Thomson A3305 Disc tray stuck closed
The open and close feature is not working and a "error" message appears
  • 275 Answers
SOURCE: CD player problem
Seems like the Timingfor the Tray Open / close has got disturebed. Could be a bad drive gear, or as simple as a loose Drive belt. Get it checked by a professional.
Posted on Sep 20, 2006
techman
  • 3130 Answers
SOURCE: ERROR, NO DISK
No if the cleaning does not work, you will need to have the unit hooked up to test equipment to check if the laser is bad. It could also be a bad spindle motor if the unit will not spin. good Luck
Posted on Mar 16, 2007
SOURCE: Locked dvd tray.
To unlock, manually press and HOLD the open/close button & the stop button simultaneously, and HOLD them both down until the lock picture disappears.   The DVD will eject when you press the open/close button.
To lock the DVD inside the machine, repeat the same step, and it will lock it inside.
Posted on Oct 20, 2007
spare_head_2
  • 47 Answers
Hi SoraTotoro,
This sounds like the child lock has been inadvertently activated . Look through the manual to find the key combination to unlock it.
Hope this helps.
Spare head 2.
Posted on Jan 06, 2008
SOURCE: cd door won't open
I just bought the same system a week ago and my stereo door is completely broke and the cd peice doesn't eject
Posted on Mar 22, 2008
How can I unlock Samsung HT-H4500R
1) Turn on the player with no disc in the tray.
2) Open then close the tray, wait to see the No-Disc Message
in the top Left Corner.
3) Now press the REPEAT button on the remote, followed by a
five digit code. eg. 57538 if you have a region 2 player.
4) When it works a 2 (your current region) will appear in
the top left corner.
5) Press 9 to make it region less.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all
regions of DVD/BD Disc.
Here is a list of all the region codes:
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
Aug 25, 2014 | Samsung Televison & Video
416b-4174-b680-0f00-c000-0034
I had this error code as well. Here's the solution that ended up working for me:
  1. Eject the disc tray and remove any disc from the console.
  2. Important: Do not close the disc tray. Leave it open.
  3. With the disc tray open, remove the power cord from the back of the console.
  4. Gently push the disc tray about half-way back into the console.
  5. Plug the power cord back into the console.
  6. Push the power button on the console. The tray should close the rest of the way, then the console should restart and display the Xbox Dashboard.
  7. Important Do not use the controller or the disc eject button to turn on the console.
  8. Try updating your console software again.
What this does is put the DVD drive into Mode-B, which is an alternate operating state that allows the drive's physical memory banks to be flashed with new firmware. Because the latest XBL update involves flashing the drive with new firmware, you may need to physically put the drive in Mode-B. The latest update flashes the drive to make it compatible with Microsoft's new high-capacity disc format, XGD3, which will be used sometime in the future.
Jun 10, 2014 | Microsoft Xbox 360 Console
Tray error on a denon dn 4000
The cd transport is up the swanny (broken , kaput).
take it to your nearest registered denon repair/service centre
Sep 05, 2012 | Audio Players & Recorders
Hi - the CD tray cannot open. It is empty - no CDs in there. I hear a buzz, but an "error" message comes on. I tried pushing on the tray while turning on; I unplgged the CD player, I put it on...
The loading tray belt has more than likely stretched or snapped.
The buzzing you hear will be the motor spinning freely.
The 'ERROR' message will show up because the tray isn't opening
and activating the 'tray open' switch, therefore the 'tray closed' switch
is permanently activated after the 'open/close button is pressed.
Aug 20, 2011 | Marantz CC-4300 5-Disc CD Changer
I am getting the locked display
Hi Blackhawk,
This sounds like you've accidentally set the "tray lock" feature.
You can set this to stop unwanted tray ejections:
I hope this solves your problem..
Warm Regards
Mike
Nov 28, 2009 | JVC TH-M303 System
My cd is stuck in macbook and is not being read by my computer it only makes a funny sound when i reload it
A CD or DVD disc can become stuck in your Macintosh. It may not be appearing on your desktop or could be causing the computer to lock up if the computer cannot recognize it properly.
[edit] Solutions
  • First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu.
  • If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X.
  • Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared.
  • If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar.
  • Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder
  • Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button.
  • Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism.
  • Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray.
  • Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. )
  • If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Sep 30, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
REGION 2 DVDS ON REGION 1 PLAYER
Wait till the unit is at the Samsung logo screen.
2) Open then close the tray, wait to see the No-Disc Message in the top Left Corner
3) Now press the REPEAT button on the remote, followed by a five digit code.
In this case Repeat 29334
4) When it works a 1 will appear in the top left corner
5) Press 9 to make it regionless.
9) Now power the unit on again, it should now read all regions of DVD Disc.
Enjoy
Jul 18, 2009 | Samsung DVD-1080P9 DVD Player
Region error message
Switch player on and make sure there is no disc in the tray.
CLose tray and press menu,1,9.
A menu should appear with the region option at about the third line from the bottom. Press enter and enter the region you want. Next press open/close. Put in your movie and enjoy.
Aug 12, 2008 | Cyberhome CH-DVD 300 DVD Player
Sanyo 6100 dvd player-disc tray automatically opens whenever power is on.
you should try inspecting & servicing the tray transport mech first and then the tray sense swt.
Dec 08, 2006 | Sanyo DVW-6100 DVD Player/VCR
42 people viewed this question
 Grubhead
Grubhead
