Question about Tablets & eReaders
Unable to connect my ez tab to wifi
Connected one time', unable to get it to connect to my home or work wifi
5 Suggested Answers
  • 21 Answers
SOURCE: can I use my galaxy
Go to settings -> wireless and network -> mobile AP -> press the mobile AP check mark -> click yes. the access point name and password is located on the bottom of the page in the mobile AP menu. cheers.
Posted on Mar 08, 2011
  • 525 Answers
SOURCE: My Galaxy Tab no longer
You have to re enter your security code on your tab
Posted on Mar 12, 2011
ngwasuma
  • 75 Answers
SOURCE: galaxy tab p1010 connected to
I suspect your proxy setting on your p1010. Maybe you have set a malfunctioning proxy server
Posted on Jul 09, 2011
  • 239 Answers
SOURCE: unable to connect to wifi several days at a time
I understand the you are unable to connect to Wifi.
Need more clarification on this:
1. What is brand and model name of the Tablet?
2. What is OS installed on it (Android or Windows)?
3. Have you ever connected to Internet on this Tablet?
4. When did you first notice this issue:
Thanks and regards,
Jitha
Posted on Nov 20, 2011
How do I stop continually trying to connect to wifi and failing
Unable to Connect to wifi problem - Solved for me ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jun 7, 2012 - I tried the "forget the connection" workaround but it always came back. ... recognizing and joining the wireless network, but are not connecting ... Ipad won't connect to wifi after update iOS 7.0.6
Mar 1, 2014
New iPhone 5s - constant "Incorrect WiFi" password
Nov 25, 2013
Wifi ISP keeps failing
Sep 10, 2013
New Macbook Air - wifi connectivity problems
Jun 13, 2013
More results from discussions.apple.com
How to fix limited or no connectivity Wi-Fi issues in Windows 8
www.fixedbyvonnie.com/.../how-to-fix-limited-or-no-connectivity-wi-fi...
The connection is limited ... He couldn't connect to Wi-fi on battery power. ..... Will this work if we have limited connectivity when trying to connect through a LAN cable? .... I found another solution, If you are running Windows 8 and your laptop keepsdropping the WiFi .... Investigate router or access point issues Failed
Dec 28, 2015 | Tablets & eReaders
Why Tablet Wont stay connected to wifi?
this may be because they wifi goes away and comes back again. or maybe because it's messed up .
hope this helps.
Feb 06, 2015 | Samsung Galaxy Tab 10.1 Wifi - Tablet -...
I cannot get my tab 3 which is brand new to even see my wifi at home. it says it is not in range. i have been able to connect to some free wifi in other spots. help!
I read something about manually adding a wifi spot...Don't remember where it was but try Samsung dot com
go to your wifi page and do a search will progressively getting closer to you modem... if it doesn't see it in range at all, check with your internet provider as something may be conflicting... I've had no problems connecting to my home wifi or wifi spots all over the state of Florida and I have the same Tab. Wonderful product and you will enjoy it. Also some apps are made for mobile phones only and will not work with the tabs... keep this in mind
Dec 18, 2013 | Samsung Galaxy Tab 3 7.0" - White...
Will not connect to wifi
  • Touch the Apps Menu button on the Home screen.
  • Open the Settings app.
  • Choose Wireless & Networks.
  • Choose Wi-Fi Settings.
  • Ensure that Wi-Fi is on.
    When you see a green check mark next to the Wi-Fi option, Wi-Fi is on.
  • Choose a wireless network from the list.
    Available Wi-Fi networks appear at the bottom of the screen. When no wireless networks are listed, you're sort of out of luck regarding wireless access from your current location.
    Optionally, type the network password.
    Touch the Password text box to see the onscreen keyboard.
    Touch the Show Password check box so that you can see what you're typing; some of those network passwords can be long.
    Touch the Connect button.
    You should be immediately connected to the network. If not, try the password again.
  • May 12, 2013 | Samsung Galaxy Tab Tablet PC
    Can't connect mini iPad to my wifi my other iPad is connected
    Always a good idea to shut down and then turn back on (hold down both home button and power button until it turns all the way off. Wait a couple seconds, then press the power button to turn back on)
    Try wireless again.
    If nothing, then
    Obviously check and make sure wifi is on under settings.
    If still nothing,
    Try resetting your network connections:
    Settings > General, then tap Reset > Reset Network Settings
    If you can't see any wifi networks at all, you might have a bad wifi card in the iPad. Bring back to an apple store.
    Jan 31, 2013 | Tablets & eReaders
    Authentication problem connecting to wifi
    Can't get unit to connect to my home wifi , keeps giving message Authentication Problem
    May 12, 2012 | Polaroid Tablet Computer PMID701
    Unable to get connected to the internet and the app market
    On my Iconia when I see this show up it will be from a low power or a poor wii connection. Basically the signal strength is too low which means the speed drops to the point where everything is timing out before it gets loaded.
    There are a couple o causes to check . One is too far from the wifi router.the farther away the lower the signal the slower it goes. You have objects blocking the signal such as steel reinforced safety windows or steel mesh in walls. These can block the signal. I have one are where I'm all of 10 feet away and it will barely connect. I have to move about three feet to the side and get ull strength and speed. The orientation of your tablet can effect i you can use a marginal signal or not. Try aiming the edge with the volume buttons towards the wifi. The antenna is oriented in a way that this will slightly improve the signal. The other thing is that your tablet can be fine but your wii router is having problems with its wifi sections. Certain brands will show more errors and then difficulties in connections in as little as a year old (on some about half that). The Iconia has a rather good wifi ability so I wouldn't blame its hardware but would look at the location orientation etc as I have mentioned.
    Feb 20, 2012 | Acer ICONIA Tab W500PC52G03iss
    Unable to connect to wifi it just says scanning
    make sure your wifi network is turned on, then open your tablet's wifi and search for it. it should be fine, if not, contact Toshiba for tech help.
    Android 4.0 Tablet PC
    Feb 04, 2012 | Toshiba Thrive Android Tablet
    My galaxy tablet cannot detect our wifi connection. it always says disabled and scanning, obtaining IP address but will not connect. ive turn of/off the unit and entered the passkey several times but still...
    Does the WiFi router have SSID? Did it ever connect to other WiFi Access Point before? If not some say to set the Tab on Static IP and configure the router to allow the Tab's MAC address. Hope it helps.
    Jan 02, 2011 | Samsung Galaxy Tab Tablet PC
    Tablets & eReaders Logo
    66 people viewed this question
    Top Tablets & eReaders Experts
    Are you a Tablet and eReader Expert? Answer questions, earn points and help others
