Question about Dryers
Spring keeps coming off - Dryers
    Genius:
  • Dryers Master
  • 1,669 Answers
Put the end loop back wher it is supposed to be and close the end loop tightly over its pin with a pair of vice grips. If you can't get a grip on it that way., leave the loop off and use a pair of needle nosed plyers inside the loop to make it more of a closed loop.
Posted on Dec 31, 2012
When can I order a conical spring for the trigger?
Keep calling the company, somebody has to know where they can get you that 'spring', after all it's the customer service that makes a good company great ! Can you make one for a paper clip or something else, maybe a spring on a clothespin? Keep thinking, you'll come up with something.
Nov 06, 2014 | Microwave Ovens
Water is coming out where the cleaner is suppose to siphon from. Do you have a schematic of how that port should be , i.e the small spring and the bearing?
If water is coming out, then you just need to reverse the spring and ball bearing (swap them around). Right now, the spring is where ball bearing should be and this is keeping the ball bearing from seating against the o-ring inside. Shouldn't take more than a few minutes. Usually, the small end of the cone spring goes against the ball bearing.
May 07, 2014 | Coleman Garden
REPLACING STARTER SPRING/HUSQVARNA MODEL141
To rewind the spring is a bit of an art, hook the end of the spring into the stub on the starter, now start to wind each coil into the cover, making sure you keep your thumb on the coils you have wound in so as they do not spring out, otherwise order a new spring which will come pre wound in a keeper to make instalation very easy.
Apr 21, 2012 | Husqvarna Chain Saw 20" Bar
Drive spring
no if i knew what you meant by drive spring then i may be able to help but drive spring refers to a clockwork toy so please be more specific.
Dec 18, 2011 | Ariens Garden
Bostitch Rn46-1 Nail feed keeps coming dislodged when firing gun
The feeder will dislodge if the feed paw spring is weak or missing. Replace with new spring to keep the feeder paw in place. Visual test with good feed spring. Remove nails and open side door. Fire gun rapidly against hard rubber or coiled air hose. The feeder should move back and fourth in time with the piston/driver. If the feeder seems to move in slow motion compared to the driver, check feeder piston orings and feeder piston spring. If both feeder piston orings and spring are in good condition, then check air passage to feeder piston chamber for obstruction. Sometimes debris will lodge in white oring where body mates to nose of gun. Good luck
Jan 14, 2011 | Stanley Bostitch Rn461 Gun Coil Roofing...
How does the drum come off? Is there a a spring that you have to release on the inside?
I assume that you speak of a rear brake drum and no spring, just RUST so you have to back off the brake shoes a bit then hit the drum rather hard all around and look for movement like in its getting loose. Keep band and keep pulling it will come....eventualy. Just make that drum spins around if not keep backing off on the brake shoe because they can hold the drum in place
Sep 09, 2010 | 1990 Nissan Axxess
The spring has come out and we don't know where to put it
The Spring keep the Staples against the Stapler driving tool. Normally there is a metal pad to push against the staples, a rod that goes thru the Spring with a metal latch that locks inside the Stapler.
Jul 01, 2009 | Stanley Staple/Nail Gun Elec
Poulan Chain Saw (Model 2775) Handle keeps coming loose.
If it keeps coming loose, you could try some thread-locking solution on the screw to keep it in place. The spring is there as an anti-vibration measure (well a vibration reducer) so the saw is more comfortable to use and so it doesn't cause excessive fatigue through constant, high vibration transmitted through to the handle. You could of course remove the spring if you wanted to but the saw is likely to be pretty uncomfortable to use. Without seeing the saw in person however, there must be some reason the screw keeps loosening... See if you can find that issue and replace the affected part, or try some threadlocker in the meantime.
Mar 16, 2009 | Poulan Pro Chain Saw 46cc 20"
Hotpoint DWF61 Soap Tray Spring
Best way for checking it will be on your next machine's operation. Good luck!
Aug 31, 2007 | Hotpoint 24 in. DWF61 Built-in Dishwasher
Dryers Logo
52 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
