Question about Optics
How do you disassemble the bolt of a mossberg bolt action 817?
I just need to take apart the bolt so I can oil it
4 Suggested Answers
bigcass
  • 35 Answers
SOURCE: need to find out how much a 185 KA mossberg bolt
$50-$150 Good to Mint Condition.
This is based on info found in "Blue Book of Gun Values".
Posted on Oct 16, 2009
agent91
  • 2100 Answers
SOURCE: i am trying to find extra magazines for my
Gunparts.com has the mags, the scope parts, I don't know, you would have better luck finding an old scope for the parts.
Posted on Feb 13, 2010
  • 679 Answers
SOURCE: looking to buy 5 shot mags 595/695 bolt action
You can check this website http://www.gun-parts.com/mossberg/ Most of my friends buy their gun parts and accessories here. thanks
Posted on Jan 11, 2011
30-06 trigger won't pull Mossberg
Is it an semi auto or bolt action could be the safety is not all the way released if the semi is open any at all it will not fire and the same for a bolt action the bolt has to be all the way down hope this helps Merry Christmas
Dec 10, 2017 | Mossberg Optics
Dismal mossberg 85 bolt
Like most bolt action bolts, you have to relieve the spring pressure. That means you need to pull back on the cocking knob on the back of the bolt. The bolt head will come off easily then. The bolt has to be in the exact same condition it's in when you **** the gun. Reverse to reassemble.
May 12, 2016 | Mossberg Optics
How doI disassemble a Mossberg 9200 semi-auto to clean it?
I wouldn't take it apart per-say. use some gun scrubber or brake cleaner. Be careful with the stock and take it off if the solvent would damage the finish.
Mar 24, 2015 | Mossberg Optics
What do I need to mount a scope on a Mossberg bolt action rifle
You'll need scope mounts to fit that MODEL of Mossberg rifle and a set of rings that attaches the scope to the mounts.
Feb 18, 2015 | Mossberg Optics
Disassemble bolt on bolt action shotgun
Pretty much all bolt action bolts work the same. You need to relieve the spring force. That means pulling back on the cocking knob. The head will come off easily then. You need to have the bolt in the exact condition it's in when cocked, cocking knob back, to disassemble it. Reverse that to reassemble.
Apr 21, 2014 | Mossberg Optics
Mossberg 817 magazine
Not much can go wrong. Have you checked your extractor? If it's intact and not broken, try moving it with your thumbnail. Is it loose? That's a spring problem. If it's tight and intact, WITH THE BOLT OUT, try slipping a small diam wooden dowel down the barrel to see how hard it is to push a spent shell out. If it's tight, you've got a burr in the chamber or dirt/varnish buildup. Examine the shell for scratches. If the shell's good and no scratches, clean the chamber with a brass brush mounted in a drill.
HOW DO YOU DISASSEMBLE A MOSSBERG 20 GAUGE BANTUM
Same as all Model 500's. Bolt halfway open, remove barrel, remove trigger group pin, trigger group, both shell stops, bolt carrier, bolt, lifter. Reverse to reassemble. Seriously, head to youtube and watch a video. You can go step by step with the video. The only key spot you need to watch out for is the bolt/bolt carrier when you take it apart and put it back together. The carrier will just ever so slightly clear the front of the inner rail on the receiver....and when you out it back together, put the bolt into that spot, put the forearm back on so the action bars are down next to the bolt, and then drop the bolt carrier back in to link the bolt and action bars back together. Once the cvarrier is in that perfect spot, it'll drop right into the slots. Just slide it a hair forward so the rails slightly block it in and then do the stops. Next key spot....and this is one a lot of folks mess up so don't feel bad. You aren't alone. The pins in the trigger group have to be centered all the way to get the trigger group in right. Use your fingers to center them on both sides, slip the front edges into the trigger group hole to catch the two front tabs, and then GENTLY lower the group in and pin it. DO NOT FORCE IT IN!!! Those tabs break.
Apr 19, 2013 | Mossberg Optics
Mossberg 500, shell will not eject
did you check the elevator to make sure its not applying the pressure on the cartridge interrupter and cartridge stop? or that one or both aren't damaged and over bent. the ejector slot on the bolt isn't damaged, or the action slide bars.
Dec 28, 2012 | Mossberg 500 AllPurpose Field Shotgun 20...
I took out the bolt to clean it and now can't get it back in. It goes part way.
Not real sure which model you have, one named is a semi-auto, the other is a bolt action. So if you have a bolt action, to reinstall the bolt you have to have the safety off, pull the trigger as you insert the bolt back in place (be sure it is unloaded and pointed in a safe direction). If for some reason the bolt has un-cocked you must first **** the bolt. some models have the firing mech. in the bolt.
Jan 04, 2011 | Mossberg Marlin Rifle 992m,989,mossberg...
Mossberg 800 bolt disassembly instructions
TO DISASSEMBLE BOLT - Depress Safety
Cap' Lock Plunger #8 and turn Safety Cap
# 1 counterclockwise. Striker Spring #9
and Firing Pin Assembly #10 can then be
removed.
TO REASSEMBLE BOLT - Replace firing pin
assembly and striker spring. Insert safety
cap and turn clockwise making sure that it is screwed forward as far as it will go. Then unscrew
until the hole for the safety cap lock plunger is in line
with the cam slot in the bolt. Drop lock spring and
plunger into hole and face cut out portion toward bolt.
Depress plunger and screw cap clockwise until the
plunger is engaged in the recess in the rear of the bolt.
Oct 26, 2010 | Mossberg Sport & Outdoor - Others
Optics Logo
357 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you an Optic Expert? Answer questions, earn points and help others
