Question about Whirlpool Washing Machines
In the begining of was the water won't stop filling, it overflows and it won't go to the wash cycle (adjetate) however I can turn it to the rinse cycle and it will drained and spins?
  • Whirlpool Master
  • 17,130 Answers
Possible that the water level sensor has failed.Shut down washer and trace the sensor which is a pressure activated switch from the drum overflow. the switch can be activated by blowing and checking continuity. if so replace the unit
Posted on Dec 31, 2012
  • jayne hurford
    jayne hurford Mar 27, 2014
    will give this a go but its complicated
    Scholar:
  • 49 Answers
Water level is controlled by what is called a "pressure switch" -- Based on the dial setting you select for small, medium, or large loads the switch is electronically set to engage at different pressures to start the wash cycle. The most common reason for water continuing to fill and overflow is an obstruction in the tubing that runs from the load size selector switch to the pressure switch or from the pressure switch to the drum. The pressure switch itself rarely goes bad, the load size selector switch is a more common issue.
It takes a bit of doing to get at these parts... start at the load size selector switch. Obviously that is located in the control panel of your washer and is the switch you physically turn to selct the load size. I assume if your trying to fix this yourself that you can use common sense on how to remove the head unit or control panel to access the switch, the process will differ based on your brand or model of washing machine...
Once your looking at the load selector switch you'll want to remove the plastic tube and blow into it, then suck on it like a straw, then blow again. You'll hear the pressure switch click and feel resistance. Now you can put the tube back on, start your machine and monitor to see if it stops filling and start agitating properly, just doing that will work many times because the obstruction is caused only by grease.
If that did not work, you'll want to get at the pressure switch itself, which will require pulling the machine out and taking off the back panel of your machine. Follow the tubing down from the load selector switch to the pressure switch and remove the tubes there, you'll likely find and obstruction in the tubing... usually thick grease or lint. Now reassemble and try again, use the small load setting, water should stop filling by itself and the wash cycle should start.
If your machine still wants to overflow, the last thing I would try is replacing the load size selector switch itself. It can be tested with a multimeter, but since we have eliminated the other 2 most common causes of overflowing at the beginning of a wash cycle, I would simply obtain the part and swap it out.
Hope that helps!
Posted on Nov 13, 2014
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 31 Answers
Check to see if the pressure hose is clogged, kinked, or cracked. if not i would replace the pressure switch.
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
Illeagle
  • 525 Answers
SOURCE: Washing Machine won't stop filling up
Try resetting your water level control. If that doesn't help then set the water level control to the lowest setting and observe if level exceeds that setting. If so, you may possibly have a faulty water level control, or an obstruction in the air dome or water level control hose. This can be a tricky 1 to diagnose for a novice.
Posted on May 24, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
megarza
  • 88 Answers
SOURCE: older maytag wahser water level and agitate cycle
you need to replace the water level switch
Posted on Sep 23, 2009
marka19
  • 1430 Answers
SOURCE: Kenmore Heavy Duty 80 Series Extra Capacity Plus
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Posted on Oct 30, 2010
Testimonial: "I had already figured this out before viewing this message. I found that the pressure hose had fallen off of the water level pressure switch."
My samsung top loader washing machine sw65v9w won't stop filling with water
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
Nov 04, 2012 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Won't stop filling up. Water continues to flow without stopping for cycles
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps.
Gene
Aug 28, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a GE washer that during the spin cycle / rinse on my washer the water won't shut off and will run and run until I turn the water valve off. This occurs during spin cycle when it adds water but...
water valve or water presher switch my vote is water valve start washer when water is filling unplug from wall if water is still running it is the water valve if water stops it has to do with presser switch let me know what happens I will walk you threw how to repair thanks
Jun 24, 2011 | GE WPGT9360EPL Top Load Washer
Item: Whirlpool Ultra Dishwasher Age: 3 yrs Problem: Not enough water to effectively wash the dishes. State: When the dishwasher is started, the fill valve opens as normal. Only about 1/2 the amount of...
Larry,
The float is generally for overflow conditions and will interrupt power to the fill valve solenoid.
If you are not filling completely in the time allowed by the timer, it is most likely a flow restriction in the water supply. Barring other obvious restrictions, the fill valve has filter screens on the inlet side of the fill valve, which is generally the cause of your symptoms. Be careful if you attempt to clean the screens, as the fill valves are very sensitive to debris, and can become stuck open if sediment gets past the screen. I usually replace the fill valve to avoid future problems.
Hope this helps.
Oct 30, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Washing machine filling
turn the power off if the water stops it most likley a pressure switch problem or the pressure tube on the side of the outer tank may have pulled off.if you turn the power off and the water doesnt stop then the valve is faulty (cold)if it was on the rinse.hope this helps.
Mar 17, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
226 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
