Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Purple light is on and cycle won't start
It's possible that you have put the dishwasher into delay mode. Try powering off at the powerpoint as this will force a reset of all programming.
The pause/start button also sets the Delay Start feature which can delay the start of a wash program
from 1 to 12 hours.
To cancel Delay Start
Press the I button.
Posted on Dec 31, 2012
Door won't lock / cycle won't start
Check if the lock is binding or the door switch is not being operated.
May 19, 2013 | Asko W6221 Front Load Washer
Portable emerson ice machine
The sensor in the bin that detects the ice to tell if its full could be bad. That or the control board.
May 12, 2013 | Kitchen Appliances - Others
Truck won't start
Sounds like you have several problems.
If the engine will not crank, do you have power on the purple wire on the small starter terminal when the key switch is in the start position ?
Apr 14, 2013 | 1995 GMC Sonoma
What does this mean? My machine is very new & won't drain it won't go through a full cycle & won't spin properly now it's bleeping with this flashing up on it!
Turn off machine and check water waste filter to see if blocked should be at front at bottom of machine or at back,not sure this is the cure but hope it helps
Apr 06, 2013 | Washing Machines
2009 HHR won't start. Battery is good.
Is the security light on or blinking?If not then do you have power to the starter.You can check this with a test light.You should have power when you turn the key to start.The test light should light up.Should be the small wire.I believe it is purple in color.If the security light is on then you will have to get the codes to see what is causing the no start.Hope this helps.Good luck.
Dec 07, 2011 | 2009 Chevrolet HHR
My 1996 Buck LeSabre won't turn over. I took the starter off and had it checked, it was fine. I checked the starter fuses and all was fine. \ Cabling was fine to the starter, voltage was 12.54...
Be sure the AIR BAG/VATS fuse 10 amp, is good. there is a STARTER ENABLE RELAY up high on the left of the steering column. I ASSUME the anti theft light is not flashing?" at the STARTER ENABLE RELAY the YELLOW wire is hot in the crank mode and comes out large PURPLE to the starter. the small purple wire is hot in the crank mode if the fuse (air bag/vats) is good. the small yellow is grounded through the park switch and the VATS module (anti theft)
Sep 21, 2011 | Buick LeSabre Cars & Trucks
Hello. My 1997 Chevy Tahoe refuses to start. The problems began with a bad fuel pump. I changed. It worked. The fuel pump died again. I changed it again and it has been working. I parked it for two weeks....
Now you have a good battery & a starter that turns over the motor
Have you cycled the key on & off with a fuel pressure gauge on the
fuel rail?
Do you have a fuel filter that isn't over 3 or 4 years old?
Have you checked for spark while cranking ? Use an old plug on the wires,
if you have ignition wires,don't ground the wire without resistance
If you removed the ducting & MAF Sensor it won't start
Tell us what you checked & exactly how that was done.
Jun 09, 2011 | 1997 Chevrolet Tahoe
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
174 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
