Question about IBM TotalStorage Networking Switch
I`m forget password admin to login on my san brocade 2005-h16
I had change default password admin on brocade 2005-h16
Did you find the recovery procedure of 2005-h16. please send it to hillanes@datec.com.bo
Posted on Jul 22, 2009
  • 50 Answers
Hi
Please find the link to get default password
http://www.anameless.com/blog/default-passwords.html
Good Luck
Posted on Jan 18, 2009
What is the default username and password?
user name: Admin
Password: admin
user name: Admin
Password: blank
user name: 1234
Password: 1234
Sep 17, 2014 | Computers & Internet
Tip
Forgot my password.
If you ever forget your password to your router you can look up the default password online.
Most default passwords for linksys is: login=blank password=admin
Default passwords for belkin is: blank
Default passwords for netgear: login=admin password=password
Default passwords for d-link: login=admin password=1234 or password.
if none of the passwords work then you can reset the router to factory defaults by holding the reset button in with a paperclip for 30 seconds while powered on. This will erase any customized settings and apply the factory default settings. If the password doesn't work please check with your device manual.
on Feb 23, 2012 | Linksys Computers & Internet
How do i set a password
Setting the router's administrator password
All Belkin Router's ship without an admin password. If you require an admin password then follow the below instructions.
Setup steps:
  1. Connect the computer to one of the four LAN ports on the router.
  2. Open a web browser on the computer.
  3. In the address bar of the web browser, type http://192.168.2.1
  4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  5. Click on System Settings under Utilities on the left-hand side of the opened page.
  6. You will see a feature called, "Administrator Password". Type in your current password (default leave blank).
  7. Click "Apply Changes". Your new password is now active.
Note: Do not forget the new password and keep it somewhere safe. If you forget your password, you'll be unable to access your router's settings. If you forget or lose your password, you'll need to "Perform a hardware reset on the router". This will reset the password to its default, as well as erase any and all other settings you may have changed.
Aug 12, 2011 | Belkin Computers & Internet
Forget Password and admin, when I login on website
If you reset your router normally by holding in the reset button for 10sec , it will go back to the default password and admin . Sometimes the default password and admin is stored at the bottom of the router. the username and password for this model is admin
i have supplied you the manual for this model below:
http://www.engeniustech.com/resources/ESR-1221_EXT_User_Manual.pdf
May 09, 2011 | EnGenius ESR-1221 EXT Router
How will i change my password
First: Navigate to the router's web admin page by going to it's IP address, this is usually 192.168.1.1, but you can look it up in your computer's network settings. The IP address of your router is called the "Default Gateway". If the Default Gateway is not 192.168.1.1, use what is there.
After you get to the web admin page, use the current admin username and password to login. If you don't know it, try the default, usually admin/admin or admin/password. Once you're in the router, you can change the settings as you wish.
Hope this helps and feel free to ask questions if need more help!
Mar 30, 2011 | Computers & Internet
I need to change my password on my router
Setup steps:
Note: Do not forget the new password and keep it somewhere safe. If you forget your password, you'll be unable to access your router's settings. If you forget or lose your password, you'll need to "restore to factory default". This will reset the password to its default, as well as erase any and all other settings you may have changed.
Dec 19, 2010 | Belkin (F5D5231-4) Router
Somebody cn tell D-Link DIR-600 login password
Welcome to FixYa
Dear User,
Default User name :Admin
Password : admin
Your Product manual also Here..Dont forget to RATE..
Thanks for Connecting FixYa...
Aug 20, 2010 | D-Link DIR-600 Router
I forget my sonicwall admin password how will reset this password
If the SonicWALL's admin password is lost, there is no backdoor or other mechanism to bypass the administrator login. Please note that prefs files do not contain the admin name and password. So if you reset the firmware and import a current prefs file, you can gain access using the default login credentials ('admin' & 'password'). Without a current prefs file, you must reset the firmware and configure from scratch.
For models running SonicOS (Enhanced or Standard), you can reboot to factory defaults. This resets all settings including the admin name, password and LAN IP address. Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login.
For models running Firmware 6.X, you must reset the firmware (wipe and upload using the reset procedure). Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login. The 'Reset to Factory Defaults' button does not reset the admin name, password or LAN IP address for these models
Feb 03, 2010 | SonicWALL PRO 1260 SonicOS Enhanced...
I don't remember how to login to my linksys configuration
Hello
I am not sure the IP you put in the message is the right one. Assuming that you are still using the default settings, the IP is 192.168.1.1
open internet explorer or your default browser and type: http://192.168.1.1
and you shoulfd see the login page and if you forget the default login try
user: admin
password: {blank} nothing
or
user: {blank}
password: admin
Apr 13, 2009 | Linksys Wireless-G WRT54G Router
Reset the IBM 2109-F16 SAN switch to factory settings
Were you able to find an answer to this? I have the same issue...
Oct 17, 2007 | Computers & Internet
IBM TotalStorage Networking Switch Logo
1,242 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
