Question about Hotpoint Washing Machines
Hotpoint WT540 - Has fast flashing power light and lights 1 & 4 (Wash enhance & Mini load) flashing slowly. Tried power restting and holding On/Cancel buttons together. Is this a terminal PCB fault (EPROM?) or an easy component replacement (cap, resistor, chip?) Many thanks in advance. Mark.
  • Mark Hales Jan 03, 2013
    I'm going to look at this on Friday for a friend. Does anyone know of a reset procedure. Someone said power and cancel buttons at the same time, but this appears not to work. Neither does switching off for 10 minutes. Thanks.
SOURCE: WF540 - Won't work and rinse hold and wash enhance lights flash?
Hi ya, just a quick suggestion, have you cleaned the filter on the front of your machine?? My machine did this and it was only when i cleaned the fluff and the 5 pence pieces from this filter it stopped, Hope it helps
Dobby
Posted on May 16, 2008
huuum
  • 750 Answers
SOURCE: Wash enhance light keeps flashing
Dear penzance,
Welcome to fixya.com
I'm Huuum and happy to assist you,
You said, Wash enhance light keeps flashing on Hotpoint WT540 Aquarius 1400, have emptied pump filter and cleaned interior.
It keeps coming back, have switched off
Try this method to reset your system as we sometimes do with our computer when it reacts strangely.
As with an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works out!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Huuum.
How old is the appliance?
Please remember to leave a rating when you finish!
Here is an interesting report I just read.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Bless You
Posted on Sep 23, 2008
barkencoa
  • 3463 Answers
SOURCE: Problem with wt540
Have you actually tried to pump water out, if you select a drain only position or drain and spin ,and hold the drain hose into a bucket or into the sink, you should see water pump out.
If it does not ,then you have a blockage somewhere, or your pump is faulty, assuming of course that the pump is getting power.
Plz leave feedback.
Ta
Posted on Dec 10, 2008
SOURCE: Hotpoint WT540 1400 spin. Flashing Rinse hold and Mini load LED
Had exactly the same last week - Jan 09 - and had to call out Hotpoint engineer - £99.98 all inclusive of parts - it was the main controller board, so thats under guarantee for another 12 months. all working and spinning as should be and only took around 30mins.GS :)
Posted on Jan 22, 2009
  • 278 Answers
SOURCE: rinse cycle gets stuck
Most models have a timer relay that times out when a cycle is over. It may be located behaind the front panel - It's worth a shot
Posted on Oct 15, 2009
My washing machine is not working
Sounds like a communication error. remove lid and unplug top consol panel for 5 mins ,make sure connections on bottom pcb are tight ,if that dont work replace your PCB
Mar 08, 2015 | Hotpoint Aquarius WT540 Front
Flashing lights
Sounds like a fault code Ring your local dealer They should have a list of codes and what they mean Hopefully they'll be kind enough to tell you over phone
Oct 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Rinse cycle gets stuck
Oct 15, 2009 | Washing Machines
Water will not drain - rinse hold/mini load lights flashing
You might have to take the pump off and clean out the debris in the line theres probably lint, change and other things in the line. Take the lines off and run a piece of wire through the lines to make sure their clear.
May 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Dec 29, 2008 | Hotpoint Washing Machines
Problem with wt540
Plz leave feedback.
Ta
Dec 10, 2008 | Washing Machines
Machine freezing with three lights flashing.
HI JOHNNYHEFF,
JUST GOT A NEW HOTPOINT STARTED TEST WASH ALL THE LIGHTS FLASHED SO SWITCHED OFF TRIED AGAIN NO JOY. TECHNICIAN COME OUT SAID THE CIRCUIT BOARD WAS GONE, NOT GOOD NEWS FOR YOU BUT THOUGHT I'D LET YOU KNOW!
Oct 23, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Dobby
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
