....or these.
If you can turn off the auto restart to get a stop error code from the blue screen, that will help you to diagnose this error. See 'disabling restart..." here. Then reboot and note the exact error code reported. Write back with that info and we'll help you to sort it out.
You can look up codes here.
Also helpful links for blue screens here, here, & here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 01, 2009 | Acer Aspire One AOA110-1588 Notebook
Reporting wrong times on my emails
You probably need to check your time zone settings in Yahoo...
on the upper right-hand corner just above your yahoo mail inbox, you'll see an options link... select mail options.
when you get to that page, click on 'accounts' in the left-hand menu, and once in that page, click on add or edit an account.
in this next page, click on account information, you may be prompted for your password before continuing....
once you get in there... look for 'Time Zone' and see if yours isn't some hours ahead of what it should be.... if so, click on the edit link for that section, and change this to your correct time zone.
that should do the trick!
*bru
Feb 09, 2009 | Yahoo Mail
My laptop crashed over the summer; everytime I turned it on it would bring up the blue screen that says "begining physical memory dump" and a few times after that it would no longer turn on and i...
If you have win Xp go to start then programs then accesories then system tools then system information . Sorry about all the thens. when you get there click on hardware resources and conflict sharing that will give you some idea then you can click on componets and problem devices and see whats there. I hope that helps you
God Bless Greg
Nov 30, 2008 | Computers & Internet
MGS4 crashed my ps3
I would say to replace the blue ray drive. It's problaly a faulty drive.
Jun 19, 2008 | Sony Playstation 3 (PS3) Console
Truly MP3 13X only showing blue backlight
same here, you just have to keep messin' with (pluging it into computer, etc.). I know it sounds strange but that's how I deal w/mine. It eventually comes back to life.
Feb 21, 2008 | Truly MP313X 1 GB MP3 Player
ASUS ET2410-06 23.6 LCD Desktop i3 3.3GHz 4GB 1TB DVDRW Logo
55 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
