Question about Garden
Honda Lawn Mower HRR2166VKA Throttle lever broke
The arm/throttle lever that holds the throttle cable (located on top of the transmission on rear axle) broke. All I need is to access the top of the transmittion to replace or fix the throttle arm.
  • 246 Answers
SOURCE: John Deere 14SB mower with Kawasaki FC150V series - Throttle adj.
Hello rfbarrett:
From your Description it Sounds like the Plate that is Attached to the Carburetor (that the Throttle cable Attaches to) Thru Shaft (holds and Moves the Throttle Valve) has Loosened and is Simply Turning on the Thru Shaft and Not Moving the Thru Shaft and Throttle Valve at All.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers 14SB and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
rburroak
  • 14 Answers
SOURCE: lawn mower needs new cord to crank the engine. how do i replace the cord
Remove the 3 bolts located on the flywheel housing.(should be 7/16") one in front and two on side.
Posted on Jun 19, 2009
SOURCE: Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Posted on Aug 07, 2009
SOURCE: I have a Honda HRT216SDA lawn mower. I replaced
Took it to a repair shop.
Posted on Sep 03, 2009
  • 78 Answers
SOURCE: honda lawn mower wheel drive works, but needs adjustment, how?
Take the covers off the drive,there should be a hollow bolt the cable comes thru, it should have 2 adjustment nuts This lengthens or shorts the cable. There also may be a adjustment on the handle.
Posted on Oct 27, 2009
My Victa push lawn mower won't shut off. Throttle cable pulls back but won't push forward and springs underneath housing seem extremely loose. What do I need to repair/replace?
Sounds like the inner throttle cable is binding with the outer casing,
This coule be caused by dust and moisture causing rust on the inner cable. I would firstly try to get a light spray lubricant into the outer casing .
I would disconnect it from the throttle lever and spray lubricant onto the inner cable and progressively work the throttle lever to draw the fluid into the outer case. Elevate the lower end so gravity will assist you.
Feb 03, 2013 | Garden
I have a 6.5 B&S engine on a RYOBI lawn mower That will not come up to mowing RPM. the mower does not have a throttle cable and the spring on the throttle appear to be intach. The engine starts real...
Normally when you move the throttle control on the handle, all that is happening is that governor spring tension is increasing or decreasing pull on the linkage /governor arm. With engine off and plug wire removed, look for a small shaft coming out of the engine with an arm attached. Attached to the small arm will be linkage to the throttle on carb.. So when you move the throttle on the carb with your finger the arm moves also. There should be spring connected to opposite side of governor arm connected to throttle control at the handle or small lever or metal tab. When you incease pull on the spring, the engine will speed-up. Adjust as needed. Good luck
Jun 28, 2011 | Briggs Stratton H7159 & StrattonĀ® 5500,...
Engine cycles high & low, does not run smooth
I think the gas needs to be changed or the carb needs to have the needle and float replaced. The gas may be just strong enough to fire but misses causing the high and low. If gunk gets built up on the float, then the float can't be "floated" right to open up the needle so the right amount of gas is let in. Sometimes the carb, can be cleaned but it's usually best to just buy a new float kit, which is $5-$7 here. You can also buy a new carb which is about $35. Just depends on where and how you want to do it. Good Luck
Apr 11, 2011 | Poulan Pro PR550N22SH 22Inch Briggs ...
How to set the linkages and adjust a carburettor on a Honda HRU 195 mower
Turn the engine off, Put the throttle
lever to the HIGH position. Loosen the
pinch bolt nut on the governor arm a
turn or two; just enough that the arm will
move on its shaft.
With one hand, move the governor
arm so that the throttle plate of the
carburettor is wide open. With your other
hand, use smallish pliers that's
why there is a flat on the shaft to turn
the shaft in the same direction. Hold
everything in that position and tighten
the pinch bolt.
You've just taken all the slack out of the governor linkage.
Recheck the choke, idle and maximum RPM
and you've done all the adjusting
you can do.
Nov 25, 2010 | Honda Garden
Toro 6.5 hp Mower Model 20487 Serial # 200001326 Initially, the mower would start and run for 3 seconds. I removed the carb and cleaned the bowl and jet holes in the bolt that holds bowl. The float...
The linkage on the top of the carb should go to a spring loaded arm that goes into the side of the motor. Work the lever back and forth and see if it works the carb. If it does and everything is in place your governor mechanism inside the engine might be damaged.
If the arm isnt working the carb it is probably bound up or attached to the wrong hole in the carbs throttle lever. There should be two holes and one of them would force the throttle wide open everytime reguardless of what the governor arm tries to do.
Oct 09, 2010 | Garden
Lawnmower engine idling to low
First, follow your throttle cable down to the carb. Locate the clamp that holds the housing in place and loosen it just enough to move the cable. Start the mower and adjust the idle by the screw that touches the same plate that your cable hooks to. Then push the throttle control to idle and retighten the cable clamp.
Apr 26, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Craftsman self propelled walk behind lawn mower sef propel handle will not engage..the wheels will turn if you hold the handle down but the handle won't lock in........is something broken in the gear box?
Normally grass and debris are clogged under the belt/transmission cover, preventing the full engagement of the transmission cable/lever.
The cover is located on the topside, left front corner of the mower shell. Clean debris, try it again. If OK, re-install cover, If not, there is a cable adjustment (threaded portion with a nut on either side of a fastening arm) move the cable adjustment towards the rear, this will tighten the cable. Sometimes the cable assembly (includes the cable and the control box) needs to be replaced
Nov 08, 2009 | Craftsman Garden
I need to how to connect the throttle to the carb on a briggs and stratton riding mower a diagram would be great.
Don't have a diagram. It's pretty simple, tho.
There is a throttle cable run from the throtle control lever on the dash down to the carburetor. There is a lever on the carburetor -- usually this has a hole in it where the end of the throttle cable hooks.
There should be a clamp in that vicinity to hold down the throttle cable housing to allow the cable inside to move back and forth without moving the cable housing,
May 06, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Kill switch on handle
I presume it is the throttle switch as well, as most of the mowers have the kill switch there.
the plastic throttle handle should have a round pin at one end which connects to the throttle cable, there is usually a plastic outer cover that is retained by a threaded screw which holds it all together on the handle,
there may be a small screw at the top of the plastic throttle cover which is the adjusting screw for the throttle cable, if you loosen it, pull the throttle lever right back and push the screw down until it stops and then tighten it that will adjust the cable and should shut the engine down when the lever is pulled right back
Apr 02, 2009 | Garden
Garden Logo
121 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
