Question about Optoma HD80 Projector
Optoma HD80 images are glared and blotchy, especially reds and skin tones in dim scenes. The reds turn to orange and the blotches/glares move with the image. We have had the projector for several years and this started happening recently. We have tried many of the settings, but none seem to fix it. Any thoughts on how to fix this?
3 Suggested Answers
vortash
  • 431 Answers
SOURCE: Lamp light is solid orange/red; No Image on screen when pj on
Sounds like bulb to me best way to check is take it to a service centere and they will use a replacement or test bulb to find out for you , it may not be your bulb it may be your ballast circuit . ... regards Vortash
Posted on May 10, 2009
SOURCE: blotchy colors on optoma hd80
i had, have the same problem i also replaced the bulb then shortly after the power went out no standby light or anything. From what i've read so far it seems like a power supply issue so i ordered two power supplys from optoma 1 for lamp 1 for the unit waiting on delivery from CA they were $ 99 each if this work i'll be one happy camper. Three years no problems it's a great machine with incredible picture using 106" screen
Posted on Jan 29, 2010
Optoma HD80 flashing blue lights
Sound like the original color wheel for Optoma HD80 is bad.
If the unit has been moved when hot.
If not, try un-plugging the unit for a few minutes and re-connect.
Hope this helps
Mar 23, 2014 | Optoma HD80 Projector
Red glare on screen and seems that paused script is burned into screen.
Hello
This is anormal fault to all flat panel tVs. If a still picture is paused for a long duration of time, itd image will seem to appear on the secreen even after that picture has been moved away from it. In some cases, this fault will be retified with time. There is no repair for this fault. Just input any plain white screen signal input to it, and let it be there for at least 15 minutes or so. If the fault has not been rectified by this, the screen may need repalcement.
As your set is almost new one, and will be within warranty period, just cusult to the service center for any remedy. Never tell them the cuse for this fault, as you have made it by yoursef (eventhough they knows the cuse). OK.
Nov 14, 2011 | Televison & Video
My Night Owl Cyclops NOCC3 night vision monocular wont pick up the infra red light properly so I can't view anything at night!!!! I haven't the lens cap off in light only when it's dark out and it won't...
Hello, is the IR glowing red, don't look into the IR lens. Just place your hand in front of it and see the is a red glare on your had. If there is a red glare then IR is work.
Another thing when you taking a look see through the Night owl NV monocular there should be a green glow from the image intensifier tube, if not, then the NV monucular isn't working properly. stewbison
Feb 21, 2011 | Night Owl Optics Cyclops Compact NOCC3...
Blotches on images especially images with a light background eg.
This is probably due to dust or other foreign matter on the CCD. Look at the Pentax *ist DL manual under "CCD cleaning" or "sensor cleaning" for instructions.
There is a "sensor cleaning" mode in the Set-up menu that will lock the mirror up so you can inspect/clean the CCD sensor.
Jul 10, 2010 | Pentax *ist DL Digital Camera
The lamp of my optoma hd80 shut down after 20 minutes. The lamp indicator problem light on. My lamp as only 880 hours. Do i have to change the lamp now?
Hi Pierre,
Did you resolve this issue. I am facing a similar on. After a few minutes, the lamp shut down and the the red lamp light turns on. I was thinking it is an overheating issue.
Regards
Ludovic
Mar 25, 2010 | Optoma HD80 Projector
Blotchy colors on optoma hd80
Dec 22, 2009 | Optoma HD80 Projector
Optoma projector HD806
its not the color wheel. Its the sensor that counts the black tape on the color wheel. The sensor has dust on it. It can't count how many times the wheel is going around because the dust is blocking it. the sensor is located by the wheel. if you have any questions you can callme 610-842-7442 ask for dan.
Dec 01, 2009 | Optoma hd806 DLP Projector
Glare on my windshield
Yes dim the light panel. Their should be a small knob somewhere on the dash on the left of the steering wheel that you turn to increase or decrease the brightness of the instrument panel.
May 27, 2009 | 2007 Toyota Prius
"Sunshine" Glare on faces and other bright areas
Hi there
What make and model is this Projector ?
Mar 23, 2008 | Optoma H56 Multimedia Projector
Magnavox Projection
What is model number? A magnavox 51MP392 is a CRT rear projection type and doesn't use a bulb (unless he was refering to the CRT's as bulb). And they are prohibitively expensive.
Jan 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
Optoma HD80 Projector Logo
165 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
