Question about Thermador RES30 Electric Kitchen Range
RES 30 Thermador oven keeps turning off
When I turn on the oven, it starts to heat up, then it turns off on its own and display screen goes blank. When screen comes back on, time is displayed but oven is turned off.
5 Suggested Answers
siawolf
  • 749 Answers
SOURCE: Thermador 30" Dual-Fuel Range 0FF error
Make sure there is proper electrical power going to range. Then check your kitcen circuit breakers or fuse box in your house, then reset the oven controls.
LOL look what i found, a CHILD LOCKOUT FUNCTION-- check this out
TO SET CHILD LOCKOUT
Press and hold the COOK MIN/HR and STOP TIME buttons until indicator word OFF appears in the
display (approximately 6 seconds).
TO CANCEL THE CHILD LOCKOUT
Press and Hold the COOK MIN/HR and STOP TIME buttons until indicator word OFF disappears
from the display (approximately 6 seconds). Mode selections will now be available on the control panel.
looks like someones could have been playing with the buttons and locked you out..
Let me know what happen.........................please rate this
Posted on Oct 15, 2008
SOURCE: My thermador convection oven has an "off" message.
I turned the breaker to the range off.. then on, it cleared the message.
Posted on Jan 14, 2009
SOURCE: thermador range electric model ref 30
in pre heating the oven it does not go beyond 250 degrees. what could be the problem. I have a thermador 30 inch dual-fuel range (rdf30).
Posted on Feb 09, 2009
tony2155
  • 64 Answers
SOURCE: We have a Thermador PDR484GG with flashing blue lights!!!
one thing i found with the little blue flashing light is the main board in the back of the range not fun
Posted on Jul 01, 2009
Maytag cwe4800acb oven shuts off and display goes blank during heating
Display on maytag oven 8114p471-60 went blank - Fixya
www.fixya.com/.../t16018814-display_maytag_oven_8114p471_60_we...
Jan 20, 2013 - Stove top electric ignition still works fine, so there is power going to the .... maytag cwe4800acb oven shuts off and display goes blank during .
Oct 10, 2015 | Maytag CWE4800ACB 2.6 cu. ft. 24" Single...
Thermador SC301TS Neither oven nor broiler will heat up
most likely the thermal safety was activated and needs to be reset if not, you have a bad relay board.
Mar 02, 2013 | Thermador Ovens
My thermador double oven turns off once I heat both ovens for use, it will beep, turn off and display F34 in the display window. The appliance service man has been out to look and called the company and...
the problem is the fan is either bad or there's a screen near the fan,it could be blocked with dust but f34 is a problem with the cooling fan,the fan cools off the electronics and your machine is overheating and shutting down,check the fan
Oct 17, 2011 | Thermador CM302U Electric Double Oven
Thermador 30" wall oven.
Your touch in put key is stuck, replace ,power relay board and the touch panel
Always unplug the oven first before service
May 20, 2011 | Thermador C301U Electric Single Oven
My thermador double oven does not turn off for 30 minutes.
Welcome to FixYa.
Please clarify if I`ve misunderstood what you`re asking, but with all Thermador ranges and wall ovens ( including your SC302T model, most brands in fact ) the cooling fans will remain on for quite some time after actually shutting the oven off.
This is done by design to keep the electronics cooled to a temperature usually below 200°F so they aren`t damaged.
Heat after all is the thing which damages electronics more than anything else.
I do have use and care guides available via email attachments in "pdf" if you need one.
Thank you for choosing FixYa. I hope this eases your concern. Please let me know.
Regards,
Macmarkus :)
Sep 07, 2010 | Thermador SC302T Electric Double Oven
Thermador prd486edg oven/heating flashing 1/2and neither oven heats. help!
only code that is close ( e12) ( E12) look at display and make sure .. mm if the code is E12 then " CT oven:latch switch problem ) this may help Note E . 1 turn the clock selector knob to off 2 tweak the oven control by turning the clock selector slightly to the left ( counter clockwise ) this may stop the flashig message / beeping and clear the display window. " try it and pray mm .
Dec 09, 2009 | Thermador PG304BS Gas Kitchen Range
Thermador professional
I had the exact same problem. I read someone else turned off the circuit breaker in the electrical panel.. so I tried that. Flipped breaker off for 30 seconds and then turned back on. Oven now works perfectly as before. Go figure??
Oct 19, 2008 | Thermador PG486GEBS Stainless Steel...
Thermador range electric model ref 30
Feb 16, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Thermador oven/broiler turns off after 5-8 seconds
two things come to mind a faulty safty valve thats the device that the ignighters connect to the other maybe trash stopping the screen on the pressure regulater are any codes displayed on the clock
Jan 30, 2008 | Thermador PRG304US Gas Kitchen Range
Thermador RES30 Electric Kitchen Range Logo
44 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
