Question about Honeywell Rth110b Horizontal Digital Manual Thermostat
Batteries don't last but a day or two in my thermostat and then the fan only runs
Heat won't come on,only the fan, I've been changing batteries every few days,
  • 5 Answers
SOURCE: heater won't blow heat and keeps running
first try to pull out the little white button on bottom left side. if it is already pulled out, then take cover off, lightly press on the center dial as you adjust the little adjusters that are in the dial. should be two of them, the first should say off set to 90, second one says on set to 130or 135. these steps may work. if not then one of the wire connections may be loose.
Posted on Apr 26, 2009
  • 5 Answers
SOURCE: day and night heater and a/c unit heater would go
first try to pull the little white button out, it is a manual control button, and the out position is auto. If that does not work try taking off the cover, lightly hold the dial down while you adjust the settings. they are on the side of the dial, first setting is the off pos. set to 90, second is the on pos. set to 125-135. then put cover back on, while being careful not to push the button in.
  • 19 Answers
SOURCE: My Honeywell chronotherm IV Plus thermostat intermittent problem
The Chrono Therm 3 and 4's were some of the worst products that honeywell has EVER put out. I would suggest switching to the Vision Pro 8000, please consult your local HVAC company for more information regarding the change over.
Posted on May 17, 2009
heatman101
  • 43501 Answers
SOURCE: purchased a new stand fan but after few days
The motor has gone bad... the best thing to do is to take it back and get another one... often if a motor is bad it will fail very quickly like that...
Heatman101
Posted on Aug 28, 2010
  • 224 Answers
SOURCE: My thermostat has a low battery indicator that
Fortunately the price of thermostats has dropped over the past couple of years, so you probably know where I am taking you. It is time to replace that faulty thermostat with a new one. Simply remove the old one pay attention to where the wires come from and put them on the same lettered terminals to the old one. It is best to kill power to the furnace before replacing begins.
Posted on Dec 14, 2010
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
Honeywell thermostat won't turn the furnace on after power outage.
probably tripped a limit switch or a low voltage fuse would kill your display on the tstat, you should have battery power on your stat though.unless you have knowlege of electrical you better call a technician
Dec 09, 2012 | Honeywell Programmable Thermostat Heater
My Android Fusion was dropped in water and now won't turn on
Sometimes these things take a while to dry out before they perform the way they're supposed to. Stick it in rice for a few days more. I've had luck with placing it near NOT ON a heat source to aid in drying it out. You don't want to scorch the thing, but leave it in the rice for a couple more hours to days & see how that goes. You should be up and running in no time.
Oct 17, 2012 | Huawei At&t Fusion Prepaid Android Gophone...
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
Fan pulley nut won't budge
it may be reverse threaded
Aug 11, 2012 | BMW Cars & Trucks
HONEYWELL RTHL2310/RTHL221 THERMOSTAT AIR WILL NOT COMEON
Recheck your connections.The wire colors may not have been wired in the standard way when HVAC system was installed. I remember the instructions on my Honeywell thermostat(replaced mine about 2 months ago) stated that you should look at the wire LOCATIONS on the 'stat you're replacing and tag the wires according to this,not the wire color(too late in your case).You'll have to verify the wires.Disconnect them(don't worry about noting where they were as it's not right anyway).Using an A/C voltmeter,locate the hot feed to the 'stat(ground one lead of the meter at a nearby outlet and look for 24v on any of the wires).Tag it as "feed".Now,touch this to each wire until you find one that turns on the ventilation blower and tag it.Try the other two,one of them should turn on the outside A/C condensor unit(this is the A/C wire).The remaining wire's gotta be the furnace,but verify anyway.This should be enough to get you back on track(don't feel bad,the instructions in my 'stat confused me a little,even though I've replaced mine a couple times before).PS- I think the blower fan wire goes to the terminal with the little factory jumper wire-this is so you can set it up to run the same fan in heat or A/C(factory setup) or remove the jumper to run a seperate fan for each(highly unusual setup but possible)
May 25, 2012 | Honeywell Programmable Thermostat Heater
Marvel 6BAR Not Staying Cold
i don't know much about these units,don't work on them but work on sub zeros and have helped out some customers that have me look at them,usually what i find is when they are cool but not cold is the coil is blocked with dust and the heat can't escape from the machine,i use a shop vac,i vac out as much of the dust that i can see and then set it up to blow and blow out the coil,after doing this it usually works
Nov 19, 2011 | Marvel 6BAR Wine Cooler
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
I've changed my battery just last November. I did
Well, if the Batt don't hold charge then check the regulator on the bike with an Ohmmeter you can buy one at an Auto parts shop....motor running you should see 14.5 V if not then the Reg is out!!!
May 24, 2011 | 2001 Harley Davidson FXDWG Dyna Wide Glide
Honeywell Rth110b Horizontal Digital Manual Thermostat Logo
32 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
