Question about Frigidaire Affinity ATF6000F Front Load Washer
After removing and cleaning a front loading washer bellow, can you reuse it? Mine had black mold, gross. Would not come ou, broher saud remove it and soak in water bleach mix, and it worked! But can
My model is ATF6000ES1 Mine had black mold, gross. Would not come out, no matter what I did. Brother said remove it and soak in water bleach mix, and it worked! But can I re-use the bellow? I know I need to leave the door open b/w washes, but I have also learned I've been using too much soap. Anyway just want to now if I can reuse the bellow...
    Sergeant:
  • 291 Answers
As long as it has retained it's shape and flexibility there should be no problem. That wire spring that goes around the outside of the bellows can be tricky to get back on. Be patient, wear gloves, get two more hands to hold in appropriate places. You'll see what i mean. Just keep telling yourself you can do it and eventually it will just magically happen. First time i did it i didn't think i'd ever get it and then suddenly there it was...easy-peasy.
Posted on Dec 30, 2012
Testimonial: "thanks do you mean the fist spring I removed, the one closest to the door? Or the second inner most spring. I'm cursing a lot, but will keep your comments in mind! thx again!"
  • B.H. Countryman Dec 31, 2012
    Yes, it\'s a bugger. I\'ve never replaced any with "the second inner most spring."
  • hoffclan
    hoffclan Dec 31, 2012
    Thanks for your help, it's done! It was especially hard as a 40 year old (female) with no extra helping hands , I used magic markers to hold the space for the inner ring. I mentioned the second "inner ring" just becauseI knew I had two rings, once I started I knew which onee you were talking about. Good news, mold is gone, an no leaks! (I'm sure ill come back dspite my best efforts)! Thanks again fo you fast reply! Happy NYear
I have front loader washing machine and the rubber has got mould and having difficulty in removing the black mould
  • Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
  • Tips for Preventing Mold & Smelly Problems:
    • Always leave the door and dispenser unit slightly ajar after the laundry is done. Front-load washers and the detergent/softener dispenser drawer must dry out.
    • Never leave a wet washload in the washer overnight; remove it when the washing cycle is complete and leave the door open.
    • After a load is done, always rotate the drum with your hand to see and remove all items. Some could be sticking to top or sides of the washer drum.
    • Use softener sheets in the dryer instead of liquid softeners in the washer.
    • Liquid detergents may leave less residue than powdered formulas which may not dissolve properly.
    • Use less than the recommended detergent level for your load. Too much detergent can cause a residue build up. Experiment until you find a minimum measurement that delivers a clean wash. This is also a money saver.
    • Occasionally wash some loads such as whites, linen and towels in warm or hot water to help flush out wash residue.
    • Always clean your washer as per your product manual. High efficiency front-load models have a cleaning cycle and it's imperative that you periodically run this cycle as directed.
    • Check the gasket just inside the door opening and remove any visible debris. You can also wipe it to speed the drying process.
    • Always use HE detergents with high efficiency front-load washers. Specially marked HE laundry detergent is low sudsing and is recommended for these low-water washers.
    • If this advice was helpful a vote with the thumbs up would be appreciated. Thanks.
    Apr 08, 2011 | Ariston Technologies Ariston AWD12 Front...
    Mold and mildew and a musty odor. I can see black mold around the door seal, primarily at the lower side of the door seal. Can I attempt to clean by using bleach? What are your recommendations to correct...
    The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
    PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
    CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
    LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
    NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((^^&&
    Sep 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
    Extreme mold on the gasket. How do I remove the mold and odor?
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!@
    May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    How do I deal with the black mold that is on the drum....it is pretty gross. solid black around the ribber on the drum.
    Here is a tip that I wrote about that problem...it tells you how to clean your washer and also how to prevent it from coming back...
    I will also include a tip I wrote on washer maintenance...
    http://www.fixya.com/support/r3993813-stop_washing_machine_smell_mold_mildew
    http://www.fixya.com/support/r4312694-washing_machine_maintenance
    heatman101
    Apr 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
    Mold on and behind the rubber gasket in the front opening of the machine! I need to know how to remove and prevent.
    A combination of bleach, a rag or toothbrush, and your time will remove the mold. Be sure to run a load of whites on the next load. Bleach, you know.
    Leaving the door open between loads should prevent this problem from repeating itself. The machine will have a chance to air dry. Only front loaders seem to get this. The top load machines are not sealed water tight, of course. Good luck
    Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Musty odor removal; also "mold" black in color around rubber seal
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$^*#
    Sep 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Mine does not get clothes very clean or remove odors. I use HE detergent and the tablets to clean the washer every month. It doesn't use ENOUGH water to get dirt out. With towels, parts of the load does...
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!@@
    Aug 12, 2009 | Maytag NFW7200TW Front Load Washer
    Mold build up around ribber gasket . Heavy, black and hard
    Front load washers are notorious for developing mold/mildew to build up because they retain a lot of moisture in the round gasket the door closes into. Wash it down with a 50:50 soulution of bleach and water. You may have to use a brush on the "hard" stuff. Occasionally, run a quick load with no clothes and just bleach through a complete cycle in the washer. After a heavy day's washinh, leave the door open a little to help dry it ou.
    May 28, 2009 | Washing Machines
    Black mold growing on gray rubber boot inside door.
    Leave washer door slightly ajar after use to air out any moisture. Should prevent any future mold.
    Apr 10, 2009 | Frigidaire Affinity ATF7000E Front Load...
    Frigidaire GLTF2940ES Front Load Washer
    Have you tried using detergent HE (High Efficientcy) for front loaders? I had this problem and changed over to HE Detergent (Tide) and it solved my problem. Good Luck
    John 3:16
    Dec 28, 2007 | Frigidaire GLTF2940ES Front Load Washer
    Frigidaire Affinity ATF6000F Front Load Washer Logo
    262 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Jason Harris
    Jason Harris
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
