Problem with whirlpool AWM 1000
When i start the machine, it doesn't take water, there is a LED indicator Hydro- Security. How can i resolv the problem?
It's not indicated to put much detergent ( washing solution), because it will stop water acces, causing acumulation of water, then the LED will indicate Hydro-Secutity. The solution is open the washing mashine you'll see that you need to evacuate water then to clean manualy the indicator ( Hydro-Security). That's all, I hope that i my information was helpful for your problem.
Posted on Jan 26, 2009
  • Eda Qazimi Apr 17, 2012
    I know it might be too late (3 years already), but I am having this problem with my washing machine. It is a Bauknecht (Whirlpool), and it will not accept water, the Hydro Security LED is on all the time. I tried to clean the thing on the bottom right, to see if any "external bodies" were blocking the way, but even after this, it still goes on in the same manner. Would you, please, be so kind and explain to me how to drain the water out of it? I tried the "abpumpen" (my washing machine is in German, no idea why) option, but it will not result into anything. I would so much appreciate your response. Thanks in advance!
Whirlpool awm 9000 I bought a used Whirlpool
The error code F/H for this machine means that the drain pump is blocked. Look at your manual for how to access the drain pump and clean it out. This will resolve your issue.
Oct 18, 2013 | Washing Machines
Inlet valve non operational on whirlpool awm 258 nordic
Please check on the voltage on the inlet valve , check on the controller if there is no voltage if not the inlet valve is faulty.
click this link: inlet valve
Jul 27, 2012 | Whirlpool Washing Machines
Whirlpool AWM 045-1000 washing machine has suddenly stopped working and warning light "WATER STOP" has come on. Any ideas for a fix?
Sep 19, 2009 | Whirlpool Washing Machines
Whirlpool awm 221 washer
you will need a replacement heating element for the appliance
Jan 24, 2009 | Whirlpool AWM5125/1 Front Load Washer
Washing cycle starts and takes hours even for short cycle.
Try checking for good water supply.
Pull out detergent tray and check for good water supply during filling.
if poor filling-
Try checking the hoses.
Turn taps off, disconnect from machine, place hose end in sink, turn tap on and check for good water flow.
if the hose has a red indicator in the side of the hose (end which is fitted to the tap) - Red indicator is a failed hose.(for models with Water Stop hose type "B")
Oct 05, 2008 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
502 people viewed this question
Top Washing Machines Experts
