Question about ASUS (M2NCMBO90N66163000) CD-RW/DVD-ROM (Combo) Burner
My dvd rom cannot extract all files when i check my dvd in another dvd rom it is fine what can i do now?
    Problem Solver:
  • 10 Answers
Sounds like a dirty lens.
try running a DVD cleaner disc in it.
you could clean it yourself, but that would involve taking the unit apart.
Failing that the easiest thing is to buy a new one. They're really cheap these days.
Posted on Jan 18, 2009
I just bought an LG BD-550 and I want to make it region free. How?
Hi.
Try the solution below:
"To set DVD Region to "any", download file "6000.zip" (often also called "LG6000.zip") from this link:
http://www.multi-region.net/_media/6000.zip
Save the file and then unzip and extract it to your hard drive. Now burn the subdirectory RMTM0000 and its contents (not the text file) onto a CD-ROM (ISO format, "closed" CD-ROM). Insert CD-ROM into the LG BD 370 P player, and when the Region Management System screen is displayed, set the Region Code to "0" using your remote. Once done, press "PAUSE" on you remote to save, and you're done!"
From : http://www.videohelp.com/dvdhacks/lg-bd370/10016
Feb 17, 2011 | LG BD370 BLU RAY PLAYER
I INSTALLED NFS CARBON FROM INTERNET ITS IS ASKING ME TO INSERT CORRECT DVD-ROM
copy the crack folder from the downloaded file and then paste it on the file where you have extracted the game doing this probably will help you
Jan 17, 2011 | EA - Electronic Arts Need For Speed:...
How to instal file 'asms The file 'Asms' on Windows XP Professional Service Pack 2 CD is needed" when installing WinXP Pro,
When you install Microsoft Windows XP, you may receive the following error message:
[Files Needed]
The file 'Asms' on Windows XP Professional CD-ROM is needed. Type the path where the file is located, and then click OK.
This issue may occur if the Setup program cannot communicate with the CD-ROM drive.
To resolve this issue, use the appropriate method for your computer.
Hard disk formatted with FAT or FAT32 file system
If the hard disk is formatted with the FAT file system or with the FAT32 file system, follow these steps:
Use a Microsoft Windows 98 Second Edition or Microsoft Windows Millennium Edition (Me) Startup disk with CD-ROM drivers to restart the computer.
Copy the Xcopy.exe tool from the Windows 98 Second Edition CD-ROM, the Windows Millennium Edition (Me) CD-ROM, or the hard disk to the Windows Startup disk. To do this, use the appropriate method.
Insert the Windows 98 Second Edition CD-ROM in the CD-ROM or DVD-ROM drive, and then at the command prompt type the following lines, pressing ENTER after you type each line, where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive:
c:
copy cd-rom:\win98\smartdrv.exe
copy cd-rom:\tools\oldmsdos\xcopy*.*
Insert the Windows Millennium Edition (Me) CD-ROM in the CD-ROM or DVD-ROM drive, at the command prompt type the following lines where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive, and then press ENTER after you type each line:
c:
copy cd-rom:\win9x\smartdrv.exe
extract cd-rom:\win9x\win_17.cab xcopy.exe /L c:\ xcopy.exe
extract cd-rom:\win9x\win_17.cab xcopy32.exe /L c:\ xcopy32.exe
extract cd-rom:\win9x\win_19.cab xcopy32.mod /L c:\ xcopy32.mod
Hard disk
At the command prompt, type the following lines where drive is the drive letter of the hard disk where Windows is installed, and then press ENTER after you type each line:
c:
copy drive:\windows\smartdrv.*
copy drive:\windows\xcopy*.*
Eject the Windows 98 or Windows Millennium Edition (Me) CD-ROM, and then insert the Windows XP Professional CD-ROM.
Copy the I386 folder and all its subfolders to the hard disk. To do this, type the following lines at the command prompt where cd-rom is the drive letter of the CD-ROM drive, and drive is the drive letter of the hard disk, and then press ENTER after you type each line:
smartdrv
xcopy cd-rom:\i386 drive:\i386 /e
Restart the computer, and then start the Setup program again.
