Question about Dryers
My 2002 Intelidry Maytag dryer is not turning on. Drum light is off, dial turns but not moving on its own and there is the proper electricity supplied to it.
    New Friend:
    Problem Solver:
  • 11 Answers
Have u checked the socket it plugs into.. May need to be reset..
Posted on Jul 29, 2013
catriver
  • 878 Answers
SOURCE: Maytag Atlantis Electric Dryer
Fly, sounds like you blew the thermal fuse. This is located on the front blower. You will need to remove door by removing the two screws and lifting up on the hinge. Remove the 2 spacers on the other side of the door. Now the panel will pull out and the blower will be exposed. The fuse will look like the one on the right of the attached picture....Catriver..post back.
Posted on Jan 27, 2007
SOURCE: Maytag MDE4806AYW Electric Dryer won't stay running
AFTER A LONG TIME AND CHECKING ALL CONECTIONS IT FINALLY CAME DOWN TO THE CIRCUT BOARD. PURCHASED BOARD FROM REPAIRCLINIC.COM. EASY TO PUT IN. MY ELECTRICIAN TOLD ME BEFORE I START TO TOUCH THE WASHER GROUNDING MYSELF OUT.
FROM CEWAKA.
Posted on Apr 07, 2008
SOURCE: Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Posted on Jul 13, 2008
lenwest
  • 150 Answers
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Posted on Jan 30, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Electric Maytag Dryer Performa: Front loading
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 05, 2010
My Maytag MDE9606AYW drum randomly decides to not start. I hit the push button and there is loud noise but the drum doesn't move. When it does start the loud noise happens but it is quickly replaced by...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 02, 2011 | Maytag MDE5806AY Electric Dryer
Drum runs and does not heat. The dial does not move. It does not shut off. It is a Maytag gas dryer about 12 years old. Has worked great untill this problem.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 19, 2011 | Maytag Dryers
Drum won't turn
Dryer Repair - The
Dryer Repair - The
heatman101
May 17, 2010 | Maytag PYE2300AY Electric Dryer
My maytag dependable care plus electric dryer doesn't shut off
Does the timer move when it's almost ready to shut off if not most likely need a timer. Can you turn it by hand to finish the cycle and shut it off. If not must be timer.
Hope this helps
Apr 24, 2010 | Maytag MDG7600AW Gas Dryer
I have a Maytag Model pyet224ayw electric dryer, The belt broke and I replaced it. Now when I put the new belt on, every time that I turn it on the belt jumps off the tention pully. Can the problem be that...
http://www.applianceaid.com/maytag-dryers.html
this site has proper belt routing pictures for several brands maytag included might be helpful the only other thing i can think of the idler may be worn out or bent or drum may be tight not turning properly should turn freely with belt loose from inside dryer
should be able to push vanes and rotate drum easily
good luck ron
Dec 10, 2009 | Maytag PYE2300AY Electric Dryer
Our Maytag dryer runs, but the drum is not moving. When I try to spin the drum it won't hardly move backwards and forward it is hard to turn as well.
Check your blower wheel for a lint buildup or other obstruction.
Remove the front panel to access the blower wheel.
Mar 03, 2009 | Maytag MDE9700AYM Electric Dryer
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
63 people viewed this question
Top Dryers Experts
