Question about Honeywell Electronics - Others
Thermostat does not show temperature and stopped working. but it does turn fan on
No temperature readout, no ac or heat. But fan operates in fan selection but not on automatic
SOURCE: heater control wont heat. AC and fan works fine
The heater core was plugged and took 8 flushes to clean it . Would clean it would stop again. Have heat now .
Thank you everyone for helping.
Posted on Sep 20, 2008
  • 2692 Answers
SOURCE: Heater only blows cold air
Yes,it rules it out. The valve leading the water into the heater core is not opening or the door that put the air past or through the heater core is closed. This is general information not specific to your particular model.
Posted on Dec 18, 2008
co7196
  • 3433 Answers
SOURCE: Dometic AC that the fan shuts off but the compressor keeps running
call dometic dealer. I hear they have a bad circuit board that is replaced.
Posted on Jun 02, 2009
SOURCE: 1992 SEDAN DE VILLE CAD...AC BLOWER MOTOR FAN HAS
Since replacing anything could cost hundreds of dollors, would you really replace it from a suggestion or would you prefer to get it diagnosed properly. It gets expensive when you just throw parts at a car. This really need to be diagnosed properly ( hands on with the proper equipment).
Posted on Aug 30, 2009
Testimonial: "thank you"
bargainbin2
  • 123 Answers
SOURCE: 99 saturn no heat or defrost
Sounds like your heater core is mostly stopped up. You need to have your cooling system back flushed and cleaned.
Posted on Sep 12, 2009
I have a Rheem Classic Super Quiet 80 gas furnace (for heat). The fan stops when the "heat" turns on.
Any time I ever had trouble,first thing to suspect is the thermostat.
They lose contact sometimes and sometimes you tap the face and they work til next glitch.
If the thermostat has some years on it,go ahead and replace it.
Can't you just leave the heat and fan in auto? That would be best,I think. don-ohio
Jan 10, 2017 | Heating & Cooling
Would a closed thermostat stop the radiator fan from turning on when the temperature is within heat range.it turns on when I turn ac on,is that a different cause when not using ac.
There are two different thermostats--one in the cooling system, and one just to turn on fans. The AC has a separate circuit to turn on fans regardless of engine temp, so tind the the fan thermostat and test it.
Jul 03, 2016 | AC Cars & Trucks
My coolent fan turns off then car runs hot
I would check my relay's and or your fuses first. If thats not it, let it cool down and take it to Auto Zone or somewhere close to have a diagnostic readout done. Good luck.
Jul 29, 2014 | 2000 Ford Crown Victoria
Why has my air conditioning stopped blowing cold air , engine light come on and coolant readout (in the driver info. center)a stopped showing any numbers
If your check engine light is on you usually have a code. Where I live several auto part stores will read the code for free. It would help to have a code.
If you have 2 fans on the radiator one should come on when you turn the A/C on. The other fan come on when engine reaches engine operating temperature. You have relay for compressor and the fan motor. Does the inside fan stop blowing. If a fuse was blown they should not work at all but a relay could drop out and in. I have found a bad relay over the years by checking the temperature of the relays, it is not always the case.. I have had a couple relays which were a lot hotter than the others, helped identify the bad relay. you can get the relay checked at the auto parts store. The low pressure switch could be creating problems with low Freon pressure. some info fuse relay below.
http://www.autogenius.info/chevrolet-cobalt-2005-2010-fuse-box-diagram/
Aug 06, 2017 | Chevrolet Cobalt Cars & Trucks
Mystery message "wait" appears above "following schedule" display line on our Th8000. Ac does not come on even when temperature is in range. Fan operates ok. Is "wait" setting one I can reset? Maybe a...
Mystery message "wait" appears above "following schedule" display line on our Th8000. Ac does not come on even when temperature is in range. Fan operates ok. Is "wait" setting one I can reset? Maybe a compressor issue rather than thermostat? Thanks
Jun 21, 2010 | Honeywell Electronic Programmable...
We have the white and rodgers thermostat model 1F81-261. The problem is that the ac unit will not work. We have reset and changed the batteries and set the point 4 degrees less than the actual room...
Set System Switch to Cool and lower setpoint below room temperature.
Verify thermostat and system wires are securely attached.
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating system is operating correctly.
Reset the thermostat by pressing , UP,DOWN and TIME at the same time.
Jun 28, 2010 | White Rodgers White-Rodgers 1F85RF-275...
The high limit thermal switch on heater burns out.
There are two thermostats, a 'limit' or 'operating' thermostat which turns the heating element on and off, and a 'high limit' or 'safety' thermostat which oversees the 'operating' thermostat by opening and removing power to the heating element when the upper limit temperature is reached. Basically, the only difference between these two are the temperature ratings. The 'high limit' is higher than the 'operating' thermostat. The thermal fuse is the last resort protection.
First and foremost, you must know that every inch of your exhaust vent pipe is clean.
Usually, a bimetallic limit switch will degenerate in the direction of too low of a temperature range because as the parts wear out inside, the mechanical tolerance widens (the tiny rod that pushes the contacts together gets shorter).
The high limit thermostat is by the thermal fuse. The operating thermostat is in the blower housing.
Check the fan impeller for broken vanes and lint. The impeller is directly coupled to the motor and should not turn without the motor. The fan housing and ducting should be free of excess lint.
Good luck.
May 02, 2010 | Samsung DV316LES Electric Dryer
2000 jeep grand charokee laredo over-heating
have you changed the thermostat? is your fan kicking on? if your fan is not kicking on you need a temperature sensor.
Aug 17, 2009 | 2000 Jeep Grand Cherokee
Robertshaw 9600: Temperature rises too high, fan doesn't stop.
It sounds like the thermostat is wired improperly. One quick was to check is by finding breaker to unit and shutting off power. Go to thermostat and remove from wall take all wires off thermostat besides wire going to R(might be RcandRh) and C(which is common) Tape all bare wires removed with electrical tape. Now go back to the breaker and turn power back on. Nothing should be running at all. Take a voltage meter and measure the voltage from R to W(which is heating). If you read 24V then the thermostat is open and not calling for heat. Now turn the thermostat up so it is calling for heat. You should read 0V from R to W. If this checks out your thermostat is probally fine. You can check the fan the same way by going from R to G. In auto you shoul read 24V from R to G and in th on postion you will read 0V from R to G. If the thermostat checks out then the problem is probably at the furnace or rooftop. Either with the thermostat wiring or the main board acting up
Jan 19, 2009 | Heating & Cooling
I have a trane thermostat and I need help programming it
If indeed the program is stopping it you can find out by putting the thermostat temp on a manual hold. Set tstat to a desired temperature then push hold. If all works well then you will need to reset your program to fill your needs
Oct 13, 2008 | Hunter Fan Company 5/1/1 Programmable...
Electronics - Others Logo
32 people viewed this question
Top Honeywell Electronics - Others Experts
Are you a Honeywell Electronics - Other Expert? Answer questions, earn points and help others
