Question about Indesit W 123 Front Load Washer
Drum spring has fallen off
When moving machine out to put belt back on I put machine on side and drum spring has fallen off can't locate were to put it back.
thanks
  • Indesit Master
  • 3,463 Answers
If you look at the opposite side to the one where the spring has come off, it should help you to locate where the spring goes.
One end of the spring hooks into the side of the drum, and the other end onto the top of the cabinet.
Plz rate my solution.
Thanks.
Posted on Jan 18, 2009
Wf865 drum won't turn in programme
have you checked the motor brushes there are 2 of them they are located on each side of the motor you will have to take the motor off and you will see them at the back of the motor undo the 2 screws on each one and take out the carbons should be 25m long and shinny and spring in and out freely I can supply new ones if you need them
Sep 27, 2012 | Hotpoint Ultima WF865 Front Load Washer
Replacement belt for a Hotpoint Aquarious Extra WMA40,seem too short, but it's the same size as the one that came off!
They have to be stretched tight, so it will appear a little small. Put the belt over the motor spindle first, now guide it onto the large drive wheel of the drum, hold the belt in the correct place on the large wheel as you slowly spin it to draw it onto the wheel and it will fit. Easy.
Now then, the nasty nasty bit and I hope I'm completely wrong here!
I have once and only once ever come across a washing machine that needed a belt replaced because the belt was faulty. 99 times in a hundred, if the belt has "fallen off" and "keeps falling off" it's because of another problem. They can't simply fall off because they have nowhere to go except on the track they are set on. If your belt has fallen off, I would put good money on there being an underlying problem with the main bearings in the drum failing, allowing the inner drum to "flop about". and allowing sufficient latteral movement in the the large drive wheel for the wheel to wobble and allow the belt to slip off.
To test your bearings, open the door of the machine and by putting a little lifting pressure on the top of the inner drum, attempt to rock the stainless steel inner drum up and down.
The outer drum is mounted on springs and shock absorbers, so it will rock about (and it should do this) but the inner drum should not move up and down in relation to the outer drum. There should be ABSOLUTELY NO PLAY between the 2 drums, even the tiniest amount will mean the bearings have failed.
If the bearings are bad enough then other symptoms will typically include:
A clonking noise as you lift and release the inner drum (this is the inner drum rattling on its bearings and/or hitting the outer drum)
You will have become aware of the spin cycle becoming far noisier recently and possibly even a grinding crunching noise when the machine spins.
The drum may feel like something is crunching or stopping you turning it when you spin it by hand with the door open.
A leak from under the machine, which you will probably be able to trace to the back of the machine, coming from the centre of the drum. This is a result of the failing bearing allowing water to escape through the seal at the rear.
This is NOT a job for the uninitiated DIY enthusiast as it will mean stripping the machine and removing the drum from the chassis, splitting it, removing pressed in bearings and then sourcing and re-fitting new bearings.
To be frank, the cost of a bearing set (if they are replaceable, and most are) will be about £20 ($30) or so. But it's a long and horrible job if you haven't done it before. I know professionals who claim they can do a bearing change in under an hour, I've done a few and it takes me about 2 hours by the time I've ripped the machine apart and reassembled it after the bearing swap. A local repairer will probably attend and swap out your defective drum for a refurbished one and then take yours away so he can refurbish it and put it back in his stock. Sadly, this will take the price up to the point where you need to question if the expense is worth it or do you get a new machine instead.
Feel free to drop a comment back on this thread if I can provide more help.
Jul 21, 2011 | Hotpoint WMA40 Front Load Washer
Cant get my belt bak on really tight fit help
Jul 21, 2011 | Hotpoint Washing Machines
Very loud banging and clanking when the drum is spinning
If the dryer is making this noise the roller on the belt tensioner has a flat spot causing this to happen. The roller and belt are replaced as a unit. If it is the washer unit the spring has fallen off on one side of the drum which is one of two that balances the drun while spinning
Apr 28, 2010 | Kenmore 98702 Stacked Washer/Dryer
Drum won't turn
Your dryer uses a belt wound around a spring loaded pulley and, around the middle of the drum and, around the motor pulley to turn the drum. If you feel capable of fixing ths yourself: Unplug the dryer, if it is gas or, electric. if it is gas: shut off the gas line to the dryer then remove the gasline; next pull the dryer out from the wall and, remove the back panel. Once you do this you will see that the belt has fallen off both the motor pulley and, the spring tension pulley. put the belt back on so that the belt is tight around the drum and, the drum will turn again.
Apr 05, 2010 | Whirlpool LER4634J Electric Dryer
Indesit wdl102 - Drum making a buzzing noise, like belt slipping. Alan D
Open the machine top and pull at the belt--it should not be loose. If it is, then remove the back panel to check the drive end of the belt. There should be a tension pulley held tight by a spring that may be weak or broken. If everything below looks ok, check the condition of the belt itself--it should not be cracked, hard, or missing segments. The front panel has to come off to replace the belt. If the belt looks ok, check for loose metal or plastic bars that are fastened to the interior of the drum--tighten any loose screws from the drum exterior side. Another possibility may be the drum front support bearings that are dirty or have failing bearings if the roller type. One further point is to look below the lint filter for anything that might have fallen into the blower fan. Hope some of this helps!
Mar 26, 2010 | Washing Machines
Putting on belt
put it around drum,then around motor pulley, then idler pulley with spring attached to, move it forward and slip belt onto idler pulley and release and belt should become tight,then self align belt by manually turning drum before putting unit together
Sep 13, 2009 | Crosley CDE6000 Electric Dryer
New belt runs too close to drum on pully
adj belt in motor pulley groves 1 grove at at time spin with hand to center on drum pulley
Dec 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Clothes are still soaking wet after spin cycle and the wash cycle is complete.
If the drum spins in the spin cycle, then the belt can't be broken. However, if the drum does not move at all in wash and spin, then the belt can be broken or just fallen off. You will have to remove the back plate and fit the belt back on the drum pulley and the motor pulley. If belt is ok check the motor brushes, they could be worn. They are located one on either side of the motor and identifiable by a single wire that connects to each one. You could also have a restriction in one of the drain hoses which is not allowing all the water to drain out.
Nov 05, 2007 | Maytag MAH6500 Neptune Front Loading...
Indesit W 123 Front Load Washer Logo
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
