Question about Maytag Neptune MDG6800 Gas Dryer
Dryer heats up but heat turns off after 5-10minutes. dryer still runs. If the dryer is unplugged and plugged back in it will heat up for 5-10 minutes and heat shuts off during the cycle again.
  • James Smith
    James Smith Jan 01, 2013
    model number MGD6800AWW
  • Charlie Lapinski Feb 08, 2013
    did Shelby Gemsamer helped you a lot or not at all
Illeagle
  • 525 Answers
SOURCE: Maytag MDG7600AW Gas Dryer heat starts and then stops
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance. Clicking on the underlined links will take you directly to that page.
If your dryer doesn't heat properly, check this: Venting restriction: Disconnect the dryer temporarily from the vent. If the flame stays on for a longer period, you may have an air flow obstruction to the outside. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Also, in your case, the coils may work fine initially, but heat build up can cause the coil(s) to malfunction and when they cool down will work again.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3479&PPStack=1
This link will help you with disassembly and diagnostics diagrams.
http://www.repairclinic.com/0100_17.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
TheMobilian
  • 8220 Answers
SOURCE: gas dryer maytag MDG 7600 AWW Heats - then shuts off
Replace the coils READ THIS!!!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 14, 2009
SOURCE: Maytag Neptune MDG 5500 AWQ heats sporatically
GAS DRYER WORK FOR MINUTES AND THAN STOPS!
Posted on Apr 19, 2009
Healeyman
  • 1198 Answers
SOURCE: maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
Posted on Apr 28, 2009
  • 3 Answers
SOURCE: MDG5500AWQ - Heat shuts off after 10 minutes. Have
If ignitor continues to cycle on and off like normal but no flame, coils on gas valve are bad.
Posted on Jun 24, 2009
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
Dx2300 shuts off after 10 minutes. Will turn back on. is heating
Sounds like a high limit temerature sensor. Could still have air flow blockage inside the dryer or faulty sensor.
Mar 05, 2013 | Dryers
Frigidaire Affinity AEQ6700FSO electric dryer does not heat, then shuts off within 10 minutes.
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
Feb 05, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Hi I have a dryer model # GLEQ215ES1 The dryer will run proper if I turn the heat off, but when heat is on it only runs for about 10 minutes and shuts off and all the lights on the right side blink.. Any...
It sounds like the hi-limit thermostat. For your dryer that would be Frigidaire part number 5303281113 shown below. The part is located behind the drum. You will need to take the back off of the unit to access the part. Sears carries the part.
  1. Take the back cover off of the dryer
  2. locate the part
  3. unplug one of the two wires from the old part
  4. plug that wire into the same post on the new part
  5. unplug the remaining wire from the old part
  6. plug the other wire into the new part
  7. unfasten and remove the old thermostat (with no wires)
  8. fasten the new part (with wires) into the old parts place
  9. run the dryer to see if the fix works
  10. replace the back cover on the dryer.
Steps 3 through 6 above insures that you get the two wires installed correctly. ddmagee57.jpg
Apr 27, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Whirlpool Estate gas clothes dryer runs but the heat only lasts for about 10 minutes. the drum will be turning the heat will be on but only for about 10 minutes.After 10 minutes the drum will still be...
The gas coils have failed. These are the two round devices on the gas valve. You would need to open the dryer to access and replace the gas valves. Every make and model is different.
With the model number I would be able to better assist you.
Mar 31, 2011 | Whirlpool Dryers
Pushed dial, dryer would not start. Heating coil on, can feel the heat and hear ticking.
If the heating elemnts are coming on but the drum is not spining then the motor could be bad or the belt could be broken that turns the drum. The motor could also be on a thermal overload in this case unplug the dryer or turn off the circuit breaker for 15 minutes and let everything cool down. After turn the breaker back on or plug it back in and give it a try if you hear the motor running but the drum is not spinning then the belt is probably broken and will have to be replaced.
Jan 12, 2010 | Whirlpool LER4634J Electric Dryer
Dryer will only run for 10 minutes at a time
Hi, this is heat related. the timer module on this unit is overheating, in return, it is shutting down due to the heat generated but the faulty timer circuits. you will need to replace the timer device asap.
May 27, 2009 | Kenmore 73952 Gas Dryer
Dryer heats for 10 minutes and turns off
Turn the dryer on, go out to the where the vent exits the house. Feel the air coming out, and it should blow very strong, and for the total diameter of the discharge. If it doesn't, the vent pipe is plugged, or the connection hose from wall to dryer is crimped/collapsed when pushed back to the wall.
Also make sure lint filter is clean, and the grill inside the dryer where hot air enters is clear.
Reply back your findings and I can help you more.
Jan 29, 2009 | Dryers
Kenmore 80 series model 110.79812990 the unit will start at cold the heat will run a few cycle and the no more heat , the pipe going out is clean and free of any obstruction , then if you unplug anr...
First UN-PLUG the Dryer... Then U can take the Back Panel off, and I would bet that there is Lint Built up in the Back... get the Vacuim and Clean the Back really well.. Sounds like the Dryer is Heating up, and the Sensors are detecting a Buildup of lint... Try that, and see if it Helps...
Oct 26, 2008 | Dryers
Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Feb 28, 2008 | Kenmore 64952 Electric Dryer
Maytag Neptune MDG6800 Gas Dryer Logo
42 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
