Question about Foxconn Computers & Internet
Is my Mobo compatible with this GFX card???
I have bought this card but I am not sure if it will run on my motherboard.. MSI GT 620 1024MB GDDR3 Man Pt# N620GT-MD1GD3/LP When I tried to install it there was no post display and only beeps so I took it out and went back to using the onboard GFX... Please can somebody help me as the foxconn site doesnt seem to work properly whenever i try to access the technical help or customer support.....
  • darkloud
    darkloud Dec 30, 2012
    The board is MCP61SM2MA-ERS2H
  • Foxconn Master
  • 3,606 Answers
Hello here is your mainboards homepage:
http://www.foxconnchannel.com/ProductDetail.aspx?T=Motherboard&U=en-us0000223
Download the manual.
You will need adobe reader to read the content.
You might have to disable the onboard graphic in the bios when you install the graphic card.
Disable the driver for the onboard graphic or uninstall it before you install the new driver because the driver does not fit the new graphic card.
It will probably also help to upgrade the bios to the latest version
just make sure it`s the right mainboard.
Flashing the bios with the wrong one will destroy the mainboard !!!!!
If you are in doubt upgrading the bios let a expert do this for you.
You can download the latest driver here at nvidia:
http://www.nvidia.com/Download/index.aspx?lang=en-us
Just remember to select the right graphic card and your windows system.
Good luck
Posted on Dec 31, 2012
  • 33 Answers
SOURCE: MSI k8ngm2-h mobo doesn't recognize PCI-E slot anymore!
Just a suggestion for you to try.
This is to check whether your PCI-E card is ok or not.
The BIOS setting option should be on PCI Express.
Take out the power cable from the hard disk - we don't want to mess around with window driver or system that might be the culprit.
Now turn on the computer, if ok, you should see some texts on your screen. This is a confirmation that your PCI-E card is still working. So then for you to work on your windows to solve the problem. Good luck.
Posted on Feb 19, 2008
antiochpc
  • 1314 Answers
SOURCE: ASUS P4SP-MX motherboard no POST and no beep without ram
Try removing everything attached to it. The only thing should be the cpu and cpu fan. Turn it on. If it is the same, then it is your motherboard. If you do get the beeping, then start installing things one by one starting with the memory.
Posted on Jul 03, 2008
map9966
  • 2351 Answers
SOURCE: foxconn x38 motherboard support
Please give me the full model number of you're Foxconn mother board. If you no longer have the box the number will be on the motherboard.
Example of other Foxconn model numbers. (Foxconn 865A01-PE-6EKRS), (Foxconn 760GXK8MC), (Foxconn 661MX) & (Foxconn P9657AA-8KS2H).
Type the correct model number into the window to the left of Search. http://www.foxconnchannel.com/EN-US/product/Motherboards/detail_overview.aspx?ID=en-gb0000242
If you still need help just let me know!
Good Luck!
Mike
Posted on Jul 06, 2008
CMV9
  • 594 Answers
SOURCE: Onboard video not working
You need to download the drivers for either the onboard video card or the 9800gt video card to make them work.
Posted on Apr 17, 2009
  • 11 Answers
SOURCE: foxconn n15235 mobo will not post nd gives long beep
i think your motherboard is your problem... check your motherboard to other systems.
Posted on Apr 21, 2009
Bluetooth Question / MSI 890GXM-G65 Mobo .
Hello the homepage is here:
http://www.msi.com/product/mb/890GXM-G65.html#/?div=Manual
From here you can download the manual.
The mainboard will support bluetooth, as a add in pci card, or a usb bluetooth usb dongle.
You just have to make sure, the driver is available for your windows system.
Add in card, or a bluetooth dongle, can be bought in a computer shop.
Blutooth is not built in, as a standard feature.
Good luck
Mar 24, 2013 | MSI AM3 890GXMG65 Motherboard (7642010R)
AGP Card MSI MS-StarForce GeForce FX 5200 undetected.
for agp motherboards, you have to install agp mobo drivers, before you install the actual video card drivers.
