Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Washer door locking mechanism
The locking mechanism in the the machine (the part the door latch hooks into, to lock) fell off into the inside of the front panel. How do you remove the front of the machine to retrieve and re-attach it?
  • 641 Answers
SOURCE: "Door Locked" Indicator Switch Faulty
You should access the lid switch (the switch is inside the machine main housing near the door frame) and to see whether it become loose or was broken. Good luck!
Posted on Aug 21, 2007
  • 1894 Answers
SOURCE: washer door latch
the door latch may have gone bad
test it by pressing with some sharp object like pen
Posted on Jun 24, 2008
  • 4 Answers
SOURCE: Fron t Load washer will not unlock
Here is the web link service manaul for your washer below. Go to troubleshooting guide. You can drain and unlock your door by using the test mode in the service manual.
http://136.166.4.200/contents/Laundry/WM2042/WM2042xx_Service_Manual.pdf
Posted on Oct 13, 2008
  • 4 Answers
SOURCE: LG WM0642H*
Remove the 4 dispenser area screws. Depress side dispenser tabs to drop dispenser assembly from the top lid .Insert an opener or flat item into top lid and front panel space to depress inward the metal lid top hold down clip.Do left side first then right.Raise the lid and look down behind lock mechanism.Or tilt washer and look underneath. It's an open area below?
Posted on Jun 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: LG TROMM -WM1814CW I bought the washer and dryer
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@(((
Posted on Sep 28, 2010
The front door won't close, due to washer lock mechanism restricting door close.
Thank you for your inquiry, kh57ca!
From what you are describing it sounds like the door latch assembly needs to be replaced. This is not a simple DIY job though. I would recommend seeking guidance from a professional technician to properly replace the door latch to avoid any future issues. Some of these intricate parts require precision and patience, therefore when replacing such components or removing them from your appliance, I would suggest seeking professional assistance. I hope this has been beneficial. -Matt
Oct 12, 2014 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
My washer door will not open its a wd645 model i cant find the lever when i took lid off
Hi.
The door latch is probably broken. Emergency opening can be done accessing the door latch from the inside of the washer assembly.
Before attempting an emergency opening, disconnect power cord and empty water inside the machine through the filter located at the bottom front side of the machine.
After removing water connect back the machine and try opening again.
If that does not work, then the machine must be disassembled. Most models have an emergency cable located on the inside of the door latch. Pulling the cable will release the latch.
The inside of the door latch is reached either from filter housing or from top of the machine. Either the filter (usually held by screws) or the top panel must be removed to access the inside of the lock mechanism.
Power must be kept off while doing maintenance. Due to the safety issues involved the door latch emergency opening and repair must be done by a trained technician.
Regards.
Ginko
Dec 15, 2011 | Hotpoint -Ariston Aquarius WD645 Front...
Door is locked will not open
Potential Causes
Door Lock Mechanism broken. • Check Door Lock/Switch Assembly for foreign objects • Check Wire Harness connections to the Door Lock/Switch Assembly and Central
Control Unit (CCU) • Door Lock/Switch Assembly Failure
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet. 2. Remove the lower toe panel. 3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly. 4. Located on the bottom of the door latch assembly is a tear-drop shaped tab. 5. Gently pull the tab down about 1⁄4" or until a click is heard. 6. The door may now be opened.
Feb 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door lock failure
The door latch is controlled by the Central Control Unit (CCU). If you've already replaced the door and you're still experiencing problems, you need to re-verify your electrical connections and check the CCU. There is a technical data sheet inside the washer that explains how to troublehsoot the CCU in more detail. You will need to remove the lower lick panel directly below the door. The tech sheet will either be behind the lower panel, or located along one of the interior cabinet walls. There is a relay on the CCU that controls the locking mechanism. If this relay goes bad, the CCU needs to be replaced.
Replacement parts (if required) can be purchased on line at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
This still does not rule out the possibility that you may have purchased a bad door latch (it happens). You can prove the latch by leaving it installed and following the troubleshooting steps in the tech sheet.
In addition, make sure the door hook is not damaged. If the latch cannot latch on to the hook, the door will not latch properly.
If you have any questions, please let me know. I hope you find this information helpful.
NOTE: Refer to the parts websites for some excellent exploded view diagrams of your washer for reference in locating parts if you need assistance.
Aug 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How do I fix my washer with an F-22 code
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed. The following link explains how to troubleshoot and repair:
http://www.fixya.com/support/r1976388-f22_error_code_whirlpool_duet_kenmore
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
There is a tech sheet located inside the washer behind the lower kick panel under the door. Refer to your tech sheet for more detailed information concerned connector plug numbering and troubleshooting of the CCU.
If you still have questions, please let me know. I hope this helps you.
Jul 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
HE front loader washer door opened during cycle and will not shut
the latch broke within( the hook inwhich actually hold doorshut) , youll need a new latch assy.
Mar 14, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore front loading washer
brand new and you changed the latch mech.? door latch or lock asm.? DU is door unlock error, it tried to unlock and cant. usually replace lock asm (inside machine) for this problem. may have latch out of alignment.
Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
My new front loading washer is not spining. It is 3 months old. We have a 12 month warranty and labor
call whirlpool customer service, they own maytag now, you will be covered under warranty.
Mar 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Door locked
Unplug washer or disconnect power for at lease two minutes. EEPROM ERROR A communication error between the Central Control Unit (CCU)and the EEPROM onboard the CCU occurred. Possible Causes/Procedure ■ A power glitch may cause this error. ? Verify CCU operation by running a Diagnostic Test or any cycle. PUMP DRIVE ERROR The pump driver fails to activate. ■ Replace CCU board. MAIN RELAYS ERROR ERREUR - One of the main relays is not working properly. Possible Causes/Procedure ■ The relay might be soldered or always open. Replace CCU board
Sep 24, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Door locked open
Tool: We cut a piece a wire about 10 inches long from a wire clothes hanger. On one end we bent 1/2 inch of the wire in a 90 degree angle with needle nose pliers. On the other end of wire we put another bend at least three inches.(this end will be your handle end) Process of using homemade tool to release latch: Make sure washing machine is on a wash cycle. Use flash light to locate latch in the locking catch. Insert the small bend of the tool into the locking catch. Then hook onto the latch and pull out --apply a small amount of pressure -- about three lbs of pressure) Then at the same time you are pulling, press in on the door release button (the little white button above the latch hole where you now have the wire inserted). As your are pulling with little pressure on the latch, hold the little white button in and press the start /stop button. You should hear the door lock. Let machine start working. (about ten seconds) Now push start/stop button again and you should hear door lock release. Your lock catch should give away. This worked for us.
Feb 11, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
20 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
