Question about GPS
Where is the pilot light for the efel model 491.64 propane vented room heater?
Hi. We just moved to NH and the house has a propane heater in the basement. I've never used propane and have no idea where the pilot light is located. We've looked over the heater and the instructions 'imply' a level of knowledge on the various components that we don't have. I would appreciate some clear direction, if possible.
SOURCE: Empire Wall Heater(propane) won't stay lit
John Mac here...the solution was that we had shut the pilot off for the summer, and birds had made a nest inside the heat exchanger...coming in through the direct vent. Cleaned out the nest, and it works perfectly. My technician recommends that I leave the pilot buring through the summer to prevent this in the future.
Posted on Aug 30, 2007
SOURCE: Stadt Ducted Heater ignition problems
Could be a number of things
Sounds like it the gas valve. If the gas Valve isn't opening or is burnt out then no gas will flow through it.
Also it the pilot is blocked then you wont get and gas coming through to light it up.
I am forever replacing gas valves on the buffalo series units and have found this to be quite a common problem on older units.
Posted on Aug 21, 2008
SOURCE: Pilot light keeps going out
Dan, Since you just had the tank filled and the heatewr installed a tinty piece of trash could have entered the pilot orfice. Un do the lower floor panel take off the pilot assy. Blow out the small pilot orfice. Blow reverse from normal gas flow to unlodge the debre. Re asemble and light.
If this dosen't work It may be the pilot air intake is too open causing the pilot to blow itself out.If thats the case close off the air adjustment some. It will be located behind where the flame exits the pilot orfice.
ljtomega
Posted on Dec 03, 2008
SOURCE: Comfort Glow Vent-free Gas Heater CGN18B
Check with Ebay seller s.a.w.inc for available thermocouples. If that doesn't solve the problem the valve unit will likely need replaced.
Posted on Feb 13, 2009
  • 139 Answers
SOURCE: Have Model CGP30TB Copmfort Glow propane
sounds like an obstruction in pilot assembly.try using canned compressed air to blow directly into pilot. this technique is successful about 70%. if not,pilot assembly must be removed and cleaned thorougly
Posted on Sep 16, 2009
Pilot light wont light will spark, but no propane
verify the inlet pressure to the heater. those pezioelectric spark lighters are garbage. make sure all manual shut off valves to the heater are open. Pilot tubing may also be blocked
Nov 25, 2013 | Glo-warm 503284 30000 BTU Propane Gas Vent...
Pilot won't stay lit on mr heater vent-free propane heater
if it is direct vent chances are it has electronic pilot.. it does not have a standing pilo and match size upt. if in fact it did have a buning pilot there is a part called thermocoupling. it will look like a 1/8 in. copper wire coming out of the bottom of the gas valve and goes right to the pilot. anywhere from 10 in. to 20in.. unscreew nut at gas valve pull out from pilot area [ it just clips in at pilot] take it to any home center
Nov 25, 2012 | Kitchen Ranges
I have a 50 gallon rheem direct vent natural gas heater. The pilot light goes out on an infrequent but aggravating basis. I replaced the thermocouple one time and it got better for about a year but has...
Open following links for pilot light help:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/images/Negative-pressure.jpg
http://waterheatertimer.org/pdf/Bosch_Ventilating_tight_houses.pdf
Since pilot light goes out and can be re-lit, problem is probably not thermocouple, gas control valve, or air in gas line. But these things can factor in as contributing factors.
Problem is likely one of following or combination of following including dirty burner parts, tight house, incorrect vent lengths, negative pressure caused by other venting appliances, condensation dripping down into combustion area, and inadequate oxygen supply due to hot or closed-off room or attic location.
Gas water heaters draw air from surrounding area. If water heater is located inside house, then air has to enter home through cracks and when doors and windows are opened. Other gas appliances and vent fans also draw air from same indoor area. When other vent fans turn on, air can be drawn down the water heater vent and blow out pilot light.
Inspect combustion chamber to make sure there is no condensate water dripping down from incorrect vent that is putting out flame. If combustion chamber is dry, then close doors and windows. Turn on all vent fans and gas appliances that vent outdoors, and see if water heater pilot goes out.
Consult with plumber or product manual about proper horizontal and vertical lengths of vent pipe for your model. Have plumber clean combustion parts and inspect vent termination and check gas pressure and bleed gas line.
Add louver opening to outdoors so air can enter room where water heater is located.
Aug 05, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Propane heater produces fumes in very cold weather
Hi it sounds like the tank was so cold that the gas inside the tank could not vaopour off fast enough to burn ,
Or your line could be blocked with mercaptan which is what they put in to the gas , it will be a brown liquid that will stink very bad stink very hard to get rid ot the smell, the liquid if in there would move up and down the pipe if full or there may be a drip pocket you can undo on the gas line but this will stink . hope this helps
Mar 05, 2010 | Heating & Cooling
Have Model CGP30TB Copmfort Glow propane heater. Pilot light won't stay lit. Flames also coming from what seem to be air vents just below flame on pilot light.
Sep 10, 2009 | Desa International Comfort Glow Infrared...
Pilot and Burner shut off at same time at various run times.
sounds like your pilot saftey is working.the pilot flame heats a device called a thermacoupler which gives a signal to the gas valve letting it know its ok to open main valve. you may need a new thermacouple , might have a dirty pilot orfice or a problem with gas pressure or worse case a cracked heat exchanger in any case in less you have some type of training you should call a pro
Feb 05, 2009 | Coleman Propane Forced Air Heater...
The pilot won't light up
Hi Welcome to fixit.com
Make sure the gas/propane is on and or working elsewhere in the house. If the piolet wont light ....and its a standing flame piolet ....its the thermocouple gone bad. Please rember to leave me some positive feedback ! Thanks !
Dec 16, 2008 | Bosch AquaStar Indoor Natural Gas Tankless...
Delayed lighting
It sounds like the orifice is missing or is the wrong type (LP) on the back burner.
Dec 20, 2007 | Procom 10K BTU, Vent Free, 2 Plaque...
GPS Logo
56 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
