Question about Hardware & Accessories
How do i wire a Utilitech TM-029-1
My wall switch has only a black wire with no withe's
  • 351 Answers
SOURCE: Trying to replace Intermatic with Utilitech inwall
The wires on your new switch are intended for black = power .. white = neutral . and red = lights .. with two black wires on the old switch I am assuming that there is a bundle of white wires in that wall box, the white timer needs to join that bundle ... then you need to determine which black wire is the power from the electrical panel ( voltage tester) and connect to the black timer wire .. the red timer wire connects to the other black wire in the wall..
Please Vote !!
Posted on May 13, 2010
  • 351 Answers
SOURCE: I bought a Utilitech 7 day digital in wall timer,
HI .. if the switch has only a black and white wire attached, and there are no other wires in the wall box, then you cannot use this timer switch. You need to return it and get a timer that does not use a neutral connection. The wires you have are a switch leg from the light and there is a white wire but it is not a neutral.
If there are other wires in that wall box , tell me and we can chat more about how to remedy this .
Please Vote !!
Posted on May 25, 2010
SOURCE: I am trying to install
1) Wires in box:
Black looped to to next switch is Black hot wire
Other Black goes to fixture
2) Connect timer wires
Black timer wire goes to Black hot
Red (or Blue) timer wire goes to fixture
White wire connects to white neutral wires (usually connected together with wire nut and pushed to back of box)
Green goes to bare ground wire
Posted on Sep 21, 2010
SOURCE: Utilitech 7 day in-wall digital timer #LW60418
Need programing instructions
Posted on Nov 13, 2010
SOURCE: Only 2 black wires on current switch - Utilitech 0192773 has 4
Webpage explains wiring and has large print:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Posted on Dec 09, 2010
Operating Utilitech #tm-029mitem #0192773 what is the button on right (next to on/off button)
The first press of the button to the right of the On/Off button on the Utilitech TM-029 will display the current Sunrise time. You can then adjust this time with the +/- buttons. A second press will display the Sunset time and allow you to adjust that.
This is useful if you want a light to come on at sunset (or a time near sunset) and go off at sunrise every day.
I found the manual for the TM-029 here: http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html . Look in the right hand column under Resource. The direct link to the manual is http://waterheatertimer.org/pdf/Utilitec-TM-029-timer.pdf .
I hope this helps.
Nov 03, 2017 | Hardware & Accessories
Utilitech TM-029 light switch timer; battery replacement; where is the battery?
The battery is a capacitor built into circuit board.
When timer is connected to power, it charges the battery... and during power outage, the capacitor discharges power to hold memories until power resumes.
There is no replacement battery.
http://waterheatertimer.org/Programmable.html#utilitec
Link above has manuals related to programmable wall timers
Gene
Water Heater Timers Save Money
Mar 07, 2015 | Hardware & Accessories
Utilitech TM-029 wall timer: I've installed the
Do not run any timer warm... replace with switch, and/or buy another timer.
Copy following link to identify timer and download instructions:
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
This timer is rated 15 amp 1875 watts.
Safe maximum is always 80% rating plate: is 12 amp and 1440 watts.
Add up total watts on circuit.
Add a comment and say what you discover.
Jun 29, 2013 | Hardware & Accessories
I have tried to install the Utilitech timer but am having trouble. I have a ground, black, and red wire that were previously wired to a switch that controlled my outdoor garage lights. I tried to hook red...
Sounds like this was probably a three-way switch you are replacing as there is no neutral (white) wire in the box. If so, you can splice the white wire to the green wire in other three-way switch box; then hook the green wire in the box you are placing the timer to the white wire of the Utilitech timer.
Apr 17, 2011 | Intermatic & Self-Adjusting Wall Switch...
Trying to replace Intermatic with Utilitech inwall timers. Have 2 black wires in wall box with other switches for other lights. Which of the Utilitech 4 wires- black, red, white & green get conected to...
Please Vote !!
Apr 08, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Mar 07, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Hardware & Accessories Logo
145 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
