Question about 2-Way Remote Starter
Doors will lock and unlock from remote but, car will not start.
I have a cool start RS900ER/RS901 series 111 I can lock and unlock all my doors but when I try to start the vehicle it will not start, Yhe lights blink when I hit the start button but, no response.
  • Keith Methot
    Keith Methot May 11, 2010
    How many times do the lights blink??
3 Suggested Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
emo-of-death
  • 9 Answers
SOURCE: remote wont make truck start?
ok this happend to me once take the key and stick it into the ignition and turn it 8 times only turn it untill the lights go on DO NOT START THE ENGINE EACH TIME after this try it again
Posted on Jan 06, 2009
SOURCE: crimestopper keyless entry remote wont unlock or lock anymore changed battery still wont work
need to program a new remote to keyless entry system it is crimestoppper cs835 rke
Posted on Dec 16, 2009
Remote start work but door will not unlock or lock!
Do the doors unlock when the remote starter is not running? If so, then you to connect to a different set of door lock wires.I usually connect to the factory alarm and disarm wires in the driver kick panel. They are blue for arm and pink for disarm. You test them by turning the key in the drivers door.
Aug 18, 2012 | 991 Responder LC3 SST Security/Remote...
2008 bmw 328i car locks are not unlocking either by remote or by manual car unlock button
At first,it seems your remote has lost its code.Try using your other keys.
Do you have all doors+hood properly closed?Does your key actually turn in door lock!
Mar 13, 2011 | 2000 BMW 3 Series
Central Locking does not work
You must reset your remote control in order for the lock/unlock to work properly.
To reset remote you would:
1)Insert Key in Ignition Turn to Position 1(Don't Start the Engine) for about 5 seconds
2)Turn Key Off and HOLD the LOCK button on Remote while pressing the UNLOCK 3 TIMES
3)Release both lock and unlock buttons you are holding
4)All doors should automatically unlock
And exit the door and lock with the Remote.
Sep 19, 2009 | 2000 BMW 3 Series
My valet remote control RPN491 Starts vehiclr and unlocks doors but will not lock doors do I need to reprogram remoteto unlock doors?
Ok you said "unlock doors' but you said it already unlocks the doors. This remote should lock and unlock door on same button, if you are describing the 2 button remote. If it is not then it could be alot of things. Does the alarm lock itself? Does the alarm lock the door when you turn on the ignition? More info is really needed. Like what veh and what model alarm.
Sep 11, 2009 | DEI Valet Keyless Entry System
Step by step reset the door remote control lexus 400LS
1. sitting in driver seat, with driver's door OPEN, press lock/unlock button ON THE DRIVERS DOOR to lock all doors, then manually unlock driver door only.
2. Insert YOUR key in ignition, DO NOT TURN, then remove key.
3. Using the same lock/unlock button ON THE DRIVERS DOOR, slowly press lock-unlock in 5 cycles
4. Shut door.
5. Open door.
6. Using the same lock/unlock button ON THE DRIVERS DOOR, again slowly press lock-unlock in 5 cycles
7. With the door open insert your key into the ignition, turn to 'on' position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once by herself). If they don't cycle or they cycle more than once, do steps 1-7 over.
9. Now using the remote, push lock button, hold for one second, then release the button. The locks should cycle once. If not, start over and go slower.
10. Close the door.
11. Open the door.
12. Press the lock button on the remote. The locks should do a lock-unlock cycle.
13. Close the door
14. Press the lock button on the remote, the doors should lock.
15. Press unlock button and the doors should unlock.
Jun 16, 2009 | 1996 Lexus LS 400
Need the steps to programme the remote
Remote Programming Instructions
1. Driver's door OPEN and unlocked, all other doors closed and locked.
2. Insert YOUR key in ignition, DO NOT TURN, remove key.
3. Using the MANUAL lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
4. Shut door.
5. Open door.
6. Using the lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
7. With the door open insert your key into the ignition, turn to on position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once). If they don't cycle or they cycle more than once, do steps 1-7 over.
release. The locks should cycle once. If not, start over and go slower.
10. Close the door. Open the door. Press the lock button on the remote. The locks should cycle. Close the door. Press the lock button on the remote, the doors should lock. Press again and the doors should unlock.
Jun 02, 2009 | 1995 Lexus LS 400
Programming keyless remote
2003-04 Mazda 6 REMOTE PROGRAMMING
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the driver’s door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the driver’s door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) twice. Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
Good Luck.
Jul 12, 2008 | 2003 Mazda Mazda6
Keyless entry remote
Try this, it works on several 2002 models:
Step 2: Lock and unlock the drivers door using the power door lock switch on the door.
Step 5: Open and close the drivers door 3 times. (Door should be left open after this step).
Step 7: Press any button on remote #1. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) Each time the ECU will respond by locking & unlocking the doors.
Jun 20, 2008 | 2002 Mazda Protege
2-Way Remote Starter Logo
150 people viewed this question
Top Crime Stopper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
John
John
Frank Mangiapane
Level 1 Expert
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
