Question about Candy Washing Machines
My Washer-Dryer Candy GO W465 does not start the programs.
After pressing the start button it is displaying E16. This is happening for every selcted program.
  • Candy Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Posted on Dec 31, 2012
  • rado_sa
    rado_sa Jan 01, 2013
    Thank you Donald!
  • rado_sa
    I have just cleaned the control board by electroclean and the machine came back in operation! Thank you again for the good support!
  • 249 Answers
SOURCE: candy cmd146 washer dryer
more info. i.e is it pumping out water????
Posted on Dec 05, 2007
  • 351 Answers
SOURCE: Asko w6021 washer not working
replace the carbon brushs in the motor,they will be worn out part no 8801195,round motor.or 8801097 square motor.
Posted on Mar 23, 2008
  • 106 Answers
SOURCE: zanussi aquacycle 1000 start pause button
Try some WD40 on the door lock on machine (not on the door) & open and close a few times. Of course the mains plug should be off the wall socket.
Posted on Feb 28, 2009
  • 272 Answers
SOURCE: Indesit WDG1095W combined washer/dryer - program wheel stopped
I'm a bit confused you posted under Bosch but you specify Indesit, which is a UK machine. The really bad news is you need to replace the timer. the really really bad news is you can only buy the timers from Indesit, I can't find them anywhere in the US. The really really really bad news is they want 117.99 british pounds for them! plus shipping and handling. Here is a link to the Indesit site where you can purchase one.
http://www.4indesit.co.uk/cgi-bin/product.pl?PID=111846&query=Indesit%20WDG1095WG&model=WDG1095WG&path=52691
Posted on May 22, 2009
SOURCE: easi logic 1300 servis washer/dryer
yes must be door catch
Posted on May 21, 2010
I have a casio Se s900 cash register. It currently shows the subtotal in the customer display in large type with the total being in small type. Is it possible to change how this displays?
Yes . turn your key to P and scroll down to program and enter press 1 or 2 an press subtotal and select settings , then scroll to display and choose font then selct the font you want
Jul 28, 2014 | Retail Supplies
How do I rename Extensions?
Press program **1234
use up down volume keys to find extension hame
selct ext. number
enter new name
store
these changes dan only be made from a 3 line display phone
May 22, 2014 | Panasonic KX-T7636-B Corded Phone
Hi , i have tried what you mention for hb88rc let say i am doing the programing and it is currently 10 am. (example) i want it to be on at 7am and off at 7pm for the entire week i do as the instruction...
You happened to catch the same guy that answered before.
Lets go through the exact programming steps:
Your schedule is ON at 7am and Off at 7pm ALL week.
1) Set the clock to current time:
Hold down clock button while doing next steps
Press Hour button until correct Hour am-pm shows (10:00am for example)
Press MIN button until correct minute shows.
>>> Now wait, the manual seems to leave off a step here... it doesn't say to enter current day.
OK, lets make sure current day is set.
I guess you press Day button until current day shows.
Now release the clock button.
2) Program the timer to your schedule:
Press and release PROG button.
press it once and Program1 ON is ready to be programmed
The screen looks like the picture below:
3) Ready to set Program1 ON:
The display shows the number 1 and it shows the word ON.
Press DAY button as many times as it takes until all days show at top of display.
Press Hour button until 7 am shows in display
Double check that the time is AM
Press MIN button until :00 shows in display
4) ON time for Program1 is set
We are ready to set OFF time for Program1.
5) Press the PROG button until the display shows Program1 OFF just like photo below
Notice that the number 1 and the word OFF appear on display
6) Ready to set Program1 OFF
Press Hour button until 7 pm shows in display
Double check that the time is PM
OFF time for Program1 is set
7) Programming is complete, and we are ready to use the timer
(If you want more programs, press PROG button until program2 ON shows in display)
8) To exit programming, press the CLOCK button.
Current time show in the display.
The timer should be operating correctly now.
Add a comment, if you want to contact me directly.
Nov 09, 2010 | Intermatic HB88RC - 7-Day Programmable...
Error e16 - cannot print even in black or white
Hi Follow the below steps .
E16 -E19 Failed to scan head alignment sheet
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
Jan 16, 2010 | Canon PIXMA MP160 All-In-One InkJet...
E16 error message for for canon pixma 210
E16 must be "Ink remaining unknown".Press and hold the "resume" button for 5 seconds.
Oct 15, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
E16-e19
E16 says that remaining ink is unknown, E19 is empty. You can press resume to print, but you should replace the ink.
Jul 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
The machine (Automatic Breadmaker SD-255/SD-254) is plugged in and the display lights up but when I press the buttons but nothing happens - I cannot change the setting or start the machine.
Plug the unit in at the power outlet. If the display comes on, switch it off with the START/STOP button. After the display goes off, switch the unit on with the SELECT button. Remember that the START/STOP button is only used to start or stop a specific program.
Aug 02, 2008 | Kitchen Ranges
Canon printer mp160 error msg 16 (e16) after replace catridge
try this PRESS STOP BUTTON FOR 5 SEC CAN FIX THIS PROBLEM
after that will adicated light alarm blinking them you can print if can't try turn off printer and turn on again.
Apr 17, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HOW CAN I GET MY HOTPOINT AQUARIUS 1400 - OFF CONSTANT TEST PROGRAM?
This works
To exit the TEST mode, press and hold down the "Start/Cancel" button until ALL of the console lights light up. Press both "Start/Cancel" and On/Off buttons simultaneously until " dOFF " appears in the display. The default setting will now appear and the machine can be used normally.
Feb 04, 2008 | Hotpoint Washing Machines
E16
press stop reset button for few seconds and you can use your black cartridge for printing,but do remember to put use black only setting in ur printer cartridge settings.
Nov 09, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Washing Machines Logo
566 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
