Question about Canon PIXMA MP600 all-In-One InkJet Printer
Ink blockage in Canon MP 600 printer
When printing one of the colours is not working. Have tried deep cleaning umpteen times. Have replaced all cartridges. I do recall a leaking cartridge which i believe may be linked.
  • Canon Master
  • 419 Answers
Given that you may spend a considerably amount of time and money trying new cartridges, etc... it's probably best to invest in a new printhead (these are easily replaceable and considered consumables by Canon).
In the USA, purchasing from Canon directly is very cheap but elsewhere, like the UK it's prohibitively expensive so you may be better purchasing a refurbished iP4300 from the Canon Outlet dealer on ebay. This gets you a set of cartridges and compatible printhead for a lot less than just a printhead.
Posted on Jan 23, 2009
PRINTER SUDDENLY PRINTING VERY FAINT ALL INK FULL
It is most likely a blockage in the print-head. Run a nozzle check to see if all the jets are firing cleanly. If there are colours missing or "scratchy" run a deep cleaning cycle. If that doesn't improve the nozzle check, remove the cartridges and then the print-head. Run the underside of the print-head under hot water from the tap for a moment. dry it with a paper towel and re-install the print-head and cartridges. Give a standard clean and re-try. If it still doesn't work, the print-head is probably dying.
Mar 11, 2015 | Canon Office Equipment & Supplies
Not printing in black and white from my mp 560
If the black ink injector is blocked by after market ink clogging or drying out of ink in the nozzles, get an eye dropper and put a few drops of ammonia on the ink pad below the ink cartridge. Do the deep clean from the printer control section in the software. If you do not have that feature delete and reload the printer driver from Canon.
You might have to do this on several days in succession. If the blockage is severe. It might not be repairable. If memory serves the ink holder, where the cartridges sit, is replaceable for worst case blockages or burned out injectors. You might get one cheap on Ebay. (Don't buy after market ink cartridges. They do not have the chip that sends information about the ink level to the printer. Without that feedback the printer can refuse to operate at all. )
I have one with stripped gears so all those parts work. The paper carriage will not advance to print in my old printer. But every thing else works.
Jun 23, 2014 | Canon MP560 All-In-One InkJet Printer
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
Canon MP360 not printing
You probably need a new purge assembly, it draws some ink to both clean and prime the printhead. When it stops working you won't get any ink to the paper.
Jul 19, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Pixma ip4200 willl not print Cyan
I think the problm lies between the ink tank and the printhead. When this passage runs dry, sometimes it takes time for the ink to fill this passage again. Try printing again after a day or two.
Jul 17, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
New Black cartridge not printing
Ink blockage between tank and printhead. Take out colour tanks and clean. with cartridge flushing agent in a spare tank, or do them all at the same time with cartridge flushing liquit.
Feb 11, 2009 | Canon MP520 All-In-One InkJet Photo...
Color Printing Problem
Remove all ink cartridges and replace them securely in position.That may be the problem always.
Print nozzle check pattern.See for any missing patterns
Give a head cleaning
Again print nozzle check pattern.If it is ok leave it, other wise give a deep cleaning
  1. If the printed result does not improve even after doing print head deep cleaning, turn off the printer. Then, after 24 hours or later, do print head deep cleaning again. (After a given time interval, ink could dissolve itself, resulting in ink unclogging.)
  2. Atleast a multi colour( like your visiting card) page should be printed in a week time. other wise the ink may clog in the head.
Mar 29, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP 500
Have you tried to print a couple of test pages from the troubleshooting help section to prime the print head ?
Jun 11, 2007 | Canon Pixma MP500 All-In-One InkJet...
Will not print some colours
Rhis seems to be a printer Firmware problem, Nothing for it but to bin the printer and start again.
Nov 13, 2006 | Canon BubbleJet i9950 InkJet Photo Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
145 people viewed this question
old marine
old marine
