Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
When I depress the start button and hold the door will not "click" to lock so the load will not start. is this a simple relay replacement ?
  • Bosch Master
  • 17,130 Answers
This can be mostly related to the controller unit but you can start by checking manually the door lock and the door switch before we can suspect the controller or even the wiring to the door switch and lock.
There needs to be a feedback so that the program can RUN.
Posted on Dec 31, 2012
The DOOR LOCK light does not come on.
The error clearly indicates bad door switch. Very simple to fix, have to take top off and loosen switch from front panel. Remove and replace.
Part #131763245 and suggested retail price $50.
Thank you
Jul 23, 2010 | Frigidaire ATF6000ES Front Load Washer
The back door won't unlock or open and the front doors won't unlock by the remote
Simple enough to reset the power locking system:
1) make sure battery in remote is good, if in doubt replace it. Next unlock all the doors and keep them closed.
2) Jack up the car and you'll find the power lock reset button above the fuel tank. If you cant reach it drop the tank down slightly until you are able.
3) Depress the power lock reset button, then get inside the car and hold the unlock button on the remote for 2 min.
4) The system will reset when you get out of the car and hold the lock button for another 2 min while circling the car briskly.
Jul 02, 2010 | 2002 GMC Safari
When i push the start button on the remote nothing happens
I'm assuming you have a remote to lock/unlock your car with an added button to start the engine.
you need to have the doors in the lock position, then depress the lock button on the remote once then depress and hold the start button until the engine starts.diections should be on the back side of your remote.
hope this helps.
(this is how my GM car remote works)
Nov 03, 2009 | 2008 Buick Enclave
The dryer's control lock light stays on and can't start the dryer
I held the "End of Cycle " button for 3 seconds and the dryer reset itself. Pretty simple.
Jun 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When I push start it beeps 3 times. Lights on the right work, lights on the far left don't light up.
Alright, pretty unconventional, but simple and Genius on my part!!! Not sure if we're talking about the same models, but I was cruising this site with the same problem.... K, so it's making three beeps right? Check inside the DRYER (maybe same issue w/ washer, I dunno), but there's a button on the top-inside.... DEPRESS THAT BUTTON, and while holding it down, START THE DRYER (HOLD TO START), if it starts working, this tip is for you!
1) on the opposite side, where the door depresses that same button on the dryer door... you ready for this... see step two ;)
2) SUPER GLUE A PENNY IN THAT INDENTATION PART, your problem is there's not enough connection, and the door is no longer holding that same button down...
3) TA DAH!! Since a repair guy could've charged ya like 50+ bucks, I'll take... emmm.. 25$, email me at Kumatrev@yahoo.com on where to send the check, or just shoot me an email to say thanks ;)
May 29, 2009 | Kenmore Elite HE4 Electric Dryer
Oven door will not close because the door lock is on and flashing, also the oven light won't go off. how do I fix the door lock flashing so I can close the oven door completly?
is not actuallly physically closing??? perhaps the lock/ latch has partially engaged prevetning door from closing, and with the door oopen it cannot do anything for safety reasons. can you see a door /light switch thtyou can depress by hand??? if so push and hold it in the light should go out, and at this point continue to hold in switch and try starting a self clean cycle ( dont worry it wont actually start cleaning right away)it then should activet the latch assy to fully engage and suppoedly lock door, still depressing the button then press thecancel button and the latch should return to the normal resting position and you can close the door
Apr 03, 2008 | Ovens
My oven door will not close it has a lock button showing can't cancel
make and model??
Apr 01, 2008 | Kitchen Ranges
HE3t wont start
open the top access panel, 3 screws in top rear.
start washer
push up gently on one of the center black wired connectors that connect to the control unit (in back top of washer)
if it starts to work then the relays on the control circuit board need to be re-soldered . a normal reoccurring issue
its rarely the latch
Mar 21, 2008 | Kenmore Elite 45986 Front Load Washer
Door locked indicator light flashing
reposition the switch.. in the door
first try holding button at door with finger and press start..if same symptom appears...check tab that depresses that switch and if its good try to reposition or replace switch.
Feb 26, 2008 | Hotpoint WMA50 Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
246 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
