Question about Motorsports
Fixing thermostat 1994 malibu 2.4 - Motorsports
How to change thermostat in malibu 2001
Follow the radiator hose back to the engine on the top side. Where the hose connects to the engine is the thermostat housing. Remove the hose clamp and hose (when vehicle is cool). remove the housing itself and the thermostat will be right in front of you. Replace an put it back together. Fill up the radiator fluid again. After you start the motor for about 2 minutes check the fluid again and top off if needed.
Feb 17, 2015 | 2001 Chevrolet Chevrolet Malibu LS
How do I replace thermostat on 2010 malibu
Follow the top heater hose to the engine. Where the hose connects to the engine is where your thermostat is located. Usually 2-3 bolts holding on. Replace thermostat. Be careful to note which way the thermostat comes out of your engine. They only work one way.
Oct 18, 2014 | 2010 Chevrolet Malibu
Replace thermostat on 1998 malibu
follow top large hose from radiator to engine block the thermostat is inside the metal case remove the 2 bolts and lift away remove old thermostat clean old gasket off with razor scraper being carefull not to get anything in the block replace thermostat place new gasket on then put metal case back on and secure with the 2 bolts top off fluids as needed.
Jan 18, 2013 | 1998 Chevrolet Malibu
Why is coolant spitting out of reservor of 1999 chevy malibu
Probably a blown head gasket. Not an easy fix and not for the faint of heart.
Mar 13, 2012 | 1999 Chevrolet Malibu
Where is thermostat located in a 2006 Chevy Malibu LT, 6cyl 3.5 L?
normally thermostats are located at the end of where the top radiator hose connects to the intake manifold, there should be at least 2 -3 bolts holding the thermostat housing on, radiator will have to be drained low enough in order to remove the hose, and housing. and thermostat, and gasket.
Mar 19, 2011 | 2006 Chevrolet Malibu
CAR RAN HOT 1999 CHEVROLET MALIBU
Several things ... best guess, in order:
1. (very likely) Radiator fan is not blowing (turn on car and a/conditioner.
When compressor kicks in, the radiator fan must blow). If it ims not blowing,
the radiator fan motor may be burned out ($40).
2. Check / replace "cooling fan" fuse ($1) and / or "cooling fan" relay switch
($7).
3. Could be (not likely) thermostat sticking shut. Replace thermostat ($20)
4. Could be radiator hose collapse (not very likely) ($18)
5. Radiator clog or hose leak (possible)
6. Head gasket broken (not likely unless you don't fix current problem) ($150)
The more detail of the symptoms, the better we can assist you.
Hope this helps!
Sep 22, 2009 | 1999 Chevrolet Malibu
Locate and Fix a thermostat in a 2000 Malibu.
The thermostat on this car was made retarded. Its located real close the the exhaust below the air intake. If you trace your upper hose you will see it connects to a housing held in with 2 nuts over studs I think. Its just really hard to get to, you might need a flex head wrench to get to it.I've put off doing my cooling system because of this.
Mar 21, 2009 | 2000 Chevrolet Malibu
Replace thermostat 1994 s10 blazer
follow the upper radiator hose to the engine, under the nipple that the hose attaches to on the engine is the thermostat, 2 bolts and maybe a bracket VERY EASY TO DO.
Feb 10, 2009 | 1994 Chevrolet S-10 Blazer
Motorsports Logo
26 people viewed this question
Top Motorsports Experts
Jim Rus
Jim Rus
chuck ringwood
chuck ringwood
_-__-___-_
_-__-___-_
Are you a Motorsport Expert? Answer questions, earn points and help others
