Question about Baumatic 27 in. B67 Gas Cooktop
Ignitors on all 5 rings wont stop sparking
Whilst cleaning the item the ring ignitors started to spark and eventually tripped the electricity which cut off. All rings checked and gas controllers checked to ensure they hadn't stuck down. When electricity put back on they continue to spark. Any suggestions, we are at a loss and need it sorting asap as unale to use oven as running off same power point.
  • duke 748 Jan 06, 2009
    when cooker is hot the igniter on bottom left burner fires.if i lift the heat adjuster it stops but begins again later
  • 76 Answers
You have a short in the ignition switches. these are located at the base of every stem under the knobs. In order to get to them you have to remove the entire cooktop, which entails removing all of the burners. The switches are run in parallel on a single harness.
Posted on Jul 21, 2007
6ya staff
SOURCE:
The igniter on my GE cooktop wont stop clicking, only if i unplug it.
Spark module part no 318 at parts diagram it may be wet and by using a hair dryer or leave it unplug for some days can dry out and stop. If not then the electric contacts are stuck and need a new spark module
Aug 27, 2011 | GE Profile JGP636 Gas Cooktop
2 of 5 burners do not start
The spark gap needs to have flow of gas across it for ignition to occur. The gas outlet holes at the point where the igniter sparks may be blocked, clean and inspect these for any blockages. Also check that the igniter spike is in the correct place. Careful evaluation of the position of the igniter in reference to the gas ring on the other rings may help you here. Good luck
Feb 02, 2008 | DCS CT-365 Gas Cooktop
My smeg cooker is brand new! after cleaning it - one of the rings will not ignite properly, it clicks so gas is coming through but no flame! any sugestions?
Brand new means you have a warranty, get the service agent to check.
I have found that you can easily place the wrong burner cap on the incorrect burner ring(the smaller burner caps).
Could also be dirt or water in burner ring or the burner jet(use needle to clear jet).
Are sparks coming from all ignitors? You might have damaged the spark plug.
May 01, 2010 | Smeg 23 in. SE64 Gas Cooktop
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
Ignitor sparks continuously
Hi, How long ago did you get the ignitors wet? Most cases, unplug the range for a few hours giving it time to dry out. Maybe set a fan near the range top to help dry it. This helps MOST of the time. please let me know if it helps or if I can assist you further.
Vic
Jul 04, 2009 | Cooktops
G.E Profile gas cook top #JGP640 ignitor.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 | GE Cooktops
Spark ignitors on gas stovetop wont stop sparking
Make sure yo haven't spilled liquid on the ignitor becuase this will cuase all ignitors to spark constantly. If all is dry, the spark module must be replaced.
Feb 15, 2009 | Cooktops
Gas ignitors continue to spark every 5 seconds in off position
try unplugging the unit over night, itspossible that by you cleaning the tops, the electrodes got wet, falsley sparkin, when the water dries out it should stop, and no not dangerous in any way, only annoying to listen to
Feb 13, 2009 | Amana AKS3040 Gas Cooktop
Spark ignitor won't stop clicking
the spacing between the ignitor and the plat is less the minimum. that will cause the ignitor to ignite prematurely. use a small screw driver or a nail filler clean out the space between the ignotor and the plat.
Dec 08, 2008 | Jenn-Air JED8430 Electric Cooktop
Viking cooktop disassembly
Well, it happened again. I'd replaced the spark module last time around, due to spillage getting into/onto that control unit. This time around, I had one burner that just kept sparking after it was lit. Cleaning the sparking post (emitter) didn't solve the problem, but I realized that there might be contamination elsewhere in the connect. I pulled the brass rings (nuts, really) and was able to lift the the top off. I carefully removed the individual sparking wires from each burner, and examined each assembly. After cleaning some debris off the male connector for that bad burner's spark assy, and reassembling the cooktop, it worked!
Things learned: The top can lift off without having to worry about dropping the entire unit. (This probably varies by model). The emitters _and_their_connectors_ are sensitive to contaminants. This was an EASY fix! Thanks for the helpful instructions everyone!
Nov 10, 2007 | Viking 31 in. VGSU101 Gas Cooktop
Baumatic 27 in. B67 Gas Cooktop Logo
594 people viewed this question
Top Baumatic Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Baumatic Cooktop Expert? Answer questions, earn points and help others
