Question about Digital Lifestyle s LT32323 LCD TV
Red flashing light on digital lifestyle lcd tv and will not power on
  • 77 Answers
SOURCE: sound lost on digital lifestyles tv
Try unplugging it for a few and starting over, check your connections. If that does not help it is probably broken. This brings you to the bigger problem, It is no mystery why all of these new "no name" TV manufactures are so much cheaper than 1st tier products. Some of it is quality, but the biggest reason you spent a few to maybe several hundred less than the Sony, Toshiba, Samsung, Mitsubishi, etc. is after the purchase support. If your TV is broken chances are it is not getting fixed. There is no such thing as Digital Lifestyle replacement parts, service centers, service manuals, etc. If a company can build a TV then wash their hands of it they can sell it much cheaper. Name brand manufactures produce original replacement parts for years, they set up authorized service centers all over the country and they publish service info for their servicers. You might take it in somewhere for a look, sometimes it is something simple or basic electronic circuit failures that can be repaired with common generic components, but if you need something specific, it won't happen. You say it is "new" if it turns out broken and you can return it, do it, go smaller with a name brand or spend the extra few hundred bucks. Don't get me wrong name brands break too, the difference is they are repaired and you move on rather than throwing it away and buying again. People are discovering there is nothing more expensive than a cheap TV. Good Luck
Posted on Dec 28, 2007
  • 3 Answers
SOURCE: U-Verse remote for Digital Lifestyle
I use my Directv remote to change the channel. What you have to do is go the your direct tv remote go to setup then go to remote then look for tv brand Citizen then follow the direction the menu tells you to do. It works fine. You can use Tv Brand Citizen, Concerto, Luxman They work with any u-verse remote 4 digit code 0056 5 digit code 10056
Posted on Dec 17, 2008
SOURCE: I need to know the manufacturer of the digital lifestyles tv
the manufactures name is corian usa 800-278-6334 i had this problem and it turned out that u have to use LG codes.i also had to use lg codes to code direct tv sat box
Posted on Mar 18, 2009
SOURCE: cannot find code for digital lifestyles remote control
LG codes work with digital lifestyle.
Posted on Aug 20, 2009
rulds2008
  • 3866 Answers
SOURCE: my digital lifestyles 42 widescreen lcd hdtv won t power on
PLEASE NOTE IF YOU HAVE NO EXPERIENCE IN TV REPAIR SEEK OUT LOCAL TECHNITION OTHER WISE CHACK THESE THINGS BELOW.
1. check power supply
2. fuses
3. inverter.
Make sure you have no bad capcitors a bad capcitor is a leaking one or bulging at the top or sides if that is the case please replace them.
thanks
Posted on Sep 17, 2009
Testimonial: "Thanks for this general insite. I'll seek a repair service and see what can be done."
I cant seem to power on
Try pressing and holding the button for a second or two. You may also try using a remote control to power on the tv
Jan 06, 2015 | Televison & Video
Turn on tv green light gose to red light after 45 seconds
It is most probably the power supply board. There is a repair service which addresses any problem with the power supply board, not just bad capacitors: http://www.coppelltvrepair.com/p/780/digital-lifestyles-wt322-power-supply-board-repair-service-no-power-shutdown-etc
Jan 14, 2014 | Digital Lifestyle FA1B32Z 32 in. LCD...
My digital lifestyles tv does not power on, either with the on/off button or witht he remote. Why?
sounds like a power board is faulty or the invertor transformers are bad
Mar 02, 2013 | Televison & Video
TV won't turn on. Red light on front stays on all the time but will blink when you push the power button.
hi
this sounds like a fault on power supply board most likly a capacitor 1000uf 25 volt working> look on the power supply board the faulty capacitor will be enlargded on the top it might pay you to replace all the 1000uf cap,s onthe power board. regards windyhouse
Jun 17, 2011 | Digital Lifestyle s LT32323 LCD TV
My dishnetwork universal remote cant find a code for my digital lifestyle tv
Power Scan instructions:
Step 1:
Press and hold the TV mode button until all mode button back lights illuminate,then release.
Step 2:
Press and release the Power button.
Step 3:
Press the Up button once a second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff.
Step 4:
Press the pound (#) button. If the code entered is valid for the remote, themode light flashes three times.
After doing the power scan please remember to put the remote back into SATmode. Thanks so much for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Nov 04, 2010 | Digital Lifestyle s LT32323 LCD TV
Red standby light is on, but when I hit the power button the red light blinks and does not turn green as is normal and th TV doesnot come on. What is going on?
Tries unplug,replug the tv about hour later,let the tv resetting itself back to factory setting.The tv should work now.Not,than the power supply board have problems,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 17, 2010 | Digital Lifestyle FA1B32Z 32 in. LCD...
My lcd digital lifestyle tv is blinking like a strobe light.
Your back-lighting is failing. This is part of the LCD panel and can not be repaired without replacing it. Due to the cost of the panel, best advise would be to replace the TV. Sorry for the bad news... you should check into your warranty status.
Jun 28, 2010 | Digital Lifestyle FA1B32Z 32 in. LCD...
Can't turn on TV.
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Jun 12, 2010 | Digital Lifestyle FA1B32Z 32 in. LCD...
Our Tv will not turn on. It has a red stand by
I've had the same problem. Found out it was a failed power supply component. Took it to local TV/Computer repair shop and they fixed it up in a couple of days.
Oct 02, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
Open Questions:
Digital Lifestyle s LT32323 LCD TV Logo
Top Digital Lifestyle Televison & Video Experts
CoppellTVRepair.com
paul
paul
Back2life...
Are you a Digital Lifestyle Televison and Video Expert? Answer questions, earn points and help others
