Audio Technica Audio-Technica AT4040 Professional Microphone Logo
Yahceal Posted on Dec 30, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My At 4040 just stopped working, no sound ?
I am going through an RME interface through the phantom input, I checked and ran my Shure SM58 and that works fine
Rick
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Audio Technica Expert 611 Answers
  • Posted on Feb 01, 2013
Rick
Level 2:
Prodigy:
Answers
611
Questions
0
Helped
162146
Points
680
Use a volt meter to measure the phantom power. Measure DC voltage between pins 2 and 1 and then between 3 and 1. They should measure the same and be between 12-48 volts dc.
\berenger microphone not working
Since you did NOT give us the model number of the Behringer mic, we can't do much to help... HOWEVER many of the mics are "condenser" mics that REQUIRE "Phantom" power from a mixer or preamp. These will NOT work without the phantom power being supplied. Look up your model number and see if it might be a condenser type.
Just got shure sm58, plug it into my starsinger on the tele but sounds is very low compared to the crappy mics? i plugged up a mixer box and can get more sound now but should it work fine with the...
The SM58 uses balanced output. If the starsinger uses a 1/4 inch jack, it is unbalanced input and probbly requires a high impedance rather than the low impedance SM58 mic. You can get an impedance transformer to fix that problem.
Neumann TLM mic is inoperative when connected to PA with same cable that worked with Shure SM 58 mic
The Shure SM58 is a dynamic microphone instead of the electret one Neumann TLM 103. This means that Shure does not need a phantom power supply voltage, instead of Neumann TLM 103; this one needs 48Volts. Here are the specifications for each one of the microphones: Shure SM 58 - Neumann TLM 103. In case you use a pre-amplifier or an audio console try to locate a switch marked as "Phantom Power" and turn it on. Typically there is no problem supplying a phantom power at the SM58. In case you have no phantom power switch available, either post back the mixer brand / model to check it for you, or post me a question to suggest you one. Details about the usage and the mixer you are already using will help me to clarify the total audio situation.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Shure sm58 mic stopped working ...
Check the wire connections where the xlr cable connects.
Shure SM58 Ticking Noise
Try turning off the phantom power required to use for the v67. Check connections on the 58 by removing the connector where the xlr connects, and making sure that's looks good. hope this helps.
I cannot hear myself on the microphone shure sm58
What sort of a preamp are u using this needs to be plugged into the lo impedance XLR input (this is a lo output dynamic mic 1.85Mv out)
The XLR should be input pin 2 return (gnd) pin 3.This mic does not NOT use phantom power (48v) if it is a dual input (pin 1 48v) source make sure the phantom power is turned of.
If this is being done then there maybe a problem with the mic.
You can check this by plugging a source in to the input to check that it is working line out from cd player midi or some other source.
biinary 6
1helpful
Lexicon Lamda Problem
I have a Sterling st-51 condenser mic and purchased a Behringer xenyx 1002b mixer. Similar problem, dynamic mics work in low impedence with or without phantom pwr on. My Washburn acoustic bass with preamp in line input section. So I tried it on my Omega Lexicon interface. The condenser mic and everything else works on the Omega. This unit has a wall wart ( your Lambda is USB powered). I checked the voltages with a meter and found 23 volts from the mixer and 48 volts from the Omega. Further, I have two Shure SM-82 line mics which work on the mixer with the inputs turned all the way down but do not work on the Omega nor on my Spirit SX mixer which has 48 volts phantom power. The SM-82s are old line mics that have a 9.6 volt battery in the sleeve. They overload badly in all but the 1002B mixer. Their voltage should run btwn the 9.6 battery or a 22 volt phantom power.
Check your Lambda voltage, It could be way less than needed by the st-51. I will check with a friend who has the Lambda and check its voltage. Bet it is too low.
Again, My St-51 and 1002B mixer combo barely works at 23volts, the Mic gain is all the way up as is the channel slider and the main output slider. I cant get any reading on my led meters, occasional bump on the first light, no possible way to clip the input or the output and have to turn the high eq off and the mid way back due to hiss noise. Hope this helps,couldn't find minimum voltages on the ST-51 as yet.
Tascam 2488
You'd plug the XLR connection into any of the first four inputs on the 2488 (labelled a to d). This is a dynamic mic so you don't need phantom power and should make sure your phantom power switch is off (out) on the 2488. You'd then assign the input you've chosen to a track, arm the track for recording, turn up the input level for that input to test the signal level, and record away by pressing record and play together.
Hope this helps.
bd.
No gain
happened to me too, I just fiddled with the phantom power button (wiggled it a little while it was pressed in) and my gain came back *shrug*
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
