Question about Pride Mobility Products Go-Go Elite Traveller Scooter - 4 wheel w/12 AH Batteries & Charger + Flat Free Tires - Silver
Batteries are charged, scooter won't move, no power to display
Go glo elite travelller; what's the ;problem?
  • 1 more comment
  • JoniB Jan 19, 2009
    We were wondering if we overcharged the battery?
  • Anonymous Mar 23, 2014
    Scooter is fully charged and when use it it works fine but when get off and then get back on scooter won't move but lights and horn work
    Batteries are charged up and scooter works perfect but then when get off scooter for 5 min and get back on scooter will not move but lights and horn work
  • 118 Answers
It is impossible to overcharge with the Pride charger. When the battery is full, it will stop charging and check about oncew a miute to maintain the charge.
Now, when you plug in the key (looks like an audio headset jack) does the battery meter indicate a full charge? Also, the scooter will not move if its in free wheel mode, and it will not move if the charger is plugged in. Beyond these first steps, you will need a voltage meter to troubleshoot.
Posted on Jan 28, 2009
Why does green light on charger stay on?
Most pride chargers show up the green light when batteries r charged...when charging u should have a red power led & an orange led ...hope this helps
Jan 07, 2016 | Pride Mobility Products Go-Go Elite...
I have a go go elite traveller plus , the battery pack will not lift off my scooter it seems to be stuck , i need to replace the batteries
The manual for this scooter is at http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
The closest info I can find is page 14. MOVING AND TRANSPORTING YOUR Easy Travel Elite
6.1. Moving Your Easy Travel Elite in Freewheel Mode when unfolded:
The Freewheel switch (Fig. 1/17) is used for releasing the brake and moving the Easy Travel Elite without operating the motor. Before activating, make sure your Easy Travel Elite is switched on. Turn Freewheel switch to the "freewheel" position and push or pull the Easy Travel Elite manually.
NOTE: The Freewheel mode can only be activated after the battery is in place and the power switch (Fig.9/1) is turned on. Doing otherwise will cause a fault situation indicated by rapid flashing of the Indicator light (Fig. 9/4). See section 4.2.
WARNING: The Freewheel switch should never be engaged on a slope.
CAUTION: The seat back must remain in the upright position.
They seem to assume removal is obvious, I would check any connections from battery to scooter are pulled out and that freewheel mode is not engaged.
Oct 07, 2013 | Pride Mobility Products Go-Go Elite...
PRIDE MOBILITY 3 WHEEL SCOOTER FAILS TO MOVE FORWARD OR BACK
Hi. This is just a thought but have you tried putting the batteries back on the scooter and putting a volt meter on the batteries to get a reading when the lever is pressed on the scooter. Batteries can display as being fully charged (+12 volts) but often fail under load, meaning that as soon as you press the lever, the voltage will drop right off. If this happens, it is more than likely that your batteries are to blame.
Hope this helps.
Jan 04, 2013 | Pride Mobility Products Health & Beauty
I have a gogo scooter it bleeps once than cuts out I have to turn it off and back on for it to move
probably a dead battery or a bad battery will move you till the controller gets to a threshold voltage then it beeps and stops , testing this is easy turn on the scooter adjust the speed control to the lowest setting then start riding the scooter at full throttle then start turning up the speed controller if that produces the problem then the batteries need charged or replaced
Jul 01, 2010 | Pride Mobility Products Go-Go Elite...
Battery won't hold a charge - go-go elite travellor scooter battery charged overnight but won't hold charge.
We have had problems with scooter batteries from time to time and the repair man said to take apart the battery case and disconnect the batteries and use a car charger. I put the two battery in parallel and used a amp battery charger. This worked fine.
Don't run your scooter batteries all the way down when using the Go Go as the scooter charger won't always bring them up to full charge and you may have repeat this. Also running the batteries all the way down shortens there life.
Mar 19, 2010 | Pride Mobility Products Go-Go Elite...
Charging sterling elite 2001 scooter batteries
If you use the scooter every day then plug the scooter in each night for 8-10 hours.
Jul 20, 2009 | Pride Mobility Products Go-Go Elite...
We have charged the battery and when we turn on the scooter all it does it make a beeping sound and the scooter will not move
So the Battery charger is showing a green light (Fully Charged ?) Can you tell me the MAke and Model of the Scooter ?
Jun 12, 2009 | Pride Mobility Products Go-Go Elite...
Pride Mobility Products Go-Go Elite Traveller Scooter - 4 wheel w/12 AH Batteries & Charger + Flat Free Tires - Silver Logo
680 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
