Sony KF-50we610 I'm getting problems with the picture I'm getting, no idea what the problem is. It's not the entire screen because the words such as 'Game' or 'HD' are perfectly clear. I haven't tried
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 35 Answers
If I had to guess, I would say it's most likely the output on your Xbox. (I don't know if the problem persist through all of the sources, even while watching tv, which would indicate an issue with your TV. But because you said GAME and HD come in clear, I can only assume that the TV is working, and the issue is with the signal itself. First, before you open it up, borrow a buddies cable, and make sure it's not just a faulty cable. If a different cable presents the same issue, then it's almost certainly your Xbox. (try another input, any other input like another xbox, dvd player, TV... to verify the source of the issue)
Specifically, this looks like a capacitor problem to me. I would look for capacitors (tiny soda can looking things) that the top is convex, or is leaking from any point. If you see any capacitors in which the top isn't completely flat, is leaking, or may have shed a lead, (feels like only one wire is soldered in when you wiggle it a bit) replace it with a capacitor of the same values. (470uf 16V can be replaced with a 470uf capacitor of higher voltage, but not lower.) The problem is, that capacitors don't always physically display faults, but may still be faulty.
If you don't see any obviously dead capacitors, I would check the solder points, and the pins on the video out connector. Just make sure that all solder points allow for continuity, and all pins are coming in contact with your cable when you plug it it. sometimes one or several pins may become slightly bent, not allowing for a complete connection. If you have any other questions, or info that could aid in repair, let me know!
Posted on Jan 31, 2013
  • 8457 Answers
SOURCE: Sony Powersupply G1 Complete
Check the transformers,and the capacitors.Zoom in the website picture of the board u going to buy,and ur power board.If these commponnents are the same vale's the board should have the same functions.
Posted on Apr 26, 2010
Testimonial: "I will verify - Thanks a lot!"
  • 192 Answers
SOURCE: Sony KDL 46V2500
This set does have a video problem. If it was bought locally, then, the retailer may have a 30 day return policy. If bought online or cannot be returned, then, contact Sony, for a service center in your location: http://eservice.sony.com/webrma/web/index.do Either way the set is to new to have a problem and you should get it resolved as soon as possible.
Posted on Aug 05, 2007
  • 1043 Answers
SOURCE: hi I cannot find the
If you go to the following website you can download a copy of the Servie Manual and the User Manual:
http://www.scribd.com/doc/19442402/KF42WE610
The file is a pdf type file. If you go to page 171 (actually page 14 of the User Manual which is located after the Service Manual), the User Manual has step by step instructions, accompanied by illustrations, of the steps you need to take to replace your lamp.
I hope this information will help you in resolving your issue.
Posted on May 05, 2010
caroldon
  • 17130 Answers
SOURCE: my sony wega kf-50we610
It looks like the vidoe board but the fault can be also a distortion in the horizontal / vertical section. So check the PIN amp and related sections. What must be looked is of the HSTAT can be off set.
Deguass the set well to confirm if there is any possibility of a distortion of picture by a severe magnetic field.
Since there can many problems associated with a distorted picture but you can try and see these possibilites other than the Y amp processing. Hope my suggestions helps.
Posted on Aug 20, 2010
  • 1779 Answers
SOURCE: Hello, I was wondering if
Sorry, you find it. It is sold as a complete Optical Light Engine. The part number is : A-1606-008-A.....$668.51
Posted on Dec 31, 2010
Blue hue accross bottom of screen - Sony KF-50WE610
You can try doing this, turn on the Tv and select the service menu, if that tint also shows on the menu, it's most probable to be your DMD board, but if it doesn't it might be the video board..
Jul 03, 2009 | Sony Televison & Video
Sony Grand WEGA KF-50WE610 LED blinks 4 times
4 times blink shows Temp Error and requires temperature sensor replacement in Sony KF-50WE610 TV
May 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Fogging problem (i.e.) screen is foggy at start up but clears 20 to 30 mins use.
what is model number of your Sony tv to provide you info about foggy picture problem.
Oct 05, 2008 | Sony XL-2100U Projector Lamp for...
SONY KF-50we610
Go to Instuction Manual of Sony KP-50WE610 page-13, there you will see details where is compartment of lamp in tv and how to open it.
Need further info, let me know.
Sep 26, 2008 | Sony XL-2100U Projector Lamp for...
KF42WE620 Red picture
I have the same problem that started tonight! It has a red hue that I can't get rid of,I tried all settings etc. Now what.....Any ideas?Thanks
Jun 10, 2008 | Sony XL-2100U Projector Lamp for...
Vertical colored lines on Sony KF-50WE610
Hi Lucian
This is a common Mainboard failure problem on Projectors.
The unfortunate thing is that this can only be solved by having the part repaired or replaced.
Apr 20, 2008 | Sony XL-2100U Projector Lamp for...
60 " SONY KF60WE610 screen went greenish
Depending on when you bought this TV, this could be the lamp. Does the red light below the green light come on? (That's the lamp light). This light typically comes on around the 3rd year of use for an average individual. I've recently enountered the same problem and will try to replace the lamp myself. Apparently its very simple.
Dec 01, 2007 | Sony XL-2100U Projector Lamp for...
Sony KF-42WE610
Sound but no picture, tv will not turn off. Light goes red but a dim overall blue screen remains and fan is still running.
Nov 15, 2007 | Sony XL-2100U Projector Lamp for...
Sony KF-50WE610 no picture?
4 blinks = No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505.
Nov 28, 2006 | Sony XL-2100U Projector Lamp for...
Bad Blub?
probably a capacitor in the tv is going bad. contact your sony repairman
Jun 05, 2006 | Sony XL-2100U Projector Lamp for...
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
