Question about Baumatic B180 Electric Single Oven
Cuts out over 100deg Celcius
When i turn the oven on it will get up to about100degrees OK, but over that temp the oven cuts out, the clock, internal light and convection fan all stop. The smaller fan in the top of the oven stays on, and after a few minutes the power comes back. When you turn the temp dial you can hear the themostat clicking so I think thats allright. Could it be to do with the heat sensor inside the back of the oven?
    Sergeant:
  • 236 Answers
The oven cut out stat may be cutting out to early first try this, it should be mounted at the top of the oven unit.
Posted on Jun 25, 2007
GE PROFILE electric range MODEL #JSP40W0W1WW cuts off and flashes f-3 code after being on 15 to 30 min, usually during temps 350 deg or above, oven temp sensor has been replaced but problem still...
you have a bad control board.try this go to this site,get the number and call them to see how much it is to rebuild you clock assy.
http://www.generaltimerepairs.com/
i've done this with older thermador clock assy. because you can't buy the clock anymore so you send out your clock and have it rebuilt,it should be alot cheaper than buying a new one if you can still get it.hope this helps you out.
Dec 18, 2017 | GE Ovens
I HAVE A GENERAL ELECTRIC (WALL) OVEN MODEL #JKP13G.. WHEN IO TRY TO PREHEAT THE OVEN TO BAKE SOMETHING IT LIGHTS UP TO ONLY ABOUT 100 DEGREES (BUT DOESN'T GET HOT AT ALL( AND THENIT JUST CUTS OFF. ...
if the clock is cutting out on you it sounds like the computer board or clock assy. same thing is bad but this oven is to old and you can't get the board anymore,it's to old and they don't make parts for it anymore,get a new oven
Nov 08, 2017 | Ovens
Electrolux EOB5630X. Oven works fine for about 20-30mins then cuts out (light in oven turns off and grill will not work at this time either). Will work fine again after temp in oven cools but cuts out...
the electronics are heating up and cutting out.that cold be a bad clock assy. or there's a fan in there that could be bad or i've seen on some models there's a screen in where the fan is,it gets clogged with dust and the air can't blow to cool down the electronics.if it is the fan and you keep using it like that it will take out the computer board or clock assy. same part.
Nov 13, 2017 | Electrolux EOB5630 Ultrafan Electric...
Turn oven on to bake when it reaches temp oven cuts off and f2 sh
This indicates the oven has reached an over temperature. You will first need to check the temperature probe for the proper reading. Refer to the tech sheet located somewhere on your stove. It should be around 1100 ohms. If this checks out good the ERC electronic range control will need to be replaced. Here is a couple links that should help
http://appliancehelponline.com/oventempprobe.html
http://appliancehelponline.com/ovenerc.html
Jul 27, 2010 | GE Profile JTP18 Electric Single Oven
Oven cuts out as soon as it reaches temperature
not expert on bosch but sounds like cooling fan not working, either fan defective or cut in themostat not working.
Jul 22, 2010 | Bosch Ovens
My oven, model 38HN-6TVW won't preheat
I was unable to get the full model to come up. I was able to get a Magic chef range to come up. I would replace the control and oven thermostat.
Aug 14, 2009 | Magic Chef 9815 Electric Single Oven
Stoves 720ef fan oven cuts out after a while, then cools down and restarts......help
There are thermal cutouts for both ovens. When the fan oven cuts out, does the thermostat display and the oven lamps go out as well or do they stay on? Is the oven cooling fan working ok, i.e. does it run for about 10 mins after you turn all the controls off? Do you think the oven thermostat is working ok and not running too hot? If it is, Lakeland do an oven thermometer for about 5 pounds that you can check the thermostats with.
Apr 22, 2009 | Stoves 720EF Electric Double Oven
Smeg oven not working. only clock and thermostat light working
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
Feb 11, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Electrolux EOB5630 oven cuts out
First thing you would want to check is, make sure you don't have any issues with the electrical connection to the oven first. Possible cuircut breaker issue.
Check these things first, you are probably going to find a loose connection somewhere. If that doesn't fix your problem.
Let me know and we can go from there.
May 15, 2008 | Electrolux EOB5630 Ultrafan Electric...
Baumatic B180 Electric Single Oven Logo
391 people viewed this question
Top Baumatic Ovens Experts
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
