Question about Canon PIXMA MP160 All-In-One InkJet Printer
E 2 7
No scan & print
  • eni_toro Jan 19, 2009
    error 27
  • 103 Answers
Here's the solution to fixing your problem:
Issue: ERROR LED: E, 2, 7
1. Press ON/OFF switch to reset the multifunction device 2. The MP160 may require repair
Hope this helps.
Posted on Jan 18, 2009
Toshiba e studio 307 not print or scan becouse need to enebler sofwere
U need:
Print kit ( u can print or scan via e-filing/file downloader, cant use the SCAN button)
Print/scan kit ( Scan button let u scan to fileshare, scan to email etc...)
Apr 21, 2015 | Toshiba Office Equipment & Supplies
Well I have a HP deskjet 2050 print scan copy, printer but for some reason instead of scanning a paper and sending to my computer, it just prints it out. I dont know how to make it work! Please help!
well I have a HP deskjet 2050 print scan copy, printer but for some reason instead of scanning a paper and sending to my computer, it just prints it out. I dont know how to make it work! Please help!
Aug 02, 2010 | Office Equipment & Supplies
How can I scan a document then print it with larger print?
You can scan a document or photo or negative film etc.. using a scanner, there a many types of scanners which you can choose as per your requirement. There are dedicated scanners, all in one integrated scanners, or two in one like that.. but if you need it for your professional use or daily use, it's better to get a dedicated scanner not "all in one" since with all in one if the copier fails or fax fails, the scanner will also fail because they are related and built-in integrated.
The process of scanning a document is as follows;
  • > Place the document on the scanner's flatbed.
  • > Press scan button or scan using the integrated software from the computer.
  • > Customize the scan settings/quality.
  • > Save the scanned documents.
Printing a document to a larger size is different, you can use photo editors like photoshop, etc..where you can changed the resolution as well as the size of the image. It's best to change the size or resolution before you give the print command. Or you can also change the print size with the paper size or print size.
If you still need more help, please let me know with more details. I am ready to assist you.
Good luck.
Thanks for using FixYa.
Jul 04, 2010 | Computers & Internet
Printing an enlarged version of a scanned photo
The best way is to use software like Corel PhotoPaint and RESAMPLE the pix to the sze you want. YOu typically will get better resolution.
You could also try selecting the "Fit To Page" setting of the printer window before you tell it to print.
Sep 14, 2009 | HP Photosmart C6280 Printer
Flatbed scanners that can scan prints and transparences had two light sources.
One for normal prints (ie reflective light source, the light shines from under the glass to the print/photo and reflects off this print/photo to the optical sensor).
On a scanner that can scan transparences there is a second light source in the lid that shines through the transparences pass the glass to the optical sensor. The light source under the glass is not used in this case.
The scanning software automatically selects the right source when you select to scan prints or transparences.
Sep 06, 2009 | Umax Astra 6450 Flatbed Scanner
Can I scan pictures to my computer?
Yes ... your all-in-one can print, copy and scan.
Scan an image
You can start a scan from your computer or from the HP All-in-One.
This section explains how to scan from the control panel of the HP All-in-One only. To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must
also be installed and running on your computer prior to scanning.
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software.
● On a Mac, the software is always running.
Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One.
To save a scan to a memory card
1. Make sure your memory card is inserted into the appropriate slot on the HP All-in- One.
2. Load your original print side down in the right front corner of the glass.
3. Press the Scan Menu button.
4. Press to highlight Scan to Memory Card, and then press OK.
The HP All-in-One scans the image and saves the file to the memory card in the JPEG format.
To scan a photo and reprint it
1. Press Reprints.
2. When prompted, load your original photo print side down on the right front corner of the glass, and then do one of the following:
To reprint your original photo using the default print settings
➔ Press Print Photos.
To change print settings before reprinting your original photo
a. Press OK.
Basics Guide 13
HP All-in-One overview
b. Press or to highlight a paper size, and then press OK.
The paper size choices available vary depending on your country/region.
Note Depending on the paper size you choose, you might be prompted to choose a layout for the photos on your pages.
c. When the Fix Faded Original? prompt appears, highlight Yes or No as appropriate, and then press OK.
The HP All-in-One scans your original and shows a preview of the photo on the display.
d. Press OK to display the selection menu.
Tip If you want to print more than one copy of the selected photo, press to highlight Copies, and then press OK. Use the arrows to increase or decrease the number of copies.
If you want to edit the photo before printing, press to highlight Edit
Photo, and then press OK.
e. Press to highlight Done, and then press OK.
The Print Summary screen appears.
f. Press or to highlight one of the following options, and then press OK.
Print Options Enables you to manually specify the type of paper on which you are printing and whether you want to print a date and
time stamp on your photo.
By default, the Paper Type is set to Automatic and the
Date Stamp setting is set to Off. If you want, you can
change the defaults of these settings with the Set New
Defaults option.
Print Preview Displays a preview of what your printed page will look like. This enables you to verify your settings before printing and
wasting paper and ink on potential mistakes.
Print Now Prints your photo with the size and layout you selected.
To scan to a computer
1. Load your original print side down in the right front corner of the glass.
2. Press Scan Menu.
3. Press to highlight Scan to Computer, and then press OK.
4. If the HP All-in-One is connected to one or more computers on a network, do the following:
a. Press OK to select Select Computer.
A list of the computers connected to the HP All-in-One appears on the display.
Note The Select Computer menu might list computers with a USB
connection in addition to those connected through the network.
Jul 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
Able to copy and print, scan & print, but not able to scan to pc
is your printer setup to scan to pc.need to setup email address etc.
Jun 30, 2009 | Office Equipment & Supplies
Won't print
The printe will not scan or print. When I fax documents it is recieved witha balck shadow in teh background. I get error 2200 when I try to print or scan.
Apr 03, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Problem with scan from print server
This unit does NOT officially support Samsung printers... but it will allow printing with some. It does NOT support multi-function printers features like scanning for any brand of multi-function printers.
Jan 06, 2009 | D-Link DP 301U (DP-301U) Print Server
"Scanning in progress" reported even when I'm not scanning anything
You need to install the print driver and Sharpdesk before you connect the USB cable.
Dec 10, 2007 | Sharp AL-1642CS Copier
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
76 people viewed this question
old marine
old marine