When you receive the error message, click Browse, and then type the path of the I386 folder on the hard disk.
Note You may be prompted several times for the location of this folder. If Browse is not available, see the "Hard disk formatted with NTFS file system" section.
If the hard disk is formatted with the NTFS file system and you are upgrading an earlier version of Windows, use one of the following methods.
Method 1
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
When you receive the error message, press SHIFT+F10 to start a command session.
Type regedit.exe, and then press ENTER.
Click HKEY_LOCAL_MACHINE.
On the File menu, click Load Hive, and then load %Windir%\System32\Config\System.sav.
When you are prompted to specify a name, type Test.
Locate and then click the following key:
HKEY_LOCAL_MACHINE\Test\ControlSet1\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the UPPERFILTERS and LOWERFILTERS registry keys.
Repeat steps 6 and 7 for the other ControlSet# keys under the Test hive.
Click File, and then click Exit to quit Registry Editor.
If the path in the error message is the correct drive letter for the CD-ROM drive, click OK to continue the Setup program.
If you receive the error message again, the Setup program cannot correctly read from the CD-ROM drive, or the path information is incorrect. In this case, restart your computer and let the Setup program resume.
Method 2
If you cannot start Regedit.exe at the command prompt, and there is another available partition where you can install Windows on the hard disk, follow these steps:
Install Windows in the other partition.
Start the new installation of Windows, and then start Regedit.exe.
Follow the steps in method 1, but load the System.sav hive from the original Windows folder.
Method 3
If you are not using a retail Windows XP CD-ROM with a hologram (for example, if you are using a burned CD-ROM), try to run the Setup program from a retail CD-ROM with a hologram. To verify this, start the computer by using Recovery Console, and then check the C:\$win_nt$.~ls folder. Look for the Asms folder. If the folder is missing or the files that it contains are zero bytes, the CD-ROM was not burned correctly.
For additional information about how to use Recovery Console, click the following article number to view the article in the Microsoft Knowledge Base:
307654 (http://support.microsoft.com/kb/307654/ ) HOW TO: Install and use the Recovery Console in Windows XP
Apr 27, 2010 | Microsoft Windows XP Professional With...
Disk error 0280
Error 0280 on Hitachi mv350a DVD camera : It looks the dvd had bad spots that could not be read. After getting frustrated trying to get any info from Hitachi manuals and support, I just decided to try to extract the data directly from the dvd(fujitsu dvd-r disk). Since my DVD was not finalized I could not copy the files directly using Windows Explorer, so I tested several applications and here it's what worked for me: I downloaded isobuster (www.isobuster.com), and I was able to view the tracks on the dvd, then I used the "Extract" option to create an image directly from the faulty dvd and it created a couple of files with the extension .ibq. I checked these ibq files and two of them were huge, so I assumed those were my video data. I renamed these files from *.ibq to *.vob(isobuster has options to extract these "image files", but you need to register it first...), anyways I tried to open these new vob files with PowerDVD and they PLAYED JUST FINE :)! Finally I just used a DVD editor to load the new .vob files and I burnt a new DVD. I hope it will save you guys some time... Mihai from Romania :)
Oct 09, 2009 | Hitachi DZ-MV380A DVD Camcorder
Brand new computer and i did not install the adobe it came with the computer Vista basic and i get the 1311 error message when i try to run adobe computer 1 day old !
no big problm if u comp is new r old...
When you try to install Adobe Acrobat 6, 7, 8, or 3D on Windows, the installer returns the error message "Error [1311, 1335 or 2350]. Source file not found: [drive name]:\ Adobe Acrobat [version]\data1.cab. Verify that the file exists and that you can access it." If you click Retry, the installer returns the error message "Cannot find the file Adobe Acrobat [version]\data1.cab."
Solution Perform one or more of the following solutions:
Solution 1: Check the Acrobat CD-ROM.
Make sure that the CD-ROM from which you are installing is free of dirt and debris. If necessary, clean the CD-ROM with a soft, lint-free cloth.
