Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Trying to connect to plex, asking for host name or IP address also external port #
  • 7,627 Answers
Reset the Netgear to default settings. This manual page 2.7 : http://kbserver.netgear.com/pdf/wpn824_ref_manual.pdf
Posted on Dec 31, 2012
3 Suggested Answers
anandg27
  • 1272 Answers
SOURCE: Well anandg27, I performed the instructions to my
Hey Gary,
In that case, make sure that you enter the correct PPPoE information on the router and also please confirm me about the following details:
# When you are connected to your modem, do you key in your username/password before you can go online or are you able to go online directly?
Posted on Oct 12, 2009
Testimonial: "A big effort made by you. Thanks a whole bunch."
  • 159 Answers
SOURCE: Netgear DGN2000: Only ethernet port 1 works.
Sounds like a configuration issue. With some routers you can set them up for bridging. Normally port 1 would connect your "bridge" and port 2-4 would connect your computers. You can test this by plugging your modem into port 1, and your computer in port 2. Power cycle your router and see if you get connectivity. It may be in your best benefit to reset the router to factory settings and see if 2-4 work with factory settings. After the reset, reconfigure the wireless side and your firewall.
Posted on Oct 26, 2009
Canon IR 1023if; trying to network with buffalo router and two laptops and a wireless desktop. subnet mask 255.255.255.0 default gateway is 192.168.11.1 laptopA 192.168.11.2 laptopB 192.168.11.4 desktop ...
Did you change the coper to static IP? If not then the copier is most likely still set for a dynamic IP. A dynamic IP means the number will change from time to time when the IP lease from the router runs out. Your computers are most likely set for dynamic also. This is not a problem and the use of dynamic IP's is very common.
If you print out a status page (also know as a configuration page) from copier/printer there should be a Host name listed along with the IP address. The host name is a name that always stays assigned to the network card (providing you don't manual change it). If you substitute the host name for the IP address when you are setting up the printer port the computer will always look for that name on the network when you send a print job.
The IP address and host name are both ways to find the proper device you are looking for on a network. Think of them the same way as a phone number. You dial your friends cell phone and it goes out over the cellular network looking for your friends cell phone once it finds your friends cell phone his phone rings. IP's and Host names work the same way.
Let me know if you need anymore assistance. If needed I can log in remotely and give you a hand.
Shawn
Jan 28, 2011 | Canon imageRUNNER 1023iF Black and White...
Network installation error access denied on hp lj1020 my printer was working fine. i have installed printer on xp m/c its working fine but when i install it on win7 it give error print spooler error or...
HP says to use the Vista drivers. You have to install it a a local printer follow these steps....
1. Make sure the printer is turned on and connected to your network. Verify that you can access the printer's internal web page by browsing to its IP address before continuing. Print a network config page or make note of the IP address and Name. (should be a static IP)
2. Click >> Start >> Control panel >> Devices and Printers.
3. Click the Add a printer
4. Select Local printer
5. Select Create a new port and select Standard TCP/IP Port and click Next button.
6. Under Device type, select TCP/IP Device. Under Hostname or IP address, enter the printer's host name (found on the printer's network configuration report the generated above). Click Next.
If you get a message about Additional Port Information Required, then the printer was not found using the host name. You can go back and retry or using the printer's IP address instead of the host name.
7. Select HP or Hewlett-Packard from the list of manufacturers and select and select your printer model. Click Next.
If your printer model was not listed, then select Have Disk, browse the HP CD that came with your printer and select the first file that starts with hp and ends with inf.or use currently installed driver if you have teh correct on installed. Click Open then OK. Select your printer model. Click Next.
8. It will ask for the Printer name -- enter a new name or use the existing one. This will be the name of the printer that you select from other applications.
9. You may be asked to share the printer. Make a choice and click Next.
10. The Print Test Page box appears. Go ahead and print it.
11. Click Finish.
Dec 19, 2010 | HP LaserJet 1020 Printer
I am getting an oracle error while trying to login. The error says: ORA-12545; Connect failed because target host or object doesnot exist. What could be the probable error?
ORA-12545: Connect failed because target host or object does not exist Cause: The address specified is not valid, or the program being connected to does not exist.
Action: Ensure the ADDRESS parameters have been entered correctly; the most likely incorrect parameter is the node name. Ensure that the executable for the server exists (perhaps "oracle" is missing.) If the protocol is TCP/IP, edit the TNSNAMES.ORA file to change the host name to a numeric IP address and try again.
