FixYa.com
Tags:
Vector VEC438 AM/FM/Weather Radio
Flickering LED flashlight (by 2 users)
posted by Al Haab on Jun 23, 2007
When the unit is inserted in the charging base with flashlight switch off, the flashlight flickers (very annoying). Flashlight works normally at other times. Is this normal?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by k9alliance, posted on Jul 15, 2008
I have had the same problem, but it seems to be sporadic. It could go weeks without doing it. I have tried to bend the contacts out on the back of it, and currently, I am in search of a replacement battery. The current one only lasts about 20 min off of the charger, and cranking it doesn't power it for more than about 3 min.
Anyone know of a place to get replacement batteries for this, other than through Vector? I cannot return the radio, as it is a couple yrs old and the receipt is long gone!
Best Solution
posted on Aug 09, 2007
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Return radio to store. Home Depot has a recall on them, took it back with no questions.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Helpful (85)
Mister Larry
Rating: 85%, 1 votes
It sounds as if the connections in the back of the radio may not be continually connected to the contacts on the charging base. You might want to make sure that the radio is properly loaded in the cradle of the charging stand.
The reason why the lights 'flicker' is because if your power goes out, the light on the radio will come on when it detects no power to the charging base. This is a feature to many new emergency radio gadgets. Imagine a storm rolling through your area and the power goes out in the middle of the night. Your Vector radio's LED lights come on so that you aren't searching for the radio in the dark.
Solution #3
posted on Aug 30, 2007
Not Rated (0)
dcelect
Rating: 0%, 0 votes
Remove battery form radio on inital charge and charge fully before replacing it.
Can you Help with these Personal Radios problems?
Alert Funnction inop
The Alert keeps showing the... Answer This...
Cannot adjust volume level...
I just got this thing a few... Answer This...
Personal Radios
manual for Audiovox AXR48 crank...
Audiovox AXR48-hand crank radio Answer This...
I have a 1500 watt
I have a 1500 watt vector power... Answer This...
Program Alert Function
I am unable to turn the... Answer This...
Repair Service
Find Personal Radio Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