Solution 2: Temporarily disable anti-virus software, and then install Acrobat.
For instructions, see the documentation for the anti-virus software or contact the manufacturer.
Solution 3: Extract the compressed installation files, and then install Acrobat.
  1. Right-click the folder and choose Extract All.
  2. Follow the on-screen instructions.
  3. To install Acrobat, double-click the Setup.exe file located in the folder that contains the extracted files.
Solution 4: Uninstall the CD-ROM drive and let Windows redetect it, and then install Acrobat.
  1. Right-click My Computer and choose Properties.
  2. Click the Hardware tab, and then click Device Manager.
  3. Expand the DVD/CD-ROM drives section.
  4. Right-click each device listed under DVD/CD-ROM drives and choose Uninstall. Click OK to confirm.
  5. Close Device Manager and restart the computer.
  6. After Windows redetects the DVD/CD-ROM drive(s), insert the Acrobat CD into the CD-ROM drive and install Acrobat.
Solution 5: Install Acrobat from the desktop.
  1. Insert the Acrobat CD into the CD-ROM drive.
  2. Copy the Acrobat folder from the Acrobat CD to the Desktop.
  3. Double-click setup.exe in the Acrobat folder on the Desktop, and then follow the on-screen instructions to complete installation.
Additional Information Errors 1311, 1335, and 2350 occur when the Acrobat installer is unable to access the necessary files from the CD-ROM drive. These same errors may also occur if antivirus software interferes with an installation or if the installation files are compressed.
thank u sir,, if u feel i helped u, then plz vote/rate me with good marks..thank u!!
Jul 18, 2009 | Dell Inspiron 530s Desktop Computer...
I have a lg DVD-RAM Model no GH22NP20 its not run data cds & DVD-RAM.
need to check firmware version then update it
Here's how to get LG's Auto Firmware Updater
Go here :
http://www.lge.com/support/software.jsp
Select
> Location = North America > USA/ Canada
Then
> Product = DVD-ROM (writer)
> Operating System = Vista
> Subject = LG Auto Firmware Download
Download the .zip file to your Desktop
You'll need to "Extract All" from the .zip
and then run the setup file
You'll need to allow Internet Access ( AV/IS )
The Updater will probably need to Update itself - before being active
To Manually Search For Firmware Updates
> Subject = Firmware
Look through the Listings for your Specific Drive
I would recommend Disabling the LG Auto Firmware Updater
- from Windows Start-up
You can open the Updater at any time - from All Programs
Apr 26, 2009 | Computers & Internet
LG BD300 dvd palyer region free code
To set DVD Region to “0”, download file “6000.zip” (often also called “LG6000.zip”) from here:
Now burn the subdirectory RMTM0000 and its contents (not the text file) onto a CD-ROM (ISO format, “closed” CD-ROM).
Insert CD-ROM into the LG BD 370 P player, and when the Region Management System screen is displayed, set the Region Code to “0” using your remote. Once done, press “PAUSE” on you remote to save, and you’re done!
Mar 03, 2009 | LG Super Blu BH200 Blu-ray and HD-DVD...
My ide dvd-rom is not working properly and i need drivers for it
Consider downloading and installing driver scanner it scans for the outdated drivers and helps download it automatically without having to search.
click here to download driver scanneer:
you will be required to extract the file using sevenzip:
click here to download sevenzip
Jan 30, 2009 | Samsung (SD-612) Internal DVD Drive
Help copy dvd movie
clone dvd is one among the best software to extract movies and games from original dvds
Jul 07, 2008 | Samsung (TSH492ABEBN) CD-RW/DVD-ROM...
DVD-Rom's problem! Plz help!
* please check dvd rom cable(ide cable) is connected properly
* check powerconnecter is connected tight
jumper settings:
* set ur hdd as master
* dvd rom as slave in ide1
* set master to dvd writer in ide 2
Jun 19, 2008 | Computers & Internet
ASUS (M2NCMBO90N66163000) CD-RW/DVD-ROM (Combo) Burner Logo
53 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
