Question about Utilitech 1-HP Cast Iron Shallow Well Jet Pump PPSWJ100
Manual for utilitech shallow well pump - Utilitech 1-HP Cast Iron Shallow Well Jet Pump PPSWJ100
  • rmorgan314
    rmorgan314 Jan 01, 2013
    i bought it last spring while remodeling a lakeside cabin. the paperwork meanwhile has been lost. I can't find the wiring diagram from the line in to the juntion box on the pump. In other words, which wire in goes to which wire on the pump?
2 Suggested Answers
boysor2933
  • 293 Answers
SOURCE: I have a Utilitech 3/4 HP jet shallow well pump #0003134. On start up, it hums a long! time before turning, sometimes tripping the 15 AMP breaker. Anything I can do?
Try replacing first the capacitor. If it will not solve your problem, check the integrity of the motor winding insulation by doing a line to body resistance measurement. If it is okay, replace the motor bearings.
Posted on Nov 06, 2012
Can the pressure switch on the Utilitech 1hp convertible shallow well pump be changed from 20/40 to 30/50?
Yes, if the plumbing can handle the extra pressure. There should be a nut in the middle of a large spring inside the pressure switch. Turn that nut clockwise to increase the pressure. You may need to run some water to keep the pump cycling while you do this.
Jul 24, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Once the water is shut off the pump keeps running
the pump is controlled by the storage tanks pressure switch , if it continues to run well after the pressure tank has refilled with water , either the switches manual override has been activated (lever) or its defective or blocked off with mud
Jun 27, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
How do I replace the bearings ? can I get a manual on this ?
Yes you can get a parts diagram, a manual(usually downloadable version) At ultitech.com then select: parts/ manuals /schematics.
May 11, 2014 | Utilitech 3/4-HP 15 GPM Shallow Well Jet...
My utilitech shallow well froze breaking the rear flang tetween motor and pump need flang how do i order one
It would probably be easier just to get a new pump. There is two flanges that mate, one on the motor one on the pump. I believe it is called a "C" face on the motor but I am not sure. You can get replacement motors with this flange.
Jan 12, 2014 | Utilitech Plumbing
I have a utilitech jet pump can only set pressure to 20-40 would like to set to at least 30-50 but cannot .The pump is less than 6 months old .any ideas other than i bought the wrong brand
Sorry Richard,
Sounds like you are correct, you bought the wrong type of pump...if your looking for pressure/output you might consider purchasing a "sprinkler pump"...they will go past 70psi and more
Please take time to rate me
Bud
Mar 31, 2013 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Need manual for utilitech 43467
You might be able to obtain this directly from the supplier
Jan 15, 2013 | Utilitech 1/2 HP Convertible Jet Pump...
Nov 02, 2012 | Utilitech 3/4-HP 15 GPM Shallow Well Jet...
I have a Utilitech 1hp shallow well jet pump which turns off and on rapidly while using water. I have 25 psi in the air tank. I replaced the pressure switch and still have problems.
Good you got it working. Please post again if you have more trouble on this or another item. Also be sure and check what I mentioned just in case you are operating at the margins, don't want a failure right after you got it going!
Sep 15, 2012 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Utilitech 1-HP Cast Iron Shallow Well Jet Pump PPSWJ100 Logo
780 people viewed this question
Top Utilitech Plumbing Experts
Paul Carew
jhnolson
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
