Question about Dell Dimension 4600 PC Desktop
I can't close tower cover
I just added ram and I can't close the tower cover
  • Dell Master
  • 27,725 Answers
When your computer appears to slow down, one way to help increase its speed is by adding memory. You can easily purchase memory chips from various online sources or if you have a Dell Dimension and want to stick with Dell products, you can purchase additional memory chips from Dell itself. It is not difficult for a non computer person to add memory to a Dell Dimension, although sometimes, it is cheaper to purchase a new computer and then install additional memory.
Shut down your computer, turn the computer off and unplug it. Open your computer case. There will be two thumbscrews on the back of the Dell Dimension computer case that will release the cover. The side of the computer case will then slide backward and lift away from the rest of the box. Locate the slots for RAM. These are short off-white slots that are near the power supply on the motherboard. They will be slightly longer than the RAM you are about to add. There will be at least one RAM chip already in place in one of the slots. Place your new RAM chip into a blank slot gently. It does not matter which slot you use; any will work. When you press the RAM into place, be sure the notch on the chip lines up with the slot. There will be a guide on the slot to ensure that you do not insert the chip backwards. Press down on the RAM chip until it locks into place. There are two guides on the side of the slot that will snap into place on the sides of the chip to ensure the chip does not fall out. It will take a bit of pressure to make the chip snap into place, so press straight down into the motherboard to get the chip in place. Close the computer case, put the thumbscrews back where they belong and start up the computer. Your Dell Dimension will sense the new RAM, which will be available to the operating system when the computer starts up. Hope this helps.
Posted on Jan 01, 2013
Should the engine be running when adding coolant to my 2003 cadillac cts
If you just drained it & are refilling,then yes,the engine
should run & warm up until the thermostat opens & you
keep adding.
If it isn't hot & circulating thru the entire system, you won't
get it close to full with the rad cap off
Jun 10, 2012 | 2003 Cadillac CTS
Why can't I pick up AM stations on my radio
Have you tried adding a antennea booster ?
Mar 13, 2012 | 1995 Buick Park Avenue
My computer screen is black after logging in and i cant do anything i have windows vista
Hello
This usually occurs when your RAM is faulty and can actually happen to all computers running many different operating systems. Aside from installing a new operating system to test out the RAM, you can simply switch out your RAM.
Turn off your computer if it is on. If you are experiencing the black screen regularly, there is a good chance that it will not allow you to boot up your computer fully without shutting itself down. If this is the case, your computer is already more than likely off. Remove the power cord from the computer tower.
Remove the screws that hold the PC tower cover in place with a screwdriver. The tower cover usually only comes off on one side, so gently remove the side that is capable, and place it away from the tower. Users with laptops need to remove the RAM panel from the underside of the computer. This gives you access to the RAM for replacing.
Locate the RAM that is attached to the motherboard of your computer. You will see clasps that hold the RAM into place, and you may see more than one stick of RAM. Remove all of the RAM sticks by pushing the clasps away, unhooking the RAM from the motherboard. Click your new, replacement RAM into place, and cover the tower back up with the cover, or replace the laptop RAM panel.
Hook up the power cable or place the battery back in, and power on your computer. You now see that your computer is working without the black screen appearing. If you have more than one stick of RAM, turn the computer off, and remove the power cords and battery. Insert one old RAM stick, and cover the tower back up, replace the power cord or battery, and turn on your computer. Check to make sure it does not present you with the blue screen. One by one, reinsert the old RAM sticks into your computer, and test your computer for stability. Once you are presented with the black screen, remove the last old RAM stick that you inserted, and your screen problems are gone.
Nov 14, 2010 | Computers & Internet
I have hp dc7100sff desktop computer the prolem is that when i turn computer on the computer show me red light and give beep continous & not giving display...plz help me to solve this problem
please open the tower of the computer from the side and clean the RAM of the computer using a soft cloth and make sure no dust is present .Put the stick in the same way back and close the tower .
The problem should be resolved
Nov 11, 2010 | HP Compaq dc7100 PC Desktop
What is the trick to remove the tower cover to update the ram for pcv-rx 650?
you have to unscrew the back and slide it back then look where you see the ram and stick it in it only goes in one way if thats not right then check out this site it has everything on your computer http://esupport.sony.com/perl/model-documents.pl?mdl=PCVRX650
Dec 27, 2009 | Sony VAIO Digital Studio PCV-RX650 PC...
I have no monitor signal at all.
You most likely have RAM problems.
Try reseating the RAM module/s.
If it still doesn't work, the RAM may be faulty, test the RAM in another computer or take it to your friendly computer shop to test them.
May 10, 2009 | HP Pavilion a1710n (RK573AA#ABA) PC...
I want to expand the RAM in my Gateway 500SE computer
GATEWAY 500SE Computer Case Cover Removal before installing RAM
  1. Turn off the computer and then disconnect the power cord.
  2. On the rear of the computer, remove the three screws that secure the cover on the case.
  3. Slide the cover back about one-half inch, and then lift it from the case.
  4. Search for a small scale like card in motherboard similar to small scale as shown in figure in BANK A or BANK B.
  5. And place the another ram in free bank slot (RAM Slot).
  6. Make sure the locks are correctly locked to RAM at both sides.
  7. Close the cover
  8. Power On the System
  9. If any beep sound then switch of the system and reinsert the RAM module.
Hope this will be helpful
Thanks & Regards
Nandu
Mar 25, 2009 | Gateway 22929 Notebook
I want to add additional RAM to my Veriton 1000 PC where can I find a HowTo or Installation Guide ?
Here is the memory information on your system:
http://www.crucial.com/store/listparts.aspx?model=Veriton%201000
A total of 2 slots each capable of a 1 GB RAM module
Here is the user guide for the system:
http://www.acerpanam.com/synapse/data/7117/documents/VT1000_UG_ENG.pdf
Adding RAM is simple. Unplug all cables from the tower, then press and hold the power button on the front of the tower to release any stored power.
It appears that 1 screw holds the side panel on (it is on the back) and then removed the side panel. This should give you access to the RAM slots on the motherboard.
May 14, 2008 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
42 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
