Question about Toshiba Canvio 500 GB USB 3.0 Basics Portable Hard Drive -
How do i install canvio basics 3.0 external hard drive?
I cannot find setup exe file
  • 73 Answers
SOURCE: Transferring Files to External Hard drive
I would suggest you find a backup program to do all this for you. I use EZBackItUp (http://www.rdcomp.net/ezbackitup/) a nice freeware program that is easy to set up. Once the files are backed up, though, you should not delete them from your C: drive, as the program will them delete them from the backup too. What you should try to do is move big files (movies, music, etc) to the external drive, which will give you more space on your C: drive. And, as always, make sure you run a good cleaning program (http://www.ccleaner.com for a great one, download and install) to reclaim some disk space.
Good Luck, and I applaud you for having a backup!
Posted on Dec 22, 2008
bronk50
  • 27725 Answers
SOURCE: Toshiba external hard drive one files were not
try selct file right click send to
Posted on Jul 27, 2010
jcameo7270
  • 675 Answers
SOURCE: How do I reformat my
The disk utility programs should be on the main drive inside the computer...you need to make sure you tell the program which drive you want to erase..Say the external drive comes up as drive "d"..then you want to tell the drive utility software to erase the "d" drive
Posted on Dec 25, 2010
  • 240 Answers
SOURCE: I have a toshiba canvio 320GB external hard drive
Hi. Thanks for your question.
  • Here's what else you can do.
  1. Check the USB cable. Make sure it's connected securely. to make sure test with other device or computer to determine that cable is OK.
  2. Once you know you are using good cable you need to make sure that Hard Drive isn't at fault. Trying to use it in other PC is the best method of making sure that everything is OK with it.
Do not hesitate to come back and ask more if none of these solutions helped you. I am sure one of FixYa expert's will be able to help you.
Thank You for using FixYa.
Posted on Jan 17, 2011
  • 7 Answers
SOURCE: How to format a Toshiba
Just make sure you have any and all data that you want saved moved elsewhere before proceeding.
Posted on May 06, 2011
How do I save files to my Toshiba canvio slim 11 portable external hard drive
you should find someone local to help you out with that, its a little complicated to explain via text. its not a complicated process, there are just a few different ways to do it, depending on how many files you need to back up.
1. find the file you want to copy (this could be a folder, too).
2. right click and select "copy"
3. go to "computer" or "my computer" and double click the toshiba drive.
4. right click and select "paste" and that will copy it.
as i said, there are other ways of copying files, but that's probably the simplest way, although not necessarily the easiest, if you have a lot of files.
Jan 21, 2015 | Toshiba Canvio 500 GB USB 20 Portable...
How do I retrieve my files from Canvio Basics 3.0?
The usual way to back up files is to just open my computer and open the drive that is the external hard disk and just drag and copy the files over. You would then do the same this king to drag the files back to your computer. I am assuming you did not do this and usedsome software that came wwith the drive. In that case I would still open the drive in my computer to see if its there or otherwise u need to use the same software u used to backup the files to recoverthem. If you ccan't figure it out I would redo saving the files the normal way like I explained before . An internal hard drive or even external storage device like USB thumb drive simply shows upas a new drive when plugged in. Do not use an software to save files as usually they are proprietary and use compression which is iinconvenient or makes it difficult to recover
Jul 24, 2014 | Toshiba 1TB CANVIO BASICS EXTERNAL USB 3.0...
I cannot drag files in the Toshiba Canvio Basics 2,0 TB
Please test it by cutting a data file and pasting it in this hard drive. If it is success, then probably the type of your data is different and it is not freely moveable, or you it is possible that you tried to move the files to the same folder (it happens when the user opens many Windows Explorer/File Manager).
Mar 03, 2014 | Toshiba Canvio Computers & Internet
Omnitech not find exe file
Dear Gxp_mc16,
Can you open your external and see all files? If you can open it and can access any other files inside the external drive then the problem will have more chances to resolve. For the first step you might need to try this software: https://www.findandmount.com/ download it and install it on your computer and follow the steps. If the problem is not too serious the software will solve it.
My case two weeks ago with Canvio 3.0 500GB was even more difficult. I could not see and access my external after my computer crashed and the external attached to it. My Windows OS computer always ask me to "reformat" the external drive. I tried it with other computers all with WIN 7 OS, same problem. My external need to be reformat. It made me crazy because there are too many important files in it. Then I met this software http://www.easeus.com/ . I Install the software and I scan the external for the whole night (about 8 hours). Luckily, all my files could be recovered and accessed although it is separated. Then I copied all important files into my internal drive. Then I reformatted the Canvio. Until now I am still using it without any problem.
Feb 19, 2014 | Toshiba Computers & Internet
Will the toshiba canvio desktop 3tb hard drive work with the LG 47LM6700 tv?
Depends on the format your hard drives in (personally I'd just use a PC with an HDMI cable) and whether your TV supports USB file reading.
Nov 30, 2013 | Toshiba 3tb Canvio Desktop External Hd
How do you remove a file from the external hard drive
Hello tyearms
First, are you on mac or windows system?
Thank you
Nov 19, 2012 | Toshiba HDTB103XK3AA 320GB Canvio Basics...
Toshina External Hard Drive backup files in
Which program did you create the backup with? You'll need to install a copy of that software on your new computer. Then you will let the software find the backup and restore it. This will only work if you used a file backup. Many backup programs do not restore to systems with different hardware (different CPU, hard drive, OS, etc.).
However, I don't know which software uses *. PFT, pfi or pfp extensions. PBF is the format for one of the older Paragon Backup software versions. Acronis uses *.TIB . For a list of many of the software extensions used for backups, see https://www.file-extensions.org/filetype/extension/name/backup-files .
Canvio drives used to include NTI BackupNow EZ software. However, I believe that NTI backups use BJF or NTI extensions. The installer for that is here: http://support.toshiba.com/sscontent?contentId=3044104 . To check for other software for your external drive, try looking up your drive at http://support.toshiba.com/support/home . The available drivers and software should be listed. Alternatively, check if the backup software installer is still on the external drive.
I hope this helps.
Mar 03, 2017 | Toshiba Canvio Plus 320 GB 2.0 Portable...
How to install microsoft visual basic 6.0
  • Open the Web page for Microsoft Visual Studio on your computer.
  • 2 Start the download by clicking the "Download" button. Put the file somewhere where you can find it easily, such as your desktop.
  • 3 Locate the setup file "vbrun60sp5.exe" on your hard drive.
  • 4 Double click the setup file to start the installation wizard.
  • 5 Read the license agreement and click the "accept" box to begin installation.
  • 6 Follow the instructions provided by the installation wizard to install the program.
  • Read more: How to Install Visual Basic 6 ' eHow.com http://www.ehow.com/how_5896501_install-visual-basic-6.html#ixzz16RqHSTGS
    Nov 27, 2010 | Microsoft Visual Basic 6.0 for PC
    Toshiba Canvio 500 GB USB 3.0 Basics Portable Hard Drive - Logo
    604 people viewed this question
    Top Toshiba Computers & Internet Experts
    k24674
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
