BL 48Oc server not starting after shutting down
  • 1 more comment
  • smah98 Jan 31, 2009
    Thanks Misterixas,
    yes it uses UPS, and the output is tested for proper groundings and specifications.The power is redundant.
  • Misterixas May 11, 2010
    Well, your UPS is working OK, and you got the power you need. Does your server show any life signs? I mean is there any indication lighting? Do you hear ventilation movement when you try to start server?
    Does it uses any UPS or is it connected straight to the mains socket on the wall?
  • 339 Answers
Browse to the server in question using the Insight display on the front of the blade enclosure. It will likely be red and flashing. See if this has any relevant information. It will usually tell you why a server is not booting.
If this doesn't help then try going into the Onboard Administrator for the enclosure and seeing if the diagnostics there help. This communicates with an independent processor on each server using a separate internal management network so you can generally get some good info even if the server is having issues.
Have you added servers or changed your power redundancy settings recently? Either of these could cause you to need additional power supplies if you aren't already full.
Another possibility if your enclosure is not completely full of fans or has one or more fans that are failed is that you are trying to put the server in a pair of slots that won't provide adequate cooling. The Insight Display should help you with this. If you have physically moved the server from one location to another then this is a very strong possiblity/
One last thing, if you are running on 110-120V power with a C7000 enclosure then you need to change to hi-line voltage as 110/120 is not supported and has limitations/issues. If it's a C3000 then you are OK with 110/120.
Posted on Jul 12, 2009
Nokia 2700c start up then shutting down any manual reset advice??
Using the dialing keypad type in *#7370# and then inter your lock code (default is 12345)
Mar 10, 2014 | Nokia 2700 Classic Mobile Phone -...
System doesn't get on after shut down
Check the system BIOS. I know that in certain HP systems you can disable the power button so that it doesnt do anything. It's to stop the system being accidently shut down
Jan 26, 2014 | HEWLETT-PACKARD Hewlett Packard HP...
When i start it show 2 redlight and its blinking
The Firmware Maintenance CD, which shipped with Rapid Deployment Pack - Windows Edition 3.50, allows the iLO 2 firmware to be successfully upgraded using the "Upgrade ProLiant ML/DL/BL Firmware" job in RDP.
For more information on Rapid Deployment Pack - Windows Edition, refer to the following URL:
http://h18013.www1.hp.com/products/servers/management/rdp/index.html
Jan 25, 2010 | HP Compaq ProLiant ML530 Server
Recording software for Panasonic BL-C1
Look here on Panasonice FTP server. It should be their.
ftp://ftp.panasonic.com/pub/Panasonic/cctv/downloads/
Selvol
Sketchlab.com
Mar 31, 2009 | Panasonic BL-C1 Network Camera
HP Bl 480C server not starting after shutting down
If the processor runs, problem is with RAM. If the system is totally dead, the problem is with ATX power supply.
Jan 18, 2009 | Computers & Internet
BL-C30A Can not access via web after a few days
Your cameras are losing conncetivity because of the air link being compromised this could be due to unintentional jamming (blocking of the wifi signal)or Resetting of the beacon (beacons can be set to broadcast at intervals) They are needed for the wifi devices to know that they are still a part of the network. These are more then likely your problem
Sep 24, 2007 | Panasonic BL-C30A Network Camera
No pic .. leds blinks in sequence
Intermittent won't start, power supply LED's may be intermittent Cause: Power supply regulator I901 P/N CZ00868 is leaky, may verify the problem by freezing I901.
Jul 27, 2007 | Hitachi 60V500 60" Rear Projection...
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
