Question about Magellan Roadmate 9055-lm Gps Navigator
Unity will not boot up
When the unit is turned on i get a picture of a computer with a USB cable to a GPS unit with a red X. When i connect the unit to the computer with the supplied USB Cable the red X goes away but nothing else happens.
Raheeeeb
  • 20 Answers
SOURCE: 3000t download music from computer
1- check that you install teh driver for it 2- chekc the usb cable 3- may be teh socket of usb is damaged
Posted on Aug 10, 2007
  • 11 Answers
SOURCE: stuck on USB display screen
U WON'T BE ABLE TO DO IT. U NEED TO DOWNLOAD THE SOFTWARE FIRST AND THEN FORMAT F: DRIVE. .
Posted on May 13, 2008
  • 4 Answers
SOURCE: I'm trying to download software to my Sportrak Map
USER MANUALS AT
http://www.magellangps.com/assets/manuals/SporTrak_series_en.pdf
...COINWAGON@YAHOO.COM
Posted on Mar 31, 2009
  • 4 Answers
SOURCE: need to connect NMEA0183 to radio
Thank you for your quick respond.
I downloaded the owners manual and it had all the informaion I needed.
Posted on May 24, 2009
SOURCE: magellan explorist 400 gps won't power up with usb cable
fhfj
Posted on Jan 31, 2010
Cannot get the unit to go to the main page. USB does not even show up in my computer file
using the USB to connect the gps is for transferring files and updates, you will not see the map while using the usb connection.... you can charge the unit this way but it may take 3 to 4 hours to fully charge..
to connect to computer.... Turn the gps Off.... connect the USB cable to computer... the computer will then dedect new hardware (usb) a pop up box will appear
Nov 17, 2010 | Garmin Nuvi 660 GPS Receiver
How do I update my maps. All I have is the cable that connects from the USB on the back of the GPS to the cigarette lighter in my car
You need a mini-USB to computer USB cable..... ( most cameras use this same USB cable to connect to a computer)
with the unit off
plug in the mini-USB to gps and connect to computer USB port
the computer will detect new hardware
now go to www.MyGarmin.com
it will ask you to register, its free....
Garmin will detect your model and let you update your maps and firmware
it will also tell you to download WebUpDater utility to transfer to your gps
Nov 03, 2010 | Garmin nuvi 205W GPS Receiver
Does this come with a usb cable? Not sure how to hook up.
Not sure if it does, some may come with one, its the same USB cable that you hook up your camera with to a computer......
The USB to Mini-USB cable is to download maps and updates for your unit and transfer media to your Garmin
When you get your Garmin you need to register the unit with Garmin so the maps will unlock, this is how you would do it below....
With the Garmin unit off.... connect the mini-usb to gps then connect other USB end to computer
your computer will detect the connection
now go to www.MyGarmin.com the site will also detect what unit you have and let you unlock the map
here is where you register your unit and unlock maps
Oct 30, 2010 | Garmin Nuvi 660 GPS Receiver
When I charge my nuvi 200 a picture of a computer modem connected to the unit is displayed
It's normal.
Becouse you use 4 wire usb cable.
And nuvi mounted as a drive to OS.
If to use 2-wire cable like for car lighter-it won't show the picture.
Feb 06, 2010 | Garmin nuvi 200W GPS Receiver
I need help. How do I connect my GPS to my desktop computer without a usb cable which only has a vehicle power cable?
the only way to connect it to your computer is with a USB cable..if you did not get one with you garmin, one from a similar device, such as a digital camera will work...its a usb to mini usb cable like the one pictured below.
Dec 15, 2009 | Garmin nuvi 1200 Car GPS Receiver
Computer does not recognize it
assuming your using a windows xp or 2000 os, try another cable if you have one..turn the gps off, plug in the usb cord and restart the gps. if that fails, if the cable is connected to a port on the front of the computer,move the usb cable to a rear port on the computer and try the previous way i just explained.
if those fail, disconnect all usb devises connected to the pc and restart the computer and try again. (always use a rear port on the pc if you can)
good luck
Aug 03, 2009 | Magellan Maestro 4040 GPS Receiver
Garmin 760 doesn't work while charing
There is nothing wrong with your gps unit so you can relax and prepare for your trip!
While your unit is connected to the computer via usb cable as in recharging, you cannot operate it as a gps at the same time.
You will find that once the usb cable is disconnected that your unit is working normally.
Enjoy yourself.
Jul 31, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
GPS doesnt turn on with power cord adaptor or 12v lighter socket
if you can verify that the car charger is ok, try plugging it in to your computer using the usb cable. the 1412 should charge with the usb cable. if it still doesnt turn on, try and reset the unit,little pin hole on the side.
Jun 08, 2009 | Magellan RoadMate 1412 Car GPS Receiver
Unit doesn't work with vehicle power cable
if you are using the USB cable, that won't work. You must use the bracket plug. the USB cable will charge the unit and you can't use it while it's charging. If using the USB, the system thinks you are either charging the unit or connected to a computer. This is a design flaw.
Jul 04, 2008 | Garmin nuvi 200W GPS Receiver
How to charge garmin c330 gps from computer
The unit came with a USB cable. Plug this into the GPS (when it is turned off) and it will come on and the unit will charge while showing an image of the GPS connected to a computer tower.
Mar 19, 2008 | Garmin StreetPilot C330 GPS Receiver
Magellan Roadmate 9055-lm Gps Navigator Logo
16 people viewed this question
Top Magellan Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Magellan Audio Player and Recorder Expert? Answer questions, earn points and help others
