Question about Garden
How to change the pullcord on my toro powerlite snowblower
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 30 Answers
Posted on Dec 31, 2012
SOURCE: the pull cord on my toro powerlite snowblower wont retract
my pullcord won't retract
Posted on Feb 04, 2009
heatman101
  • 43501 Answers
SOURCE: toro powerlite 98 cc 16" Mod no 38182 ser
Yes, you have a shear pin and that is probably the problem...
The shear pin often will not fall out and look like a normal piece but in fact be broken...
The shear pin usually is in the main shaft from the transmission to the auger drive...
Some are right on the auger its self...look around you will find it...
heatman101
Posted on Feb 26, 2011
SOURCE: toro snowblower wont start.I have a toro ccr
Reference the Toro snow blower. It may sound crazy but loosen the gas cap just a bit. I had the same issue with my snow blower and a friend gave me the solution. It works great now. Hope this works for you.
Posted on Oct 22, 2011
2strokeJim
  • 577 Answers
SOURCE: My toro snowblower keeps stalling. It starts up fine, but won't run continuously.
If you haven't already, dump out gas and put fresh in it and try this, if it doesn't work you will have to clean the carb, take it apart and clean all jets ports etc and put back together and you should be Good to Blow Snow, pretty common problem with Small Engines that set half the season.
Posted on Dec 04, 2011
Install scarper blade toro powerlite mod. 38182
On everyone I have ever seen, there are just three bolts that go through it into the auger housing. There is a notch that the scraper has that fits on to the end of the housing. You can see the drawing for it here - http://www.partstree.com/parts/?lc=toro_consumer&mn=38182%2C+Powerlite+Snowthrower%2C+2009+%28SN+290000001-290999999%29&dn=3358-429-383366-0008
I just picked one of the models for 38182 cause i think they are likely all the same, but if you want to be sure, use the list here - http://www.partstree.com/parts/?lc=Toro+Consumer&mn=38182 and choose the one that matches your serial number range. Then select the drawing to see the rotor assembly. Should be pretty easy except sometimes the heads of the bolts to keep the scraper on get wore down if the scraper bar wasn't changed when it should have been.
Jan 09, 2015 | Toro Power Clear 210R Part 38587
Toro snowblower wont start.I have a toro ccr powerlite that dosnt seem to be getting fuel from the fuel line into the carb. I took the fuel line off and fuel is getting to the carb so then i removed carb...
Oct 21, 2011 | Toro Lawn Mower With Toro Power Tools
My toro 1128 OE snow blower wont throw snow the auger turns but the thrower doesnt rotate. Does anybody have any suggestions
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Dec 26, 2009 | Toro Lawn Mower With Toro Power Tools
Toro powerlite snowblower sputters out after 10-15 minutes
I would change the spark plug and be sure to gap it as per your owner's manual. I would also clean or change the air filter. I would also use only high test gas and the oil recommended by the manufacturer. good luck.
Jan 14, 2009 | Mowtownusa Snow Thrower Starter Switch for...
The pull cord on my toro powerlite snowblower wont retract
YES YOU CAN JOE,Your recoil has come undone or the spring broke. but it can be fixed.richardm69
Jan 01, 2009 | Toro Blowers Rake and Vac - Electric...
How to change spake plug on powerlite snow blower
Remove the two screws holding the control panel to the machine. The spark plug is behind the panel.
Dec 23, 2008 | Toro Blowers Rake and Vac - Electric...
Garden Logo
88 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