Aug 16, 2010 | Computers & Internet
Can you tell me what an ip addresse is im trying to connect to xbox live and it keeps asking for ip addresse
Every device connected to the public internet is assigned a unique number known as an internet protocol (IP) address. IP addresses consist of four numbers separated by periods(also called a 'dotted-quad') and look something like 127.0.0.1
since these numbers are usually assigned to internet service providers with region based blocks, an IP address can often be used to identify the region or country from which a computer is connecting to the internet. an IP adress can sometimes be used to show the users general location because the numbers may be tedious to deal with, an IP adress may also be assigned to a host name, which is sometimes easier to remember hostnames may be looked up to find IP adresses,and vice-versa. at one time ISPs issued one IP adress to each user. These are called static IP addresses. beacuse there is a limited number of IP adresses and with increased usage of the internet ISPs now issue IP adresses in a dynamic fashion out of a pool of IP addresses (using DHCP). these are referred to as dynamic IP addresses. This also limits the ability of the user to host websites mail servers, ftp servers, etc. in addition to users connecting to the internet with virtual hosting,a single machine can act like multiple machines (with multiple domain names and IP addresses).
Jan 30, 2010 | Microsoft Xbox 360 Elite Console
Remote access DVR through dydns
the host name does not reside in DNS. Try accessing with the external public ip address
Jan 20, 2010 | 2wire 2700HG-B Router (2700HGB)
Netopia NAT
I know that most Netopia's I've worked with have been able to port forward single or ranges of ports to numerous internals from numerous externals.
Address Translation needs to be on.
IP Passthrough has to be off.
Then in NAT Easy Servers, setup port forwards and specify the external IP, internal IP, and ports (can forward all).
Dec 21, 2009 | Netopia ADSL2+ 11G WIIRELESS ROUTER 400MW...
Am trying to set up a Windows 2003 server to serve web pages over the Internet. Have got a DSL line from Embarq. They installed a EQ-660R interface which is really build by Zyxel. I can reach the Internet...
In order to access your default web page remotely, port 80 "INBOUND" must be open to the internet.
To access your web server, two things need to happen.
The first is you or someone else must initiate a http request on port 80 using the public IP Address of your DSL connection.
Second, your router must forward that request to your servers internal ip address.
Ex. Lets say your public ip address is 24.39.45.10. In a browser window from a remote location, you enter the URL http ://24.39.45.10 The request will be sent to your router on port 80.
Your web server will not have the ip address 24.39.45.10 because it's on the private network side of your router. So, lets say the private ip address of you server is 192.168.1.100
You need to configure your router to take the http request coming from the internet on port 80 to ip address 24.39.45.10 and forward that request to 192.168.1.100. This is known as port forwarding.
You also need to configure the host header name of your "web page" so it knows it needs to display the web page.
Since we're just using ip addresses in this example and not an actual FQDN (fully qualified domain name), you would make a host header entry for the web page of 24.39.45.10.
To do this open IIS.
Navigate to the web site in question and right click on it then select properties.
On the website tab, ensure the port number is set to 80 and choose the appropriate internal ip address if you have more than one network adapter in the server.
Next click on the advanced tab and look for the heading Multiple identities for this site. This is where you enter the ip address 24.39.45.10.
If you have a fully qualified domain name, you would enter the domain name instead of the ip address as specified in this example.
Host header names are the key to running multiple websites from one physical server as long as it has the necessary horsepower to do so.
Hope this helps and isn't confising. If you're confused in any way, don't hesitate to ask for clarification.
Sep 13, 2009 | Zyxel P-660RU-T1 ADSL Ethernet/USB Router...
Ports
Just to verify, you are trying to connect from a computer external to your network to a computer on your internal network, right?
The error you mention is thrown if the name in the remote asstiance file cannot be resolved by DNS. Open the remote assistance file you generate in a text editor like notepad and then look for the value next to "RCTICKET=". This is name name & IP of the computer requesting remote assistance. If you're trying to connect from an external computer, make sure of the following:
  1. On your router, forward TCP 3389 to whatever IP you're trying to access
  2. That the hostname listed is able to resolved externally (it needs to have a fully qualified domain name list somehost.somedomain.com not just somehost'
  3. The IP address is not a private (192.168.x.x or 10.x.x.x) address but a publicly accessible IP address.
Feb 10, 2008 | Computers & Internet
First packet in connection is not a SYN packet:
Verizon blocks port 80 traffic to residential customers. If you want to host a website, they expect you to pay for the business service and a static IP.
I am monkeying around with my DNS records on goDaddy to see if I can get http traffic to go to port 8080 instead of port 80. So far, I have not had any success.
I did find no-ip.com, which, for $25/year, will "host" a simple redirect for you, so that when people type in http://yourdomain.com, it actually gets redirected to http://yourdomain.com:8080. That :8080 does show up in the address bar, but I think that's okay. Especially for $25/year.
Nov 08, 2007 | Actiontec (5GE583000-01) Router
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
93 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
