Question about Jcb Bruder JCB Loader Backhoe
1400b 4wheel drive won't shift into forward. reverse is ok
Machine is 1989 1400b extradig 4 wheel drive.
96 explorer disengages 4wh low but does not engage 2wheel
Does it shift to 4wd high range ? If so then shift to 2wd . What is going on here is the transfer case motor is stopping due to the motor position sensor has gone bad which means that you replace the transfer case motor assembly. But if you wish to make it a 2wd for awhile then remove motor and manually turn shaft . This can be done by raising and supporting rear axle truck in park remove motor turn shaft slowly with pliers and rotating the play in drive shaft. There are stamped markings on back of case showing gear positions..
Mar 31, 2014 | 1996 Ford Explorer
1500 stuck 4 wheel drive
Try having the truck where you can reverse for 75 to 100 feet shift truck into 2whieel then into reverse and back up 100 feet this should unlock the differential. if not get under truck there will be a a small switch mounted to the transfer case near shifter remove switch push rod in with a screw driver then re-install switch on transfer case.this will work.
Dec 06, 2013 | 1999 Chevrolet Suburban
Atv wont shift into high gear
Is this an electric shift?? SORRY.. take it to a qualified professional!!
Sep 02, 2017 | ATVs
Changed starter and now transmission won't engage in reverse. What happened?
is the level of fluid ok ? im afraid your transmission went bad not because of the starter change but it just happen at that time
Jan 10, 2012 | 2003 Kia Sedona
I parked my 1989 jeep cherokee last dec. And started it this nov. And can not get the transfor case to go in to 4wheel drive .when i shift there is no noise coming from the transfor case
So you can shift into 4 wheel but it stays in 2 wheel? If it shifts really easy into 4 wheel then you have a linkage problem (the linkage between the transfer case and the shifter, could just be that a piece wore out and fell off.) but if it feels like its shifting into 4 wheel then it would be the front end (could just be the vaccum line needs replaced.)
Hope this helped. But for more solutions you might want to post this in the Motors/cars category.
Nov 11, 2010 | Car Audio & Video
2004 jeep liberty stuck in 4 wheel drive low - can't get it to go to either 2 wheel drive or 4 wheel drive high
a reluctant transfer case can sometimes be coaxed by shifting into reverse, backing up 10 feet, and then back to forward.
Feb 07, 2010 | 1989 Jeep Cherokee
Won;t shift to four wheel drive the light on the dash blinks
When this happens I would think you have an issue with your 4 wheel Drive that needs servicing.Most of the time it's the selector switch($400),See if a National Chain( transmission )has free or low cost evaluations.Good Luck.
Sep 17, 2009 | 2004 Toyota 4Runner
Jeep stuck in low four wheel drive
Put the transmission in neutral, emergency brake off, foot off the brake pedal, now try shifting out of 4 wheel drive low. If that doesn't work, drive forward, and again do the above, trans. in neutral, roll to a stop, foot off brake, try to disengage. What you're probably experiencing is called drive shaft 'wind up', and it is very difficult to disengage, but do the above and it should shift out of 4 low. countrycurt0
Sep 01, 2008 | 1998 Jeep Cherokee
Jcb Bruder JCB Loader Backhoe Logo
Top Jcb Toys Experts
Gary Nitowski
Jerry Kramer
Jerry Kramer
Are you a Jcb Toy Expert? Answer questions, earn points and help others