May 25, 2010 | MSI MS-6734-10 (-6734-010) Motherboard
Intel D945GCZ, PCI-E video card
Mostly PCI-E now are good vga card, i have a tip for you... there's is a secret between a 512MB & 1GB PCI-E card. With this feature is required a good power supply, like for example I used Power Supply 550watts (original 500watts power supply). This power supply is different from 350watts and 500watts.. Here is a secret buy a 550 watts to boost PCI-E card both 512MB & 1GB. Secretly this performance are based on my own analysis using CPU booster freeware... I'm sure 100% more compatible & perfectly to your motherboard. Just try it at least you have idea where you want to grab PCI-E cards (any Model).
Dec 26, 2009 | Intel D945GCZ Motherboard
I bought a MSi 790gx-g65 mobo and an AMD Phenom II x4 940 which is am2+. Everything I've heard about this mobo is that it's am2+ and am3 capable, will the Phenom II am2+ I just bought work in this mobo?
Yes it will, but you'll need to update the bios to the latest one in order to be sure the processor is recognized. The 790 chipset will make that board an excellent performer with the Phenom 940. Give it as much dual channel ram as you can afford, up to the max of 4 gig for a 32 bit O/S or 64 gig for a 64 bit system.
Nov 10, 2009 | MSI AM3 790GX-G65 Motherboard for AM3/AM2+...
No signal problem with xfx 9400gt fatal1ty
Check for bios jumper set for normal operation, check for onboard vga jumper set for pci or external video.
Jul 14, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Nvidia geforce 9500 gt gpu work on asus p5n73-am
Hi!
Nahh...you can use that gpu with that mobo, but i wouldent recomend it. The GPU - Requires NVIDIA HybridPower™- enabled motherboard, and that mobo dosent have that. It might work but you cant use the full power of that gpu on that mobo. And beside that, that gpu is bigger then the mobo itself
I sugest you to buy another mobo, the gpu you looking at is a good one but your mobo isent that good.
Here is the spec for the GPU:
http://www.nvidia.com/object/product_geforce_9500gt_us.html
And here are the spec for that mobo:
http://shopping.msn.com/specs/asus-p5n73-am-motherboard-micro-atx-geforce-7050/itemid1060345734/?itemtext=itemname:asus-p5n73-am-motherboard-micro-atx-geforce-7050&fulldesc=1
Good luck
Nic
Mar 03, 2009 | Computers & Internet
No signal possible compatibility issue
Thats some nice items you have there M8!:) your machine gona rock when you done whit it!:)
And yes, the card is compatible whit your MoBo!
On your mobo you have 7 slots, 2 blue ones, they are PCI Express gen2 x16 slots , 2 white ones (the smal ones), they are 3 PCI Express gen2 x1 slots and 2 white ones (the large ones), they are 2 PCI slot, support 3.3V/ 5V PCI bus Interface.
The card you have you connect in the forst blue one, the second is if you waht to use 2 cards and drive them as crossfire.
So connect the card in the fist blue slot!
BTW, here is the link to MSI for your card
http://global.msi.com.tw/index.php?func=proddesc&maincat_no=1&cat2_no=170&cat3_no=&prod_no=1696
Dec 06, 2008 | Nvidia GeForce 9600 GT,, PCI Express...
Mobo and graphics card compatibility
They both should work fine on XP.
Go here for the drivers for your motherboard..
And, here is the most recent driver for the 8800gt straight from Nvidia.
Apr 06, 2008 | Intel Motherboard
GeForce 7600GS AGP 512MB card compatibility
it's hard to know,  it may be best to take your pc into a computer store and get them to test the compatability before you take it out of the store,  that way you can be sure that it works
Oct 13, 2007 | MSI nVidia GeForce 7600GS 256MB Dual DVI...
Computers & Internet Logo
57 people viewed this question
Top Foxconn Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
