Question about Sony Ericsson W300 Cellular Phone
My memory card is inserted, but its telling me its not!
When i go to the file manager, click more and then go to format M.S it tells me that there is no memory card inserted. And when i go to the memory stick option in the file manager it also tells me that there is no memery card inserted.
  • 425 Answers
First is try checking its memory terminals maybe their something blocking it or you inserted it in a wrong position.
or try restoring your phone to its factory settings...
 if still nothing happens maybe you have a defective memory card. or to be sure try using other memory card, if still cannot read it theirs a prob in your memory slot internally....
hope you solve it...
Posted on Oct 19, 2007
"Please format your pendrive"
you can try some data recovery software. You can see
Recover Files from USB Drive
It tells steps to perform USB drive recovery.
If above does not work, you may have to format the memory card (use quick format), and then use this pen drive recovery software called asoftech data recovery to scan again the memory card and recover your files.
Sep 10, 2012 | Electronics - Others
My microSD card memory is a not formating accept and not deleting old files.
HI there,
It seems that your memory card is infected with the virus which restricts you from formatting,
To Format the memory card:
Take out the card from the cellphone, Insert your memory card in the card Reader, (External more preferably or internal memory card if you are using laptop),
When window recognize that memory card is inserted , Just hit cancel and do not open your Memory card.
Right click on my computer and select Manage Then Select Disk Management it will show you the list of installed Hard Drive, DVD , and memory cards, right click and select your memory card (On the left size you can see the size of the memory card) and select Format, a pop up screen will come and you can select format options. Select Perform a Quick Format. and then click OK, it will format your memory card, and all the data will be erased from the memory card,
Caution: Always select the right partition in Disk Management for formatting to avoid any possible data loss,
If you require more assistance, feel free to reply to this post
Regards-BA
Jan 16, 2011 | SanDisk 2GB microSD Memory Card
I forgot my password of memorycard so please tell me how can i unlock my memory card?
There is a application named FExplorer by installing this in your mobile you will be able to get the password of it .
The FExplorer installs on the symbian OS Mobile only
Please refer the following link
http://www.mobiletipstricks.com/how-to-unlock-or-hack-memory-card-when-you-forgot-your-memory-card-password/
Nov 02, 2010 | Nokia 5310 Cellular Phone
I have nokia n73. there is a problem in its use. whenever i use it , it gives the message of memory full and asks me to delete some data. please tell me some solution.
The phone's internal memory and memory card may be running out of space. Try to delete unnecessary files and free some memory space. Go to Menu>Tools>File Manager. Select the folder or file you want to delete and scroll left or right to switch from the phone's internal memory to the memory card.
Format the memory card and the phone's internal memory if the problem is not resolved above. But it will erase all saved data on both memory.
Memory Card Formatting Procedure
  1. Go to MENU > TOOLS > MEMORY.
  2. On the memory card menu press OPTIONS.
  3. Scroll to Format memory card.
  4. Press Select.
  5. Select Yes
  6. Once the formatting is complete, remove the memory card.
Phone Memory Formatting Procedure
  1. On your phone dial *#7370#.
  2. Press Yes then enter your phone lock code. Default code is 12345.
  3. Formatting is complete when the phone restarts. Insert the memory card and format it again.
Jan 15, 2010 | Nokia N73 Cellular Phone
Memory card micro sd cannot format
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Mar 11, 2009 | Samsung Eternity Cell Phone
    My cell phone memory card is soe problem .memory card says format
    firsrt u go to file manager and click the memory card click the options last one is format option u select click the ok button
    Jan 11, 2009 | Nokia N72 Cellular Phone
    Memory Stick PRO Duo is write protected
    I had this problem and figured out a easy fix.
    1. Take out memory stick from psp
    2. Plug in usb to psp and start usb connection
    3. Psp will recongnize there is no memory stick inserted
    4. Now insert your memory stick and your good to go
    For some reason you might have to repeat these steps everytime you want to access your memory stick.
    Hope This Helps
    Dec 23, 2008 | Sony 4GB Memory Stick PRO Duo Memory Card
    How to format sony ericcsion z550i memory card
    Connect the phone to your computer using a usb cable or card reader.. If you connect the phone there will be 2 extra drives in my computer. Right click on the memory card and click on format. Also choose the FAT32 file system while formatting it is more reilable. If you want to do this from a card reader a new USB drive will be shown in my computer. Right-click and format.
    Sep 11, 2008 | Sony Ericsson Z550i Cellular Phone
    Ols help
    There is a solution, put your memory card in the card reader. Then right click "My Computer" Click "Manage" Go to Disk Manager and format it. Later you can recover your data by Any USB data recovery software.
    Nov 01, 2007 | Nokia 6630 Cellular Phone
    MMc Mobile Memory card
    try by restoring ur handset and formating ur memory card once...
    Oct 30, 2007 | Nokia 6630 Cellular Phone
    Sony Ericsson W300 Cellular Phone Logo
    76 people viewed this question
    Top Sony Ericsson Cell Phones Experts
    Computer Repairing
    Computer Repairing
    270rexton
    270rexton
    Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
