Question about Coffee Makers & Espresso Machines
How to replace AZKOYEN CAPRICCIO GRINDER BURRS
I need to know how to replace my burrs from my AZKOYEN CAPRICCIO GRINDER
  • Isaac Roffe Dec 31, 2012
    I have the manual for the Azkoyen Capriccio and there is no detail on how to replace the grinder burrs
    I have desasemble the Grinder but dont know how to remove the burrs
3 Suggested Answers
z34aga
  • 137 Answers
SOURCE: replace burrs?
here is solution how to to replace and order burs from producer. also you have diagram for opening and closing the grinder.
http://www.grindmaster.com/literature/operatorsmanual/GR-373-04%20115_250%20Manual.pdf
Posted on Mar 29, 2009
  • 352 Answers
SOURCE: I bought new green coffee beans recently, roasted
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Posted on Dec 01, 2009
My gaggia titanium dumps the brewed coffee into the dregdrawer, how do I fix that?
Water collection in dump box can be due to any of the following reasons:
1- The Plastic screw that fastens the upper filter screen in the brew group is not holding the 9 bar extraction pressure. The O-ring seal on the screw may have hardened. Replace the plastic screw. There are two different screws. Older Pre 2004 models have a screw with flexible locking pins. Here is the link to order:
http://www.shop.partsguru.com/701R05150-Saeco-Pre-2004-long-Plastic-screw-30-Gm-Lube-701R05150.htm
The screw in newer models is shorter with a flat locking end. Here is the link:
http://www.shop.partsguru.com/Saeco-short-Thumb-Screw-with-O-ring-30-Gm-lube-0018755.htm.
2- The second reason can be less coffee which is not enough for good compacting. This leaves room for some coffee that did not squeeze out and drops in the dump box with watery used coffee puck.
3- The Conical burrs may not have been replace for several years. The steel conical burrs have a life of 2500 grinds. This machine may still have burrs that have done over 5000 grinds.
Blunted burrs need to be replaced. You can order the burrs and instructions for cleaning the grinder and replacing the burrs. Here is the link:
http://www.shop.partsguru.com/226473500-Saeco-and-Gaggia-Conical-Grinder-Burrs-Set-0018819.htm?categoryId=-1
Please check the above and fix the cause.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Mar 03, 2015 | Gaggia Titanium Espresso Machine
How to change burrs
1 take the bell(bean container) carefully out. 2 disassemble the upper holder of burr 3 you will see now the burrs, clean good coffee remains than disassemble the burrs 4 after disassembling burrs clean good the lower and upper burr holder. 5 carefully switch on the grinder tan switch off(few seconds) during lower plate is rolling touch with marker the surface of burr holder very softly, if it is ok you will have complete circle / if it is deformed you will have incomplete circle( that you must compensate with letter tape ) after each correction you mark the burr with marker to see did you achieved perfect result. once you have lower burr in place you screw bolts in upper bur holder and assemble it back in his place.
Feb 11, 2011 | La Pavoni Jolly (PA-JL) Electric Burr...
When grinding coffee beans the grinder is not dropping the beans into the grinder part. I have to stay and shake or bang the grinder on counter to get the beans to fall through.
you must screw off the burr holder plate screw (in center) you will order one special screw, drill shaped, when the burrs roll it will mix and take down the coffee beans. That is solution i applied to many grinders. PS: beware the direction of burrs must be coordinated with new screw.
Feb 07, 2011 | Cuisinart Supreme Grind DBM-8 Electric...
It says to "lift the
BURRS are the metal parts that grinds the coffee. There are 2 BURRS in the grinders, The upper burr is normally the one you adjust (Fine or coarse) and the lower or closer to the motor is the one turning during the grinding process.
Jan 25, 2011 | Starbucks Barista Burr Grinder
Burrs spin but no grinding
Try this, remove the bean hopper, and vac out the burr chamber, then put 1 tablespoon white rice in the burr chamber and cover with hand and turn grinder on, if the rice grinds, then your grind might have been set too fine. Turn the grinder towards fine until you can barely turn the burr nut, you will feel them touching, then turn course about 16 notches (do not use numbers, use the small notches around the rim), that should give you a great starting point for your grind.
May 20, 2010 | Mazzer Mini Burr Coffee Grinder
The coffee comes out in little logs or clumps. The coffee is weak- no crema.
HI
There are 2 things that can cause this. Either the burrs are bad and need replacing or you grinder is out of adjustment and you need to turn to a finer grind. If you have taken it apart, you are not adjusted close enough so your burrs can't grind fine enough. Readjust the burrs closer together.
Oct 11, 2009 | Rancilio Rocky Electric Burr Grinder
Replace burrs?
Jan 01, 2009 | Grindmaster 100 Electric Burr Grinder
Clogged
The burrs need to kept clean otherwise it will create a lot of dust and jam it up. This is aggravated with oil coffee and flavored coffee. Thoroughly clean the burrs and chute.
Aug 24, 2008 | Solis Maestro Electric Burr Grinder
Won't Grind without shaking it!
Sound like it's choked up with grounds and oil. Burrs may also be blunt. U need to dismantle and clean/ check burrs, passages and body. If you can see "flats" on the burrs or they feel not sharp when you check with finger, they should be replaced.
Jan 17, 2008 | Krups GVX2-12 Electric Burr Grinder
Coffee Makers & Espresso Machines Logo
102 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
