Question about HP Compaq nx6325 Notebook
Nx6325 problem no response ..
My nx6325 has no response,
device manager said everything is ok,
how i can check everything around keyboard ?
what i have to do to solve this problem,
any1 other already has the problem like this ?
how i have to approach to this problem ?
how i can check connector ? where it is ?
how to find it ?
regards Miran
    Scholar:
  • 180 Answers
You must define the problem
Posted on Aug 01, 2009
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Usb types connections
    try another k/b or update usb driver. if not try to reinstall windows.
    Oct 23, 2013 | Dell OptiPlex GX520n PC Desktop
    Nx6325 battery
    If the battery is not charging,it can be that the battery itself works properly,but the system doesn't indicate that the battery is charging. in order to fix this problem,you will need to reinstall the battery management software by using Device Manager
    1.Open Device Manager
    Right click on My Computer->select Properties->click Hardware tab->click Device Manager
    or if you're using Vista or windows 7,type "device" on the Start menu and select Device Manager
    2.Expand the Batteries category
    3.Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall .
    WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
    4. On the Device Manager taskbar, click Scan for hardware changes .
    Aug 17, 2012 | HP Compaq nx6325 Notebook
    Nosound
    Just to make sure desktops almost never have built in speakers.
    1. Check that your speakers work. Try them with an MP3 player or other device to make sure they work.
    2. Check that the speaker is plugged in the right socket. Play something on computer and switch around the plug.
    3. In windows press START->Control Panel->System->Device manager.
    Right click on Sound device and write down the make (Company and a model number).
    4a. Google their website and go to support->downloads/drivers and download the appropriate driver.
    4b. If its an INTEL sound device you might have to look up the motherboard as it might be bundled with the motherboard driver.
    Jul 05, 2011 | Intel Computers & Internet
    Does th-e nx6325 have a bios battery if so how do i change it
    You gain access to the bios battery by lifting the keyboard. First, undo the external memory cover ( 1 screw) on the bottom of the laptop. Then you will see 2 screws which hold the keyboard down - undo these. Turn the laptop right way up, open it up and move back the 4 small keyboard retaining latches (located at the top edge of the keyboard). The keyboard can now be carefully tilted up by its top edge to reveal the motherboard with the bios battery there in the middle.
    Jul 13, 2010 | HP Compaq nx6325 Notebook
    The computer boots up fine, but i have no response from my keyboard or my touch pad....any ideas? I think there is a chip malfunction on the board....
    Hello there:
    First i would boot into bios and check the advanced section or your periphal devices and see if the mouse and the keyboard is enabled and iof it is you cantry to go to the device manager and see if they are showing up there if so you can use the device manager to uninstall the device nd once it is uninstalled reboot the machine and upon restart if everything is good with both of these items you mentioned it will reinstall all the drivers for this ok?
    I hope that this is verey helpful for you
    bvest regards michael
    Nov 17, 2009 | Acer Aspire One PC Notebook
    My keyboard just stop working . how do i fix it ?
    check all connections to the computer - if it is a usb keyboard, try another slot - if everything is connected, reboot the computer - if that doesn't work, check in the device manager (right click my comp, hardware, device manager) - and uninstall it (should be listed as keyboard or usb device) - then right click the top again, and click search for new hardware - this will reinstall the driver.
    hope this helps!
    Sep 12, 2009 | eMachines M5405 Keyboard
    Nx6325 keyboard problem: no response ..
    fuddi dya keyboard nwa lai la 200 rupye da anna wa
    Jan 18, 2009 | HP Compaq nx6325 Notebook
    HP Compaq nx6325 Notebook Logo
    208 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
