Question about Hoover U6634-900 WindTunnel Bagless Upright Vacuum
Hoover windtunnel u6634-900
I took roller off and cleaned up when i put back together the roller will not spin....the belt appears to be in good condition.....
  • conormcpeake Feb 09, 2009
    I have seme problem
I have the same problem. I believe, after some inspection, that the mechanism which allows for the circular spin of the brush has failed. Though I'm no mechanic, I believe my girlfriend's long (and beautiful) hair became entangled underneath the gray "end-cap" causing breakage of the rotating mechanism (which I believe is normally housed within the brush under the rectangular "end-cap"...the other "end-cap" piece is circular). Now the brush will spin about 6 rotations but with each spin the gray "end-cap" will extend on its screw rather than spinning freely. I believe my only option is to order another brush. We'll see if it solves the problem.
Posted on Jul 11, 2007
SOURCE:
Hoover windtunnel U5453-900.belt melted put another belt on brush was spinning.Brush spins but not easily.It spins then stops therefore burns the belt.How can i get the brush to spin around better
Kristie,
I would suggest taking the brush bearings at each end off and clean any lint or hair that might be in the ends of the brush. If you have regular ball bearings on your brush, you might need to replace the brush roller if the bearings themselves are tight. Hope this helps!
Apr 05, 2015 | Hoover Vacuums
Hoover UH70935 windtunnel agitator spins like crazy with plate off after cleaning but will not with plate replaced.... what is going on?
If the brush roller was removed, it may have been reinstalled incorrectly, causing it to bind on the bottom plate.
Aug 08, 2014 | Hoover WindTunnel 3 Pro Pet Bagless...
Hoover U6637-960 the self propel is not not working. When lowering the handle it acts like it would like to work but the roller will not turn. appears to be something to do with the self propel part of the...
This vac has 2 belts. If both self propel and roller not spinning then most likely it is the wide flat belt broken or off. 4 screws on the bottom should gain you access to the belt area. another issue for this model series is a worn pulley on the roller, a new belt when inserted around the roller should be even with the top of the pulley groove.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Apr 17, 2010 | Hoover U6630-900 WindTunnel Bagless...
I have hoover WindTunnel Self Propelled Vacuum
Greetings from GoVacuum,
Here's a great video repair tutorial that we've put together to try and help you with the repair on your Hoover WindTunnel. I hope that this helps you with your repair. If you found this solution helpful, please rate this repair video by clicking on the 4 Thumbs Up Icons in the top right hand corner of my repair solution. Feel free to email me at [email protected] if you have any questions about the repair!
Video Repair of Hoover Windtunnel Belt Change
Thank you very much!
Chris Jones
GoVacuum.com
Dec 18, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush roller on windtunnel won't spin
It sounds like you need to replace the actuator arm or the cable to it. Look for Hoover part 43143046 for a start. I've got a similar problem.
Mar 21, 2009 | Vacuums
Roller Belt Keeps Slipping Off
You could try contacting Hoover for parts availability. If it's and older WindTunnel and Hoover no longer has the part, try eBay.
May 14, 2017 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover windtunnel vacuum belt
There are 4 screws that you need to remove. The belt lies between the roller and a pin. With a little effort, you just pull out the roller, and the belt will come loose. When putting the new belt, you need to insert the belt into the pin first and then put the other end of the belt onto the roller. Then pull the roller and put it back into its groove. Voila!
Aug 19, 2008 | Vacuums
Hoover U6634-900 WindTunnel Bagless Upright Vacuum Logo
396 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
