Hid compliant mouse detected but not working
I bought a mouse to use with my laptop as I'm not to fond of touch pads, anyway the computer does detect it and registers it as a HID compliant mouse in device manager. The optical light goes on but the mouse is unresponsive- nothing moves. So far: I have tested the mouse on two other systems/laptops (XP and a vista) it worked on both of them. Confirming the mouse works. I have updated the driver. I have uninstalled and reinstalled the mouse. The laptop in question is an acer aspire v5-571, with windows 8. Any help would be appreciated.
5 Suggested Answers
romsky79
  • 822 Answers
SOURCE: IBM Optical Scroll Mouse doesn't work (Device Driver Problem)
connect your mouse. then restart your laptop do not remove mouse while restarting laptop. if not work after restart there is a problem in your mouse IC.
Posted on Jun 02, 2009
rickyostrom
  • 270 Answers
SOURCE: cordless mouse interference
Yes, they have channels and id codes.
Glad you got it solved.
Posted on Nov 30, 2008
SOURCE: Wireless mouse and keyboard not working
If you have got a USB receiver for the wireless keyboard and mouse, then the solution might be with the receiver. Normally we know that to play a USB thumb drive, we simply plug in and play. But some model of Acer computer require us to press the button on the thumb drive to activate it. The model I had (an Aspire model) set the press button same as the blicking light bulb. So (a) turn on computer, (b) plug in thumb drive receiver (c) press button on the drive, (d) press "contact" button on the mouse and keyboard. That works for me.
Posted on Dec 16, 2008
  • 208 Answers
SOURCE: MY optical mouse isn't working.
You probably can get it fixed by restarting your system with "Last Known Good Configuration". To do that, reboot your system and hit F8 a few times when it starts booting. If you catch the timing just right, the boot manager will display several options. Select "Last Known Good Configuration".
If it doesn't work after you did that, you can repeat the process but this time select "Safe Mode". After safe mode comes up, you can retore your system to the restore point just prior to the installation of the HID driver that causes your problem. Alternatively, you can remove that HID driver via uninstall if it is available.
Good luck.
Posted on Sep 03, 2009
Wireless mouse windows 7
You have an outdated driver their. When you uinstall and detect the mouse, it automatically installs the generic driver which will work but will surely stop the next time you try to use it.
You can fix that by installing the latest drivers for your computer. You can find the drivers in the manufacturer's website or you can use RadarSync to automatically scan all outdated drivers. You don't need to find them manually. With just a press of a button, all drivers will be updated.
I hope this helps!
David
Feb 13, 2013 | Logitech HID-compliant Mouse
5750z touchpad not working - all else seems ok
Do you have a red light near touch pad if so press it to turn on the touch pad, If that doesn't work then click start, run, type "devmgmt.msc" When the device manager opens First I dentify any object under other devices, if it says something like unknown mouse or touchpad mouse, then go to acers support website to download the driver for your touchpad. if its not listed in device manager as an other device, look under human interface device and see if the HID compliant mouse is there. Let me know what happens
Dec 16, 2012 | Acer Aspire 5500 5570-2609 Laptop
Dell N5040 touchpad
Is there the option to uninstall? If so, try this, although it may only be a temporary fix because if you're using windows 7, it will automatically detect and install upon restart, although you may disable the automatic installation in CP
Aug 07, 2012 | Dell Inspiron N5040 Black New
HID-compliant mouse
Not much description to go on so im guessing, right click my computer and go to manage or search device manager, click on mice and other pointing devices right click and un-install restart the laptop on boot up it will recognise a mouse and install it from there if the problem is still there then try holding down the Fn button and look at the top of your keyboard to something that looks like a mouse pad and press it as doing this will turn on and or off the mouse pad if the problem still persists then there is an indication of a circuitry fault and should consult asus to send it in for replacement or a computer repair work shop to have this fixed
Jun 27, 2011 | ASUS Computers & Internet
Got a new laptop, acer 6930, my old mouse worked until some updates were done, so i bought a new Logitech wirelesss mouse,, it says it installed it, but it doesnt work
if these updates are logitech based. may be issue with hid driver system.
  1. open the device manager
  2. look for the mouse section
  3. right click on the logitech mouse
  4. update driver (do not start auto updater)
  5. select advanced/install from specific location
  6. then select dont search i will choose a driver.
  7. if you see more then one logitech driver choose hid-compliant device.
  8. mouse should start working uninstall all logitech programs and delete all folders for logitech in the programs folder.
  9. use CCleaner to get rid of any registry entries.
Jul 16, 2009 | Logitech Cordless Mouse
Optical Mouse Model AM-3055U will not work on this computer
My same model Argos mouse was auto-detected as a "USB compliant mouse" and it failed to work. Went into device Manager and manually re-installed driver as a "HID compliant mouse" from local drivers and it works!!
Yrs, Mad-****.
Jun 27, 2009 | Toshiba LCD Display for Satellite Pro...
Cant install mouse
mouse may not be compatible
what os is the laptop
Feb 08, 2009 | Toshiba Wireless Mouse PA3205U-1ETC
Touchpad not working
First check: Control Panel -> Mouse -> TouchPad On/Off
Second check for a button near the mouse pad, often there are buttons that will enable/disable the touchpad
Thrid use the shortcut key FN+F9(or what ever F key that is used by your laptop) to disable/enable the TouchPad.
Fourth try this software: http://www.kingzm.com/eng/files/download/MouseManager.zip
Fith
- Select Start, Settings, Control panel.
- Open System, click on Hardware, and Device Manager.
- Expand "Mice and other pointing devices", and double click on the entry below, that may be called "HID-Compliant mouse", or "Alps Pointing Device".
- Under "Device usage", choose "Do not use this device in the current hardware profile (disable)", and click OK.
Jan 20, 2009 | Toshiba Satellite A205-S4617 Notebook
Frozen mouse with a touch pad laptop computer
My laptop has the mouse pad built in and it froze up..I cant do a thing .I have tried to shut down and if you dont have a mouse working you cant even go to task manager etc..Now what? It is new I have only had it a month...
Dec 29, 2008 | Toshiba Satellite L305D-S5895 Notebook
Computers & Internet Logo
1,540 people viewed this question
David Payne
David Payne
